  2. Announcements
  3. 2.0 Discussion: Units, sensor types and protocol
170 Posts 23 Posters 112.6k Views 7 Watching
  • M Offline
    M Offline
    marceloaqno
    Code Contributor
    There is a solution for multi-gateway that I'm working to port it to the development branch which could use the same radio channel and also to have sensors at gateway node.
    A 1 Reply Last reply
    • M marceloaqno
      A Offline
      A Offline
      axillent
      @celonunes what kind of a solution it will be?
      will it be possible to route messages between nodes managed by different gateways?
      sense and drive
      • M Offline
        M Offline
        marceloaqno
        Code Contributor
        Gateway become normal node, with an id(1-254), like a repeater. Address 0 become like a virtual address which is used when a node wants to send a message to the controller.
        This solution will give more redundancy to the network but the same limitations apply, like the max of 254 per network.
        • M Offline
          M Offline
          marceloaqno
          Code Contributor
          #164
          In the case raised by @lunarok, I'm not sure it will fit.
          • M marceloaqno
            A Offline
            A Offline
            axillent
            OK. But how this will prevent conflicts on the air between nodes connected to different gateways and having same radio channel and BASE_ADDRESS?
            sense and drive
            • M Offline
              M Offline
              marceloaqno
              Code Contributor
              Each node will continue to have a unique id in the network.
              The controller would have additional work to map nodes to their proper gateway, and this could make the whole idea into something impracticable depending on the controller software.
              • M marceloaqno
                A Offline
                A Offline
                axillent
                @celonunes will you keep a limit 8 bit for ID?
                currently with multi-gateway setup I have N * 255 address space, where N is a number of gateways
                sense and drive
                M 1 Reply Last reply
                • A axillent
                  M Offline
                  M Offline
                  marceloaqno
                  Code Contributor
                  Yes.
                  Your solution seems interesting, do you have some published code of it?
                  • M marceloaqno
                    Yes.
                    A Offline
                    A Offline
                    axillent
                    @celonunes it is not my solution) it is a way of using 1.4.1 with multiple gateways
                    sense and drive
                    • A axillent
                      M Offline
                      M Offline
                      marceloaqno
                      Code Contributor
                      I'm aware of this.
                      @lunarok your wish may become possible in future developments using MQTT
                      12.1k
