  3. Indigo Domotics
  4. Setting up Indigo Plugin and adding sensors
Scheduled Pinned Locked Moved Indigo Domotics
3 Posts 3 Posters 5.0k Views 3 Watching
  • carlschulzC
    carlschulzC
    carlschulz
    Re: Plugin for Indigo for Mac
    @marceltrapman
    Thank you for the indigo plugin. I am new to my sensors .. But have been using indigo for a long time with my Insteon devices. I wanted to extend my capability - so I have added your plugin.
    I have one serial gateway and one remote temperature sensor.
    The two devices seem to be communicating - I have debug turned on. But I cannot seem to add the device to Indico - when I try to define it no available sensors are in the drop down list. Can you help? I really would like to leverage your plugin.
    Carl Schulz
    • R
      R
      rosskinard
      Same here...been out of this whole loop for the past 2 years and trying to get back into it.
      The sensor is sending in the motion tripped signal and all, but like Carl above, the device is blank and the log shows "no type set" when I try to edit the new device.
      Apr 11, 2016, 8:43:39 PM
        MySensors Debug                 receive raw 0;0;3;0;9;read: 0-0-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
        MySensors Debug                 receive raw 0;1;1;0;16;1
        MySensors Debug                 get device N0C1
        MySensors                       received '0:1' motion update to 1
        MySensors Debug                 device 8:255 not available: no type set
      Apr 11, 2016, 8:53:25 PM
      • J
        J
        jfeger
        Are you guys still experiencing this? Make sure you are using 1.5 of the library, as I didn't find any luck with 1.4, 1.6. As a side note, I am refreshing the code Marcel contributed to make 2.0 work with Indigo 7. So far, its not been many changes needed
