  3. OpenHAB
  4. MQTT gateway works great but drops the connection every 2 mins?
9 Posts 3 Posters 4.9k Views 4 Watching
  • G
    G
    George Whitehouse
    Gday,
    Well I have managed to set up a Mysensors MQTT gateway which I was quite pleased with and have a PIR & distance sensor connected too it and it works!
    When I look to openHAB I noticed that every 2 minutes (almost exactly) the broker connection was lost.
    Is there are setting or reason this would occur? (MQTTlens seems to stay connected ok)
    It is openHAB 1.8 running on a Windows 7 box.
    Has this happened to anyone else? Could someone point me in the right direction with this?
    A grab from the log below.
    Regards,
    George
    2016-02-06 23:31:36.661 [ERROR] [o.i.t.m.i.MqttBrokerConnection] - MQTT connection to broker was lost
    org.eclipse.paho.client.mqttv3.MqttException: Unexpected error
    at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:115) ~[na:na]
    at java.lang.Thread.run(Unknown Source) [na:1.8.0_71]
    2016-02-06 23:31:41.403 [ERROR] [o.i.t.m.i.MqttBrokerConnection] - MQTT connection to 'mysensors' was lost: Unexpected error : ReasonCode 6 : Cause : Unknown
    2016-02-06 23:31:41.403 [INFO ] [o.i.t.m.i.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'mysensors'
    2016-02-06 23:31:51.419 [INFO ] [o.i.t.m.i.MqttBrokerConnection] - Starting MQTT broker connection 'mysensors'
    2016-02-06 23:33:36.663 [ERROR] [o.i.t.m.i.MqttBrokerConnection] - MQTT connection to broker was lost
    2016-02-06 23:33:42.785 [ERROR] [o.i.t.m.i.MqttBrokerConnection] - MQTT connection to 'mysensors' was lost: Unexpected error : ReasonCode 6 : Cause : Unknown
    2016-02-06 23:33:42.786 [INFO ] [o.i.t.m.i.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'mysensors'
    2016-02-06 23:33:52.787 [INFO ] [o.i.t.m.i.MqttBrokerConnection] - Starting MQTT broker connection 'mysensors'
    2016-02-06 23:35:36.661 [ERROR] [o.i.t.m.i.MqttBrokerConnection] - MQTT connection to broker was lost
    2016-02-06 23:35:40.080 [ERROR] [o.i.t.m.i.MqttBrokerConnection] - MQTT connection to 'mysensors' was lost: Unexpected error : ReasonCode 6 : Cause : Unknown
    2016-02-06 23:35:40.080 [INFO ] [o.i.t.m.i.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'mysensors'
    2016-02-06 23:35:50.082 [INFO ] [o.i.t.m.i.MqttBrokerConnection] - Starting MQTT broker connection 'mysensors'
    YveauxY 1 Reply Last reply
    • G George Whitehouse
      Gday,
      Regards,
      George
      YveauxY
      YveauxY
      @George-Whitehouse Probably some default timeout of 2 mins for openHAB connection to the MQTT broker.
      Search your OpenHAB/MQTT broker settings for a default timeout, or enable keep-alive messages.
      G 1 Reply Last reply
      • YveauxY Yveaux
        G
        G
        George Whitehouse
        @Yveaux I initially thought the same thing, I will have another look. But I also have mosquitto running on the same win7 box for OwnTracks and that one seems to stay connected without any drop outs.
        Regards,
        George
          Regards,
          George
          YveauxY
          YveauxY
          @George-Whitehouse The client connecting to Mosquitto passes a keep-alive time during the connection. For pubsubclient (used by MySensors) this is set to 15 seconds. OpenHab should have an identical parameter. Check what it is set to, it might be different from OwnTracks, as it is a different MQTT client.
          • YveauxY Yveaux
            G
            G
            George Whitehouse
            That sounds like it could be the problem, do you happen to know where that setting might be? I had a look in the config file but there does not seem to be a mention there.
            Regards,
            George
              Regards,
              George
              YveauxY
              YveauxY
              @George-Whitehouse I'm not very familiar with OpenHAB. Google is your friend ;-)
              This could be something.
              • YveauxY Yveaux
                G
                G
                George Whitehouse
                @Yveaux Thanks for you help. I was just looking around and saw this article.
                I just cant seem to find any setting in openHAB that can be adjusted for testing.
                Does anyone else run the MQTT gateway with openHAB 1.x have any drop outs?
                Cheers,
                George
                • DerPestD
                  DerPestD
                  DerPest
                  maybe this is related to this issue https://github.com/mysensors/Arduino/issues/389
                  try the mqtt client from development branch.
                  • DerPestD DerPest
                    G
                    G
                    George Whitehouse
                    @DerPest great thanks for that.
                    Yes I will give the MQTT client gateway a try tomorrow.
                    Thanks.
                    Regards,
                    George
