  3. can´t upload my sketches anymore!!!
4 Posts 2 Posters 1.4k Views 2 Watching
  • siodS
    siodS
    siod
    aftrer a while I tried to set up some nodes but I have problems to upload code to a new node which I already used in the past successfully. Right now I am using the latest arduino IDE 1.6.7. Here is my code:
    // Simple binary switch example
    // Connect button or door/window reed switch between
    // digitial I/O pin 3 (BUTTON_PIN below) and GND.
    #include <Bounce2.h>
    #define CHILD_ID 1
    #define BUTTON_PIN  8  // Arduino Digital I/O pin for button/reed switch
    Bounce debouncer = Bounce();
    int oldValue=-1;
      gw.begin();
     // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      gw.present(CHILD_ID, S_DOOR);
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
         // Send in the new value
         gw.send(msg.set(value==HIGH ? 1 : 0));
         oldValue = value;
    and here the errors I get:
    WARNING: Category '' in library UIPEthernet is not valid. Setting to 'Uncategorized'
    T:\Programme\Arduino\libraries\MySensors\utility\SPIFlash.cpp:144:9: error: prototype for 'uint8_t SPIFlash::readByte(uint32_t)' does not match any in class 'SPIFlash'
     uint8_t SPIFlash::readByte(uint32_t addr) {
    In file included from T:\Programme\Arduino\libraries\MySensors\utility\SPIFlash.cpp:35:0:
    T:\Programme\Arduino\libraries\SPIFlash/SPIFlash.h:79:11: error: candidate is: uint8_t SPIFlash::readByte(long int)
       uint8_t readByte(long addr);
    T:\Programme\Arduino\libraries\MySensors\utility\SPIFlash.cpp:155:6: error: prototype for 'void SPIFlash::readBytes(uint32_t, void*, uint16_t)' does not match any in class 'SPIFlash'
     void SPIFlash::readBytes(uint32_t addr, void* buf, uint16_t len) {
    T:\Programme\Arduino\libraries\SPIFlash/SPIFlash.h:80:8: error: candidate is: void SPIFlash::readBytes(long int, void*, word)
       void readBytes(long addr, void* buf, word len);
    T:\Programme\Arduino\libraries\MySensors\utility\SPIFlash.cpp:214:6: error: prototype for 'void SPIFlash::writeByte(uint32_t, uint8_t)' does not match any in class 'SPIFlash'
     void SPIFlash::writeByte(uint32_t addr, uint8_t byt) {
    T:\Programme\Arduino\libraries\SPIFlash/SPIFlash.h:81:8: error: candidate is: void SPIFlash::writeByte(long int, uint8_t)
       void writeByte(long addr, uint8_t byt);
    T:\Programme\Arduino\libraries\MySensors\utility\SPIFlash.cpp:228:6: error: prototype for 'void SPIFlash::writeBytes(uint32_t, const void*, uint16_t)' does not match any in class 'SPIFlash'
     void SPIFlash::writeBytes(uint32_t addr, const void* buf, uint16_t len) {
    T:\Programme\Arduino\libraries\SPIFlash/SPIFlash.h:82:8: error: candidate is: void SPIFlash::writeBytes(long int, const void*, uint16_t)
       void writeBytes(long addr, const void* buf, uint16_t len);
    T:\Programme\Arduino\libraries\MySensors\utility\SPIFlash.cpp:263:6: error: prototype for 'void SPIFlash::blockErase4K(uint32_t)' does not match any in class 'SPIFlash'
     void SPIFlash::blockErase4K(uint32_t addr) {
    T:\Programme\Arduino\libraries\SPIFlash/SPIFlash.h:85:8: error: candidate is: void SPIFlash::blockErase4K(long int)
       void blockErase4K(long address);
    T:\Programme\Arduino\libraries\MySensors\utility\SPIFlash.cpp:272:6: error: prototype for 'void SPIFlash::blockErase32K(uint32_t)' does not match any in class 'SPIFlash'
     void SPIFlash::blockErase32K(uint32_t addr) {
    T:\Programme\Arduino\libraries\SPIFlash/SPIFlash.h:86:8: error: candidate is: void SPIFlash::blockErase32K(long int)
       void blockErase32K(long address);
    exit status 1
    Error compiling.
    Invalid library found in T:\Programme\Arduino\libraries\WIZ_Ethernet_Library: T:\Programme\Arduino\libraries\WIZ_Ethernet_Library
    can you help?? Thank you guys!!
    still learning...
    • siodS
      siodS
      siod
      solved, pls close
      still learning...
      • L
        L
        LastSamurai
        wrote on last edited by LastSamurai
        Perhaps you could also add a short description how you solved it before this gets closed. Might safe someone the time later on.
        • siodS
          siodS
          siod
          I had to re-download and reinstall the complete 1.5 library what solved the issue. Don´t know what happened but that helped! Just the quick and dirty way...
          still learning...
