Dallas sketch does not send temperature
I used the default guide for Dallas temperature sensor and downloaded the librarys from master github.
Communication with the gateway works but sensor does not send the temperature value:(12:36:03.240) req id (12:36:03.250) send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=ok: (12:36:05.250) sensor started, id=255, parent=0, distance=1 (12:36:05.280) req id (12:36:05.280) send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=ok: (12:36:07.280) req id (12:36:07.290) send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=ok: (12:36:09.290) req id (12:36:09.320) send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=ok: (12:36:11.460) 20.50<CR> <---- I have ve added this (12:36:11.460) req id (12:36:11.460) send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=ok:I've added in the sketch Serial.println(temperature); and that works so reading the temp is not an issue it is just not send in the payload part.
I've set COMPARE_TEMP to 0 for testing.I'm on Arduino IDE 1.6.7
Any idea?Best regards
-Alex -
Hi!
Attach a controller to the gateway which gives out id or set a static id in the sketch.
The node is requesting an id and no one is answering. :-)Greetings
Tim -
Aha, so ID is given out by the controller (openHab in my Case)? How can I set the ID static in the sketch?
This is what I get on the gateways serial in the same time:0;0;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
255;255;3;0;3;
255;255;3;0;3;
255;255;3;0;3;
255;255;3;0;3; -
I've added #define MY_NODE_ID 1 in the top area of the sketch but still the same result on sensor serial:
(13:36:29.080) send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=ok: (13:36:31.040) sensor started, id=255, parent=0, distance=1 (13:36:31.080) req id (13:36:31.080) send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=ok: (13:36:33.070) req id (13:36:33.070) send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=ok: (13:36:35.080) req id (13:36:35.080) send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=ok: (13:36:37.220) 21.00<CR> (13:36:37.220) req id (13:36:37.220) send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=ok: -
