  3. [solved] node can't join gateway (gw using dev branch)
3 Posts 2 Posters 1.2k Views 1 Watching
    MikaelK
    wrote on last edited by MikaelK
    I've setup my gateway yesterday using the development branch so I could put a humidity sensor on it (works great !).
    I now have a small network with the gateway using development branch, and one arduino nano on the master branch also having a humidity sensor.
    Now, I've begun working on a future watermeter with a tcrt-5000 IR Barrier Line Track sensor.
    First step has been to put components (arduino nano + nrf24l01+ + tcrt-5000) on a breadboard and upload sketch. Unfortunately, I can't join the node to the network.
    With the sketch taken from dev branch, I get this on the serial monitor
    Radio init successful.
    send: 2-2-0-0 s=1,c=2,t=24,pt=0,l=0,sg=0,st=fail:
    send: 2-2-0-0 s=255,c=3,t=15,pt=0,l=2,sg=0,st=fail:
    send: 2-2-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=fail:2.0.0-beta
    send: 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=fail:0
    send: 2-2-0-0 s=255,c=3,t=11,pt=0,l=11,sg=0,st=fail:Water Meter
    send: 2-2-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=fail:1.1
    find parent
    send: 2-2-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
    send: 2-2-0-0 s=1,c=0,t=21,pt=0,l=0,sg=0,st=fail:
    Init complete, id=2, parent=0, distance=255
    find parent
    find parent
    When using the sketch from master branch, I get this :
    send: 2-2-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=fail:0
    send: 2-2-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=fail:1.5.4
    sensor started, id=2, parent=0, distance=1
    find parent
    I just remembered having read about some inclusion time and I tried to unplug/plug the gateway to the rpi controller and it worked a bit better :
    send: 2-2-0-0 s=255,c=3,t=11,pt=0,l=11,sg=0,st=ok:Water Meter
    send: 2-2-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
    send: 2-2-0-0 s=1,c=0,t=21,pt=0,l=0,sg=0,st=ok:
    Doing this, Domoticz could detect the hardware : http://snag.gy/kuVGr.jpg
    But I could not find anything in the device tab, which I think is due to the following failed sendings.
    I guess it could be related to the development version but if someone has a suggestion, it would be welcome.
    Regards
    Mikael
    • sundberg84S
      Hi!
      First thing that comes to my attention is all your ,st=fail:
      It might be a range or power issue, do you have caps on your radios?
      Can be a hardware fault with your radio as well
      My guess is that your node is sending, but it doesnt reach the gw
      Have a look at your gw log. Do you see anything there? Probably not?
        MikaelK
        Thanks for the anwser.
        Sorry for the noise, it was some weak soldering issue on the gateway. Worked the whole night, but broke around noon today. It's now fixed and works.
        Mikael
