  3. Where to define RF24 Datarate
12 Posts 3 Posters 6.2k Views 5 Watching
  • D
    D
    DutchMurk
    I am using the developer branch because I switched to the MQTT Client. Becuase I still have longer range connection issues I would like to set the datarate to 250 KBs. I change the setting in MyConfig.h to :
    #define MY_RF24_DATARATE RF24_250KBPS
    But if I look in my debug information I see:
    CONFIG 0x0E
    DYNPD/FEATURE 0x3F 06
    Data Rate 1MBPS
    Model nRF24L01+
    CRC Length 16 bits
    Do I need to define the datarate somewhere else ?
    • Mark SwiftM
      Mark SwiftM
      Mark Swift
      I confirm I see this too...
        Do you print debug information before or after configuration has been set?
        It happens here:
        https://github.com/mysensors/Arduino/blob/a7580d124e7424cb1a19ba0b4649a72a1029d692/libraries/MySensors/core/MyTransportNRF24.cpp#L56
        • Mark SwiftM
          Mark SwiftM
          Mark Swift
          wrote on last edited by Mark Swift
          @hek Excuse the lack of knowledge... I have this at the top of my sketch:
          // #define MY_RADIO_RFM69
          // Set RF24L01 channel number
          #define MY_RF24_CHANNEL 125
          // Define nRF24L01 datarate
          // Enable nRF24L01 debug messages
          #define MY_DEBUG_VERBOSE
            Looks correct. Are you saying it still goes into 1MBS mode?
            • Mark SwiftM
              Mark SwiftM
              Mark Swift
              @hek I see this when the node / gateway is started:
              TATUS 0x0E RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
              RX_ADDR_P0-1 0x0F0F3B3F03 0F0F3B3F03
              RX_ADDR_P2-5 0xFF C4 C5 C6
              TX_ADDR 0x0F0F3B3F0E
              RX_PW_P0-6 0x20 20 20 00 00 00
              EN_AA 0x3B
              EN_RXADDR 0x07
              RF_CH 0x4C
              RF_SETUP 0x07
              CONFIG 0x0E
              Data Rate 1MBPS
              Model nRF24L01+
              CRC Length 16 bits
              PA Power PA_MAX
                Trying to understand where the extended debug prints comes from.
                Did you un-comment this line?
                https://github.com/mysensors/Arduino/blob/a7580d124e7424cb1a19ba0b4649a72a1029d692/libraries/MySensors/core/MyTransportNRF24.cpp#L73
                • Mark SwiftM
                  Mark SwiftM
                  Mark Swift
                  @hek No, I simply added
                  to my sketch?
                    Ok.. found it... printDetails happens here:
                    https://github.com/mysensors/Arduino/blob/a7580d124e7424cb1a19ba0b4649a72a1029d692/libraries/MySensors/drivers/RF24/RF24.cpp#L553
                    This is printed before we set the data-rate to 1MBPS. So I guess everything is ok.
                    Mark SwiftM 1 Reply Last reply
                      Mark SwiftM
                      Mark SwiftM
                      Mark Swift
                      Okay, I'll trust you it's being set to 250 kbps then ;-)
                        You can always uncomment the line I pointed to earlier if you don't believe me ;)
                        • Mark SwiftM
                          Mark SwiftM
                          Mark Swift
                          @hek I did (Not that I don't trust you), and you're right. Go get yourself a beer and pat yourself on the back ;)
                          Now if I could just get my ESP8266 to actually not reply to 50% off messages with st=fail.
                          I've only been trying to get this all working for 3 weeks (sigh).
