  3. Set node id. How?
Set node id. How?
3 Posts 3 Posters 1.6k Views 3 Watching
  • mescalineM
    mescalineM
    mescaline
    Hi!
    This code:
    $sock = socket_create(AF_INET, SOCK_STREAM, SOL_TCP)
    $result = @socket_connect($sock, '172.16.35.66', '5003');
    $data_read = socket_read($sock,40);
    echo $data_read;
    socket_close($sock);
    returns:
    255;255;3;0;3;
    but, if i try to set node id using code:
    $write = socket_write($sock, '32;0;3;0;4;');
    code return:
    how to set node id?
    • ahmedadelhosniA
      ahmedadelhosniA
      ahmedadelhosni
      Did you check the API ?
      https://www.mysensors.org/download/serial_api_15
      • T
        TimO
        Did you send a newline at the end?
