  3. Mystery Node ID
Mystery Node ID
1 Posts 1 Posters 826 Views 2 Watching
  • I
    I
    Ironbar
    Can someone please explain this? I only have two nodes, 105 and 106 which are both hard coded into the sketches. I have this mystery node 32 that shows up on the gateway and I cannot figure out what it is.
    from gateway:
    0;0;3;0;9;read: 32-32-0 s=0,c=1,t=0,pt=7,l=0,sg=0:70
    0;0;3;0;9;ver mismatch
    0;0;3;0;9;read: 106-106-0 s=255,c=0,t=17,pt=0,l=5,sg=0:1.5.1
    106;255;0;0;17;1.5.1
    0;0;3;0;9;read: 106-106-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
    106;255;3;0;6;0
    Finished
    106;255;3;0;6;I
    0;0;3;0;9;send: 0-0-106-106 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:I
    0;0;3;0;9;read: 32-32-0 s=255,c=1,t=1,pt=0,l=16,sg=0:
    0;0;3;0;9;read: 106-106-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
    106;255;3;0;12;1.1
    0;0;3;0;9;read: 106-106-0 s=0,c=0,t=6,pt=0,l=0,sg=0:
    106;0;0;0;6;
    0;0;3;0;9;read: 32-40-0 s=0,c=0,t=0,pt=7,l=0,sg=0: 0
    from node:
    send: 106-106-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.1
    send: 106-106-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
    read: 0-0-106 s=255,c=3,t=6,pt=0,l=1,sg=0:I
    sensor started, id=106, parent=0, distance=1
    send: 106-106-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,st=ok:Temperature Sensor
    send: 106-106-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
    send: 106-106-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=ok:
    send: 106-106-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:70.5
    and node 105 looks the same.
    Am I just reading this wrong or is something else going on?
    Thanks for any help.
