  3. [SOLVED]Two nodes with relays interfering
26 Posts 6 Posters 7.7k Views 5 Watching
    @MasMat Looks like the gateway's receive function is called even when the gateway is the destination of the message. That results in the gateway updating its relay even though it shouldn't.
    I think you could do something like this:
    if (message.type==V_STATUS) {
        if (message.sensor == 0) { // Only switch the relay if the message is for myself
            Serial.print("Updating relay state");
            // Change relay state
            // Store state in eeprom
            // Write some debug info
        Serial.print(message.sensor);
    MasMatM
    MasMatM
    MasMat
    @mfalkvidd I've been reviewing this: I have two relays actually attached, so this code will ignore the other completely, right? I think that's why it's not working. Or the numbering for the sensors is different?
    Am I wrong or does the "message.sensor" actually refer to child_id rather than node_id? Or am I following this wrong?
    • MasMatM MasMat
      @MasMat I have trouble finding documentation explaining the details, but I think you are right. See if message.destination works better.
      MasMatM 1 Reply Last reply
        MasMatM
        MasMatM
        MasMat
        wrote on last edited by MasMat
        #23
        @mfalkvidd That fixed it right up and makes complete sense. I couldn't find docs either on message.sensor or message.destination...
        The problem now appears more complex...
        The GW (node 0) relay STILL follows the other nodes (node 4) commands (completely different circuits, so no electrical connection at all).
        GW debug (first a on & off test for gw-relay, then clicked the node4-relay, on comes OK (gwrelay follows) but off reboots gw)
        0;255;3;0;9;Message arrived on topic: domoticz/out/MyMQTT/0/1/1/0/2
        Updating relay stateIncoming change for sensor:1, New status: 1
        Updating relay stateIncoming change for sensor:1, New status: 0
        0;255;3;0;9;TSF:MSG:READ,4-4-0,s=1,c=1,t=0,pt=7,l=5,sg=0:16.6
        0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/4/1/1/0/0
        0;255;3;0;9;TSF:MSG:READ,4-4-0,s=0,c=1,t=1,pt=7,l=5,sg=0:69.8
        0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/4/0/1/0/1
        0;255;3;0;9;Message arrived on topic: domoticz/out/MyMQTT/4/1/1/1/2
        0;255;3;0;9;TSF:MSG:SEND,0-0-4-4,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:1
        0;255;3;0;9;TSF:MSG:READ,4-4-0,s=1,c=1,t=2,pt=0,l=1,sg=0:1
        0;255;3;0;9;TSF:MSG:ACK
        0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/4/1/1/1/2
        0;255;3;0;9;!TSF:MSG:SEND,0-0-4-4,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:1
        0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.1
        0;255;3;0;9;MCO:BGN:BFR```
        • MasMatM
          MasMatM
          MasMat
          Nevermind. Whined too soon.
          Completely worked over the node4 code, moved "include"s around and eventually changed the relay presentations and receive clauses. Hope this helps someone with their problems later:
          Thanks a millions!
          void before()
              // Set relay pin in output mode
              pinMode(RELAY_1, OUTPUT);
              digitalWrite(RELAY_1, loadState(CHILD_ID_RELAY)?RELAY_ON:RELAY_OFF);
          later this....
          present(CHILD_ID_RELAY, S_BINARY);
          ....and ending with this...
              if (message.destination == MY_NODE_ID) { // Only switch the relay if the message is for this node
                  digitalWrite(RELAY_1, message.getBool()?RELAY_ON:RELAY_OFF);
                  saveState(CHILD_ID_RELAY, message.getBool());
          • MasMatM MasMat
            Thanks a millions!
            void before()
            later this....
            #25
            @MasMat great work! Maybe change this to make the output more complete?
            to
                Serial.print("Incoming change for node: ");
                Serial.print(message.destination);
                Serial.print(", sensor:");
              to
              MasMatM
              MasMatM
              MasMat
              @mfalkvidd That would definitely polish it up! :D
              Cheers!!
