Serial Gateway and MQTT Broker
@jkandasa has the independent service been created? I would really love to see this feature. Im using Home Assistant for overall home automation. But I want to manage MySensors with MyController due to the better features to handle MySensor Nodes.
@talhatec Thank you for your patience
Finally the first version of serial2mqtt adapter available and released for public. Kindly report issues if you find any on issues page -
@jkandasa The serial2MQTT adapter worked for a while, but then it started to fail. Looking at the logs, its not receiving the data from serial properly
2017-08-07 18:04:00,942 ERROR [Thread-1] [org.mycontroller.serial2mqtt.gateway.MessageMonitorThread:66] Exception on processing [RawMessage(gatewayId=null, data=%ヘ보ᅭ▒ᅪ゙ノ<*▒oᄚ볘ロ¦▒0;255;3;0;9;TSF:MSG:READ,254-254-0,s=255,c=3,t=1,pt=0,l=0,sg=0:, subData=null, isTxMessage=false, networkType=MY_SENSORS, timestamp=1502125439421)], java.lang.NumberFormatException: For input string: "%ヘ보ᅭ▒ᅪ゙ノ<*▒oᄚ볘ロ¦▒0" at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65) at java.lang.Integer.parseInt(Integer.java:569) at java.lang.Integer.valueOf(Integer.java:766) at org.mycontroller.serial2mqtt.gateway.MessageEngine.postOnMqtt(MessageEngine.java:53) at org.mycontroller.serial2mqtt.gateway.MessageMonitorThread.processRawMessage(MessageMonitorThread.java:63) at org.mycontroller.serial2mqtt.gateway.MessageMonitorThread.run(MessageMonitorThread.java:85) at java.lang.Thread.run(Thread.java:745) -
@jkandasa Not sure what the issue is, but the adapter seems to be working fine now. Ill leave it running for a day and see if the data issue reappears. I was trying to get HomeAssistant and myController to work off the same MQTT topics. maybe thats what cause the data issue.
@jkandasa It seems to be stable now. Think that it was a one off issue. Ive now got both HomeAssistant and MyController working on the same MQTT in/out topics.
However, when a sensor calls back to the controller, both HomeAssistant and myController send out replies, and due to this, i think the messages clash, and the controllers endup sending it multiple times.
Have to think of a way to make only one respond to requests.
I do not know your preference about, which controller wants to response for your sensors request. Suppose you want MyController only on listen mode, you have to change MQTT
Topic publishto some dummy topic on MyController gateway settings.
