  3. [SOLVED]Two nodes with relays interfering
26 Posts 6 Posters 7.7k Views 5 Watching
  • MasMatM
    MasMatM
    MasMat
    Back at this after a while... I changed code for all nodes and manually assigned node_ids to make sure nothing interferes.
    Currently the problem: when a remote nodes (number 4) relay is activated, it also causes the relay attached to gw-node to activate. The gw attached relay works well by itself (optocoupled).
    I checked MQTT traffic and there's nothing fishy (activation message "1"). I also checked the debug on the gw and that looks OK to me as well.
    The gw relays are optocoupled, the outside (it's a dht22+single relay node) light relay is not. GW receives power from car battery thru usb, so no interference should be possible.
    Any ideas?
    Conflicting relays code:
    // Enable debug prints
    #define MY_REPEATER_FEATURE
    //#define MY_RS485
    #define MY_NODE_ID 4
    #define DHT_DATA_PIN 4
    #define SENSOR_TEMP_OFFSET 0
    //static const uint64_t UPDATE_INTERVAL = 60000;
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
    #define CHILD_ID_RELAY 2
    void before()
        pinMode(pin, OUTPUT);
      sendSketchInfo("TempHumRelUlko", "vMasi");
      present(CHILD_ID_HUM, S_HUM);
      present(CHILD_ID_RELAY, S_BINARY);
      //for (int sensor=1, pin=RELAY_1; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
        //present(sensor, S_BINARY);
    //  if (UPDATE_INTERVAL <= dht.getMinimumSamplingPeriod()) {
      //  Serial.println("Warning: UPDATE_INTERVAL is smaller than supported by the sensor!");
      sleep(2000);
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
        nNoUpdatesHum++;
      //sleep(UPDATE_INTERVAL);
    wait(120000);
      if (message.type==V_STATUS) {
        // Change relay state
        // Store state in eeprom
    And the debug from GW:
    0;255;3;0;9;MCO:BGN:BFR
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSF:WUR:MS=0
    0;255;3;0;9;TSM:INIT:TSP OK
    0;255;3;0;9;TSM:INIT:GW MODE
    IP: 192.168.0.201
    0;255;3;0;9;MCO:BGN:STP
    IP: 192.168.0.201
    0;255;3;0;9;MQTT connected
    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/0/255/0/0/18
    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/0/255/3/0/11
    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/0/255/3/0/12
    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/0/1/0/0/3
    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/0/2/0/0/3
    0;255;3;0;9;Message arrived on topic: domoticz/out/MyMQTT/4/1/1/1/2
    0;255;3;0;9;TSF:MSG:SEND,0-0-4-4,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:0
    0;255;3;0;9;TSF:MSG:READ,4-4-0,s=1,c=1,t=2,pt=0,l=1,sg=0:0
    0;255;3;0;9;TSF:MSG:ACK
    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/4/1/1/1/2
    Incoming change for sensor:1, New status: 0
    0;255;3;0;9;TSF:MSG:SEND,0-0-4-4,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:1
    0;255;3;0;9;TSF:MSG:READ,4-4-0,s=1,c=1,t=2,pt=0,l=1,sg=0:1
    Incoming change for sensor:1, New status: 1
    • MasMatM MasMat
      Any ideas?
      //#define MY_RS485
      float lastTemp;
      float lastHum;
      bool metric = true;
      DHT dht;
      void before()
        sleep(2000);
          if (!metric) {
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
          nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
          nNoUpdatesHum++;
      wait(120000);
      IP: 192.168.0.201
      IP: 192.168.0.201
      @MasMat could you post the sketch for your gateway node as well?
      • MasMatM
        MasMatM
        MasMat
        Sure. Here it is. Slight mod from MQTT sketch with Relay sketch parts.
        #define MY_MQTT_PUBLISH_TOPIC_PREFIX "domoticz/in/MyMQTT"
        #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "domoticz/out/MyMQTT"
        // Set MQTT client id
        //#define MY_W5100_SPI_EN 4
        // radio on the same spi bus.
        #define MY_SOFTSPI
        #ifndef MY_RF24_CE_PIN
        #define MY_RF24_CE_PIN 5
        #ifndef MY_RF24_CS_PIN
        #define MY_RF24_CS_PIN 6
        #define MY_IP_ADDRESS 192,168,0,201
        #define MY_IP_GATEWAY_ADDRESS 192,168,0,254
        #define MY_CONTROLLER_IP_ADDRESS 192, 168, 0, 200
        #define MY_PORT 1883
        // Enable inclusion mode
        // Set blinking period
        // Flash leds on rx/tx/err
        #define NUMBER_OF_RELAYS 2 // Total number of attached relays
        // #define CHILD_ID_RELAY1 1
        // #define CHILD_ID_RELAY2 2
        #include <Ethernet.h>
        void before()
          sendSketchInfo("MQTT_GWAndRelay", "vMasi");
        • MasMatM MasMat
          #define MY_SOFTSPI
          void before()
          @MasMat Looks like the gateway's receive function is called even when the gateway is the destination of the message. That results in the gateway updating its relay even though it shouldn't.
          I think you could do something like this:
              if (message.sensor == 0) { // Only switch the relay if the message is for myself
                  Serial.print("Updating relay state");
          MasMatM 2 Replies Last reply
            MasMatM
            MasMatM
            MasMat
            wrote on last edited by MasMat
            @mfalkvidd All this under "void loop"? Do I remove the "void receive"?
            I added (and commented out previous) under "void receive": the relay became unresponsive.
            debug:
            0;255;3;0;9;Message arrived on topic: domoticz/out/MyMQTT/0/2/1/0/2
            Incoming change for sensor:2, New status: 1
            Incoming change for sensor:2, New status: 0
              You need the receive, just replace the code
              MasMatM 1 Reply Last reply
                MasMatM
                MasMatM
                MasMat
                @gohan I did. Relay unresponsive but clearly the messages are coming thru. Went back, relay works so not mechanical/electrical.
                Current code:
                  MasMatM
                  MasMatM
                  MasMat
                  @mfalkvidd I've been reviewing this: I have two relays actually attached, so this code will ignore the other completely, right? I think that's why it's not working. Or the numbering for the sensors is different?
                  Am I wrong or does the "message.sensor" actually refer to child_id rather than node_id? Or am I following this wrong?
                  • MasMatM MasMat
                    @MasMat I have trouble finding documentation explaining the details, but I think you are right. See if message.destination works better.
                      MasMatM
                      MasMatM
                      MasMat
                      #23
                      @mfalkvidd That fixed it right up and makes complete sense. I couldn't find docs either on message.sensor or message.destination...
                      The problem now appears more complex...
                      The GW (node 0) relay STILL follows the other nodes (node 4) commands (completely different circuits, so no electrical connection at all).
                      GW debug (first a on & off test for gw-relay, then clicked the node4-relay, on comes OK (gwrelay follows) but off reboots gw)
                      0;255;3;0;9;Message arrived on topic: domoticz/out/MyMQTT/0/1/1/0/2
                      Updating relay stateIncoming change for sensor:1, New status: 1
                      Updating relay stateIncoming change for sensor:1, New status: 0
                      0;255;3;0;9;TSF:MSG:READ,4-4-0,s=1,c=1,t=0,pt=7,l=5,sg=0:16.6
                      0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/4/1/1/0/0
                      0;255;3;0;9;TSF:MSG:READ,4-4-0,s=0,c=1,t=1,pt=7,l=5,sg=0:69.8
                      0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/4/0/1/0/1
                      0;255;3;0;9;!TSF:MSG:SEND,0-0-4-4,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:1
                      0;255;3;0;9;MCO:BGN:BFR```
                      • MasMatM
                        MasMatM
                        MasMat
                        Nevermind. Whined too soon.
                        Completely worked over the node4 code, moved "include"s around and eventually changed the relay presentations and receive clauses. Hope this helps someone with their problems later:
                        Thanks a millions!
                        void before()
                            // Set relay pin in output mode
                            pinMode(RELAY_1, OUTPUT);
                            digitalWrite(RELAY_1, loadState(CHILD_ID_RELAY)?RELAY_ON:RELAY_OFF);
                        later this....
                        ....and ending with this...
                            if (message.destination == MY_NODE_ID) { // Only switch the relay if the message is for this node
                                digitalWrite(RELAY_1, message.getBool()?RELAY_ON:RELAY_OFF);
                                saveState(CHILD_ID_RELAY, message.getBool());
                        • MasMatM MasMat
                          Thanks a millions!
                          void before()
                          later this....
                          #25
                          @MasMat great work! Maybe change this to make the output more complete?
                          to
                              Serial.print("Incoming change for node: ");
                              Serial.print(message.destination);
                              Serial.print(", sensor:");
                            to
                            MasMatM
                            MasMatM
                            MasMat
                            @mfalkvidd That would definitely polish it up! :D
                            Cheers!!
