  3. Using mqttGateway2.pl for Serial to MQTT on RaspberryPI
31 Posts 6 Posters 11.8k Views 6 Watching
  • A aaron832
    Try typing
    "uname -m"
    into your console (that hosts the gateway). If it does not say
    "armv6l" or "armv7l" (edit: correction)
    then the Makefile will not include -lrf24-bcm in the LDFLAGS (libraries include). If this is the problem then what hardware are you making the gateway on?
    Artur MajA Offline
    Artur MajA Offline
    Artur Maj
    @aaron832 It says armv7l. Please, note it is not armv71 the last character is small "L" not 1 (one). This is raspberry pi 2 with ubuntu mate 15.10. I am going to edit Makefile replacing armv71 with armv7l and see what's happening. Thanks again.
    • C Offline
      C Offline
      cingolanifede
      Hi, i tried to make the script work but i couldnt. did anybody make it work? I used the serial gateway option, installed all the libraries.
      . thankspi@raspberrypi:/ $ sudo ./mqttGateway2.pl --serial /dev/ttyUSB0
      Subroutine main::inet_aton redefined at /usr/share/perl/5.20/Exporter.pm line 66.
      at ./mqttGateway2.pl line 42.
      given is experimental at ./mqttGateway2.pl line 267.
      when is experimental at ./mqttGateway2.pl line 269.
      when is experimental at ./mqttGateway2.pl line 270.
      when is experimental at ./mqttGateway2.pl line 271.
      when is experimental at ./mqttGateway2.pl line 272.
      Smartmatch is experimental at ./mqttGateway2.pl line 313.
      Smartmatch is experimental at ./mqttGateway2.pl line 332.
      given is experimental at ./mqttGateway2.pl line 400.
      when is experimental at ./mqttGateway2.pl line 402.
      when is experimental at ./mqttGateway2.pl line 411.
      Name "main::fh" used only once: possible typo at ./mqttGateway2.pl line 207.
      can't create /var/run/mqttMySensors/Gateway__dev_ttyUSB0: No existe el fichero o el directorio at ./mqttGateway2.pl line 452.
      What does it means?
      Y 1 Reply Last reply
      • C Offline
        C Offline
        cingolanifede
        @Yveaux Keep on getting this error
        • C cingolanifede
          What does it means?
          Y Offline
          Y Offline
          This path doesn't exist. Create it, or change the path.
          All others are warnings, due to an incompatible perl version you're using.
          C 1 Reply Last reply
          • Y Yveaux
            C Offline
            C Offline
            cingolanifede
            @Yveaux ok. Thanks. I did it. But i am having a different problem now. I have serial gateway running fine. I installed mosquitto and try to follow different steps from the forum and I dont know how to make this work.K cant make the connection beetwen openhab--mosquitto-script--serial gateway. Can you help me ? Is there any post where this is done? Thanks in advance.
            • C cingolanifede
              Y Offline
              Y Offline
              @cingolanifede I don't have a step by step description for your solution. Searching (and reading) the forum sounds like a good start. If you give us a clear description of what seems to be working and what not, or where you get stuck, it's easier to help.
              • Y Yveaux
                C Offline
                C Offline
                cingolanifede
                @Yveaux 1) The script is running. It reads from serial port, this is what I get, then it crashes, and says broken pipe.
                20160509-10:48:33 RX: [0;0;3;0;9;read: 30-30-0 s=1,c=1,t=16,pt=2,l=2,sg=1:1] fr=000 ci=000 c=C_INTERNAL st=I_LOG_MESSAGE noack 'read: 30-30-0 s=1,c=1,t=16,pt=2,l=2,sg=1:1' -> Publish to broker 'MyMQTT/0/0/I_LOG_MESSAGE':'read: 30-30-0 s=1,c=1,t=16,pt=2,l=2,sg=1:1'
                20160509-10:48:33 RX: [30;1;1;0;16;1 ] fr=030 ci=001 c=C_SET st=V_TRIPPED noack '1' -> Publish to broker 'MyMQTT/30/1/V_TRIPPED':'1'
                20160509-10:48:43 Exception: Error: Tubería rota
                20160509-10:48:43 Restarting...
                20160509-10:48:43 trying to restore subscriptions
                ====2)On openhab log I get this========
                2016-05-09 10:48:33.189 [ERROR] [o.i.t.m.i.MqttBrokerConnection] - MQTT connection to broker was lost
                org.eclipse.paho.client.mqttv3.MqttException: Se ha perdido la conexión
                at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:138) [mqtt-client-0.4.0.jar:na]
                at java.lang.Thread.run(Thread.java:744) [na:1.8.0]
                Caused by: java.io.EOFException: null
                at java.io.DataInputStream.readByte(DataInputStream.java:267) ~[na:1.8.0]
                at org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream.readMqttWireMessage(MqttInputStream.java:56) ~[na:na]
                at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:100) [mqtt-client-0.4.0.jar:na]
                ... 1 common frames omitted
                2016-05-09 10:48:33.191 [ERROR] [o.i.t.m.i.MqttBrokerConnection] - MQTT connection to 'mysensor' was lost: Se ha perdido la conexión : ReasonCode 32109 : Cause : null
                2016-05-09 10:48:33.193 [INFO ] [o.i.t.m.i.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'mysensor'
                On openhab.cfg i put this and i have the addons installed
                mqtt:mysensor.url=tcp://192.168.1.109:1883
                mqtt:mysensor.clientId=mys
                A simple switch setting
                Switch node2_sw1 "sw1" (node2,all) {mqtt=">[mysensor:MyMQTT/30/10/V_LIGHT:command:ON:1],>[mysensor:MyMQTT/30/10/V_LIGHT:command:OFF:0]"}
                I think the problem is that i am not setting mosquitto well beetwen openhab and your script. I tested an example publishing and i get the message. Do I have to change conf.d file? or setting?
                Thanks.
                • C Offline
                  C Offline
                  cingolanifede
                  @Yveaux I made improvement:
                  I am using mosquitto_sub to read what the script posted. Thats ok.
                  pi@domotic /opt/domotic/runtime $ mosquitto_sub -d -t MyMQTT/30/1/V_TRIPPED
                  Client mosqsub/3629-domotic sending CONNECT
                  Client mosqsub/3629-domotic received CONNACK
                  Client mosqsub/3629-domotic sending SUBSCRIBE (Mid: 1, Topic: MyMQTT/30/1/V_TRIPPED, QoS: 0)
                  Client mosqsub/3629-domotic received SUBACK
                  Subscribed (mid: 1): 0
                  Client mosqsub/3629-domotic received PUBLISH (d0, q0, r1, m0, 'MyMQTT/30/1/V_TRIPPED', ... (1 bytes))
                  Client mosqsub/3629-domotic received PUBLISH (d0, q0, r0, m0, 'MyMQTT/30/1/V_TRIPPED', ... (1 bytes))
                  Client mosqsub/3629-domotic sending PINGREQ
                  Client mosqsub/3629-domotic received PINGRESP
                  The thing is when I start openhab this happens, it crashes and i get this error. What could it be?
                  2016-05-09 11:56:52.216 [ERROR] [o.i.t.m.i.MqttBrokerConnection] - MQTT connection to broker was lost
                  2016-05-09 11:56:52.219 [ERROR] [o.i.t.m.i.MqttBrokerConnection] - MQTT connection to 'mysensor' was lost: Se ha perdido la conexión : ReasonCode 32109 : Cause : null
                  2016-05-09 11:56:52.220 [INFO ] [o.i.t.m.i.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'mysensor'
                  • Y Offline
                    Y Offline
                    The script is running for months without issues on my place; both for serial and Ethernet gateway. I am not using the script in combination with a raspberry pi. Maybe there is an issue with the version of mosquitto and/or AnyEvent::MQTT.
                    I remember other people having issues in combination with raspberry pi - search the forum.
                    • Y Yveaux
                      C Offline
                      C Offline
                      cingolanifede
                      @Yveaux Thanks again. I used a phyton script. Now is working.
                      • R Offline
                        R Offline
                        robosensor
                        wrote on last edited by robosensor
                        #31
                        Not sure I'm doing this right way, but changing this line:
                                fh => $serialDevice->{'HANDLE'},
                        to this line
                                fh => new_from_fd IO::Handle ($serialDevice->{FD}, "w"),
                        Fixed Filehandle GEN0 opened only for input bug for me on RPi 2. Fix works because of $serialDevice->{'HANDLE'} is opened as read only in SerialDevice and should not be used for write:
                            # a handle object for ioctls: read-only ok
                            $self->{HANDLE} = new_from_fd IO::Handle ($self->{FD}, "r");
                        12.2k
