  3. Problem implements MySensors lib
2 Posts 1 Posters 1.2k Views 1 Watching
  • A
    A
    Adam Gliński
    Hi
    I have trable to implement the mysensors lib i try programing DHT 22 on my mini but i cant
    default sketch:
     * Version 1.0 - Henrik EKblad
     * This sketch provides an example how to implement a humidity/temperature
     * sensor using DHT11/DHT-22
    #include <DHT.h>
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
      gw.begin();
      gw.sendSketchInfo("Humidity", "1.0");
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
        Serial.println(temperature);
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
      gw.sleep(SLEEP_TIME); //sleep a bit
    But  i have problem to compilate
    HumiditySensor:39: error: 'MySensor' does not name a type
    HumiditySensor:44: error: 'MyMessage' does not name a type
    HumiditySensor:45: error: 'MyMessage' does not name a type
    HumiditySensor.ino: In function 'void setup()':
    HumiditySensor:50: error: 'gw' was not declared in this scope
    HumiditySensor:57: error: 'S_HUM' was not declared in this scope
    HumiditySensor:58: error: 'S_TEMP' was not declared in this scope
    HumiditySensor.ino: In function 'void loop()':
    HumiditySensor:75: error: 'gw' was not declared in this scope
    HumiditySensor:75: error: 'msgTemp' was not declared in this scope
    HumiditySensor:85: error: 'gw' was not declared in this scope
    HumiditySensor:85: error: 'msgHum' was not declared in this scope
    HumiditySensor:90: error: 'gw' was not declared in this scope
    what i do wrong i add my sensors on MyDocuments/Arduino/libraries
    • A
      A
      Adam Gliński
      close topic
