  3. Dallas sketch does not send temperature
6 Posts 3 Posters 1.4k Views 3 Watching
  • BiobierB Offline
    BiobierB Offline
    Biobier
    I used the default guide for Dallas temperature sensor and downloaded the librarys from master github.
    Communication with the gateway works but sensor does not send the temperature value:
    (12:36:03.240) req id
    (12:36:03.250) send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=ok:
    (12:36:05.250) sensor started, id=255, parent=0, distance=1
    (12:36:05.280) req id
    (12:36:05.280) send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=ok:
    (12:36:07.280) req id
    (12:36:07.290) send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=ok:
    (12:36:09.290) req id
    (12:36:09.320) send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=ok:
    (12:36:11.460) 20.50<CR> <---- I have ve added this
    (12:36:11.460) req id
    (12:36:11.460) send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=ok:
    I've added in the sketch Serial.println(temperature); and that works so reading the temp is not an issue it is just not send in the payload part.
    I've set COMPARE_TEMP to 0 for testing.
    I'm on Arduino IDE 1.6.7
    Any idea?
    Best regards
    -Alex
    • T Offline
      T Offline
      TimO
      Hi!
      Attach a controller to the gateway which gives out id or set a static id in the sketch.
      The node is requesting an id and no one is answering. :-)
      Greetings
      Tim
      • BiobierB Offline
        BiobierB Offline
        Biobier
        Aha, so ID is given out by the controller (openHab in my Case)? How can I set the ID static in the sketch?
        This is what I get on the gateways serial in the same time:
        0;0;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
        255;255;3;0;3;
        255;255;3;0;3;
        255;255;3;0;3;
        255;255;3;0;3;
        • mfalkviddM Offline
          See http://forum.mysensors.org/topic/3181/how-to-assign-static-node-id/2
          • BiobierB Offline
            BiobierB Offline
            Biobier
            I've added #define MY_NODE_ID 1 in the top area of the sketch but still the same result on sensor serial:
            (13:36:29.080) send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=ok:
            (13:36:31.040) sensor started, id=255, parent=0, distance=1
            (13:36:31.080) req id
            (13:36:31.080) send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=ok:
            (13:36:33.070) req id
            (13:36:33.070) send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=ok:
            (13:36:35.080) req id
            (13:36:35.080) send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=ok:
            (13:36:37.220) 21.00<CR>
            (13:36:37.220) req id
            (13:36:37.220) send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=ok:
            • BiobierB Offline
              BiobierB Offline
              Biobier
              But gw.begin(NULL, 1);
              worked now. Thank you!
              Might be worth to write this somewhere in the guide.
