  3. MQTT Broker gateway
MQTT Broker gateway
132 Posts 34 Posters 147.5k Views 7 Watching
  • H
    H
    hooraysimpsons
    I can't seem to get openhab to communicate with my MQTT gateway. I can connect to the gateway with the MyMQTT Android app and I receive messages from my light sensor node including the sketch name and light level. I can ping my gateway without issue as well.
    However, OpenHab never seems like it notices the gateway. No data in the sketch name or node result. I've used the sitemap, items, and config files as described above and I've also customized them to match my sensor node more specifically. Both without success. The only change I've made is my sensor node is defined as node ID 20 within it's sketch.
    When using start_Debug.bat what should I see in the command line window to indicate OpenHab even sees or connects to the gateway. I see no indication that it attempts to connect to the IP address of my gateway.
    • G
      G
      Gambituk
      Maybe if you can share your items, sitemap, and rules if any.
      H 1 Reply Last reply
      • G Gambituk
        H
        H
        hooraysimpsons
        wrote on last edited by hooraysimpsons
        #83
        @Gambituk
        openhab.cfg
        test.items
        1present0absent.map
        test.sitemap
        • G
          G
          Gambituk
          can you also please paste a sample of what you see in myMQTT or screenshot maybe? or it can be easier to copy and paste from a terminal window? are you using raspberry pi or something else?
          • C
            C
            C.r.a.z.y.
            @hooraysimpsons unplug the power and restart your modem, check your dhcp menu if it has ip for Ardiuno.
            Check your mqtt from serial monitor, you must see "gateway started..."
            • G
              G
              Gambituk
              mosquitto_sub -h localhost -v -t '#'
              This is what i use to see what is happening on mqtt broker, i am using a raspberry pi and mosquitto installed on the same pi. you can also swap localhost for ip address ie 192.168.0.5 etc
              • G
                G
                Gambituk
                @C.r.a.z.y. it sounds like he is getting as far as the mqtt broker, so the gateway must be working. ?
                • H
                  H
                  hooraysimpsons
                  Crazy- I was thinking my network connection as a source of the problem. On my router homepage the gateway does not show up as being given an IP. However, the MyMQTT Android App sees the gateway without issue so the routing across my network from phone to gateway is successful. I have attached a screenshot of the MyMQTT andoird app output.
                  I am trying to run OpenHab on a windows PC. I don't have mosquitto running at all. My understanding is that it is not required.
                  • G
                    G
                    Gambituk
                    Group all
                    Group node1 (all)
                    Group node2 (all)
                    Group sketch (all)
                     Number node1_light  "Light Level"     (node1,all)  {mqtt="<[mysensor:MyMQTT/20/0/V_LIGHT_LEVEL:state:default]"}
                    Try changing the first line of items like this above.. and in sitemap change node1_temp to node1_light
                    Also see if activating any of the switches in openhab publishes to myMQTT ?
                    • C
                      C
                      C.r.a.z.y.
                      Restarting the modem and checking wires of arduino solved my problem before.
                      I am sure mqtt have to be in dhcp list.
                      • H
                        H
                        hooraysimpsons
                        #91
                        I have restarted my router with no effect. The gateway still does not show up as an active client (using DDWRT) but I still have a connection from phone to gateway.
                        Added the above line. I've used one before like it but went back to what was given at the beggining of this thread to start anew. I also tried with the following edits
                        "Light Level"
                        "Light Level [%s]"
                        "Light Level [%.1f]"
                        None of which make a difference. The reason I think OpenHab doesn't even see the gateway is because nothing shows up in sketch name either which should work even if the above line was incorrect.
                        I have done the testing with the Android App turned off as well since I know OpenHab had some issues earlier if other clients were accessing the gateway.
                        I still see no reference to my gateway's IP in any of the OpenHab output/logs. So I'm not sure it is even trying.
                        The only error message in my openhab log is:
                        11:23:46.951 [ERROR] [sphere.cpr.AtmosphereFramework:2215 ] -
                        I tried clearing the EEPROM in the gateway. I changed it's Mac address and removed the DHCP lease for it from my router. Still no evidence of the gateway on my router status page but also still able to connect to it with my phone.
                        Another update:
                        I installed Mosquitto and I see the light sensor level using mosquitto_sub -h 192.168.1.134 -t MyMQTT
                        M 1 Reply Last reply
                        • H hooraysimpsons
                          "Light Level"
                          "Light Level [%s]"
                          Another update:
                          marceloaqno
                          Code Contributor
                          @hooraysimpsons Your gateway seems to be working fine. Do you see something like this on your openhab logs?
                          2015-02-27 17:48:06.349 [INFO ] [.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
                          2015-02-27 17:48:06.350 [INFO ] [o.i.t.m.i.MqttBrokerConnection] - Starting MQTT broker connection 'mysensor'
                          • M marceloaqno
                            H
                            H
                            hooraysimpsons
                            @celonunes Nope. I figured it out. In my openhab config file there was space prior to my MQTT related lines
                            " mqtt:mysensor.url=tcp://192.168.1.134:1883"
                            " mqtt:mysensor.clientId=OpenhabMQTT"
                            Instead of
                            "mqtt:mysensor.url=tcp://192.168.1.134:1883"
                            "mqtt:mysensor.clientId=OpenhabMQTT"
                            Removed the space and now I get my light sensor output value. I still don't get the sketch name coming through but I'll look into that later.
                            IdeasKickerI 1 Reply Last reply
                            • C
                              C
                              C.r.a.z.y.
                              wrote on last edited by C.r.a.z.y.
                              #94
                              @celonunes @hek
                              I installed this https://github.com/lurch/rpi-serial-console
                              pi@raspberrypi ~ $ rpi-serial-console status
                              Serial console on /dev/ttyAMA0 is disabled
                              Now my nodes are working perfect when i use manual button or ui but my logs are not correct
                              My config:
                              add on : org.openhab.binding.serial_1.6.0.201411271703.jar
                              String Arduino "Arduino" { serial="/dev/ttyUSB0" }
                              As you see there are "fails" but nodes are working.
                              015-03-09 12:37:51.725 [INFO ] [runtime.busevents ] - Arduino state updated to 0;0;3;0;9;send: 0-0-52-52 s=1,c=1,t=2,pt=0,l=1,st=fail:1
                              2015-03-09 12:37:56.726 [INFO ] [runtime.busevents ] - Arduino state updated to 0;0;3;0;9;read: 52-52-0 s=255,c=0,t=18,pt=0,l=5:1.4.1
                              52;255;0;0;18;1.4.1
                              0;0;3;0;9;read: 52-52-0 s=255,c=3,t=6,pt=1,l=1:0
                              52;255;3;0;6;0
                              2015-03-09 12:37:58.768 [INFO ] [runtime.busevents ] - Arduino state updated to 0;0;3;0;9;read: 52-52-0 s=255,c=3,t=11,pt=0,l=14:Relay & Button
                              52;255;3;0;11;Relay & Button
                              0;0;3;0;9;read: 52-52-0 s=255,c=3,t=12,pt=0,l=3:1.0
                              52;255;3;0;12;1.0
                              0;0;3;0;9;read: 52-52-0 s=1,c=0,t=3,pt=0,l=5:1.4.1
                              52;1;0;0;3;1.4.1
                              0;0;3;0;9;read: 52-52-0 s=2,c=0,t=3,pt=0,l=5:1.4.1
                              52;2;0;0;3;1.4.1
                              2015-03-09 12:37:59.700 [INFO ] [runtime.busevents ] - S2 received command ON
                              2015-03-09 12:37:59.822 [INFO ] [runtime.busevents ] - Arduino received command 52;1;1;0;2;0
                              2015-03-09 12:38:00.106 [INFO ] [runtime.busevents ] - Arduino state updated to 0;0;3;0;9;send: 0-0-52-52 s=1,c=1,t=2,pt=0,l=1,st=fail:0
                              2015-03-09 12:38:00.546 [INFO ] [runtime.busevents ] - S2 received command OFF
                              2015-03-09 12:38:00.661 [INFO ] [runtime.busevents ] - Arduino received command 52;1;1;0;2;1
                              2015-03-09 12:38:00.967 [INFO ] [runtime.busevents ] - Arduino state updated to 0;0;3;0;9;send: 0-0-52-52 s=1,c=1,t=2,pt=0,l=1,st=fail:1
                              2015-03-09 12:38:01.161 [INFO ] [runtime.busevents ] - S2 received command ON
                              2015-03-09 12:38:01.339 [INFO ] [runtime.busevents ] - Arduino received command 52;1;1;0;2;0
                              2015-03-09 12:38:01.649 [INFO ] [runtime.busevents ] - Arduino state updated to 0;0;3;0;9;send: 0-0-52-52 s=1,c=1,t=2,pt=0,l=1,st=fail:0
                              2015-03-09 12:38:01.782 [INFO ] [runtime.busevents ] - S2 received command OFF
                              2015-03-09 12:38:01.894 [INFO ] [runtime.busevents ] - Arduino received command 52;1;1;0;2;1
                              2015-03-09 12:38:02.076 [INFO ] [runtime.busevents ] - Arduino state updated to 0;0;3;0;9;send: 0-0-52-52 s=1,c=1,t=2,pt=0,l=1,st=fail:1
                              • ChaoticC
                                ChaoticC
                                Chaotic
                                Just want to make sure I'm understanding this correctly since I feel the MQTT terminology is new to me.
                                The MQTT Broker is the MQTT server so if I wanted to use this with openhab on a pi I would just need the MQTT plugin and then point it to the IP of the gateway?
                                I have the ethernet module ordered so I can't test myself yet.
                                • C C.r.a.z.y.
                                  @celonunes @hek
                                  My config:
                                  52;255;0;0;18;1.4.1
                                  52;255;3;0;6;0
                                  52;255;3;0;12;1.0
                                  52;1;0;0;3;1.4.1
                                  52;2;0;0;3;1.4.1
                                  marceloaqno
                                  Code Contributor
                                  @C.r.a.z.y. You are using the raspberry serial port to connect the openhab with the arduino and the arduino is running the SerialGateway sketch, is that right?
                                  • ChaoticC Chaotic
                                    marceloaqno
                                    Code Contributor
                                    That's right.
                                    ChaoticC M 2 Replies Last reply
                                      msebbe
                                      wrote on last edited by msebbe
                                      #98
                                      I have ENC28J60-I/SO connected by ethernetcable to my Asus RT-n66u in LAN 4. But It will not show up in my router... On my ENC28J60 there is a red light on D1 and the ethernet port has a green light and a yellow flashing light.
                                      Serial monitor says "
                                      Started!
                                      0;0;3;0;9;read: 20-20-0 s=255,c=0,t=17,pt=0,l=5:1.4.1
                                      0;0;3;0;9;read: 20-20-0 s=255,c=3,t=6,pt=1,l=1:0
                                      0;0;3;0;9;send: 0-0-20-20 s=255,c=3,t=6,pt=0,l=1,st=ok:M
                                      0;0;3;0;9;read: 20-20-0 s=255,c=3,t=11,pt=0,l=18:Temperature Sensor
                                      0;0;3;0;9;read: 20-20-0 s=255,c=3,t=12,pt=0,l=3:1.0
                                      . But nothing more. I have followed the MQTT gateway guide and set an static ip in the sketch.. DHCP is on in my router.
                                      The only thing I see in my router is : That the cable is connected to something and that its 10 Half duplex.
                                      I have also tried to connect it to other LAN ports but no difference
                                      What could be wrong?
                                      • M msebbe
                                        Started!
                                        marceloaqno
                                        Code Contributor
                                        @msebbe Did you try to ping the gateway static IP?
                                        • M marceloaqno
                                          msebbe
                                          #100
                                          @celonunes
                                          Yes, both from windows cmd and from the router ui with this result:
                                          PING 192.168.1.197 (192.168.1.197): 56 data bytes
                                          --- 192.168.1.197 ping statistics ---
                                          5 packets transmitted, 0 packets received, 100% packet loss
                                          Could be that I have not changed the MAC adress cause I tried to figure out how to do it but I dont understand this part from the MQTT gateway sketch:
                                          *1 -> NOTE: Keep first byte at x2, x6, xA or xE (replace x with any hex value) for using Local Ranges.
                                           #define TCP_PORT 1883						// Set your MQTT Broker Listening port.
                                           IPAddress TCP_IP ( 192, 168, 1, 197 );				// Configure your static ip-address here
                                           uint8_t TCP_MAC[] = { 0x02, 0xDE, 0xAD, 0x00, 0x00, 0x42 };	// Mac-address - You should change this! see note *2 above!
