  3. MyController.org
  4. Gateway status down
Gateway status down
Scheduled Pinned Locked Moved MyController.org
3 Posts 3 Posters 1.8k Views 3 Watching
  • eccleE Offline
    eccleE Offline
    eccle
    Using MySensors I have set up a serial gateway with a NRF24l01 and a distance sensor on a pro mini both are working. I get gateway startup complete on the serial monitor. When I add a gateway in My Controller the status is down. It is Enabled, type is Serial, Network, Type is MySensors, Connection detail is Port:/dev/tty/USB0,Baud rate 115200, Driver Auto. error message unable to open. Do I have to have a specific port
    J 1 Reply Last reply
    • N Offline
      N Offline
      niccodemi
      @eccle Is Mycontroller installed on Linux or Windows system? If Windows, then set port as "COMxx" (xx=number).
      • eccleE eccle
        J Offline
        J Offline
        jkandasa
        Hi in Linux USB-serial port will be something like /dev/ttyUSB* not /dev/tty/USB0. To know available USB-Serial port use this command ls -lh /dev/ttyUSB*
