  3. Send message to particular Node
3 Posts 2 Posters 2.6k Views 4 Watching
  • iotcrazyI
    iotcrazyI
    iotcrazy
    I am loving Mysensors libary...great work by the team.
    Here is mt setup:
    1 node set up(with motion sensor) and a gateway. The gateway is connected serially to Rpi and Rpi is running Controller. All works fine.
    1. I want to create another node 2 , which can send message to Node 1 . How to accomplish this ?.
    2. If I include a repeater node , can I see the data that is going through the Repeater Node ? How ?.
    any help is appreciated.
      Example:
      msg.setDestination(1);
      ...send as usual...
      You'll see passing messages if you have enabled debug logs. But you cannot intercept messages (programmatically) through the current api.
      iotcrazyI 1 Reply Last reply
        Example:
        ...send as usual...
        iotcrazyI
        iotcrazyI
        iotcrazy
        @hek Thanks for the quick replay. I will give a try .
