  3. Vera Edge almost working with serial gateway
1 Posts 1 Posters 985 Views 1 Watching
  • bob.moranB
    bob.moranB
    bob.moran
    I've gotten past "radio init fail" and "device not detected" thanks to the forums but Inclusion still fails.
    Vera Edge 1.7.1707 Arduino Nano NRF24L01+ (tested with TMRh20/RF24 Libray and code)
    Connected to vera UBS with a four port powered usb hub.
    I'm questioning two log messages:
    luup_log:31: Arduino: Incoming internal command '0;0;3;0;2;1.5.4' discarded for child: nil <0x75133520>
    ftdi_sio ttyUSB0: no of_node; not parsing pinctrl DT
    0_1457124009664_upload-e55f4782-c8ae-42e0-9277-8d4893afb161
    0_1457124050905_upload-ee012e58-5d49-45a4-94fa-26d088828d8a
    0_1457124092203_upload-9f346b0b-bd0d-4bd9-96af-8d3fb5a605e8
    In Vera:
    tail -f LuaUPnP.log | egrep "(device: 31|Arduino|USB)"
    //>develop apps >Serial Port Configuration>save
    20785 root 1708 S egrep (device: 31|Arduino|USB)
    17451 root 1708 S /bin/sh -c ser2net -n -C "3481:raw:0:/dev/ttyUSB0:115200 1STOPBIT NONE"
    17452 root 848 S ser2net -n -C 3481 raw 0 /dev/ttyUSB0 115200 1STOPBIT NONE
    [30229.370000] ftdi_sio 1-1.1:1.0: FTDI USB Serial Device converter detected
    [30229.380000] ftdi_sio ttyUSB0: no of_node; not parsing pinctrl DT
    [30229.440000] usb 1-1.1: FTDI USB Serial Device converter now attached to ttyUSB0
    06 03/04/16 10:37:33.551 Device_Variable::m_szValue_set device: 31 service: urn:micasaverde-com:serviceId:HaDevice1 variable: IODeviceXRef was: 37 now: 37 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x77c95320>
    06 03/04/16 10:37:33.551 Device_Variable::m_szValue_set device: 31 service: urn:micasaverde-com:serviceId:HaDevice1 variable: IOPortPath was: /dev/ttyUSB0 now: /dev/ttyUSB0 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x77c95320>
    50 03/04/16 10:37:41.201 luup_log:31: Arduino plugin: loading library L_Arduino ... <0x77533520>
    50 03/04/16 10:37:41.226 luup_log:31: Arduino plugin: library L_Arduino loaded <0x77533520>
    50 03/04/16 10:37:41.226 luup_log:31: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,PluginVersion, 1.5, 31 <0x77533520>
    50 03/04/16 10:37:41.227 luup_log:31: Arduino: Trying for a serial connection <0x77533520>
    50 03/04/16 10:37:41.227 luup_log:31: Arduino: Serial port is connected <0x77533520>
    50 03/04/16 10:37:41.228 luup_log:31: Arduino: Baud is 115200 <0x77533520>
    50 03/04/16 10:37:41.229 luup_log:31: Arduino: Sending: 0;0;3;0;2;Get Version <0x77533520>
    02 03/04/16 10:37:41.236 luup_log:31: Arduino: Incoming internal command '0;0;3;0;2;1.5.4' discarded for child: nil <0x75133520>
    08 03/04/16 10:38:17.741 JobHandler_LuaUPnP::HandleActionRequest device: 31 service:
    //start inclusion.
    urn:upnp-arduino-cc:serviceId:arduino1 action: StartInclusion <0x75533520>
    50 03/04/16 10:38:17.744 luup_log:31: Arduino: Sending: 0;0;3;0;5;1 <0x77c95320>
    50 03/04/16 10:38:17.750 luup_log:31: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,InclusionMode, 1, 31 <0x75133520>
    06 03/04/16 10:38:17.751 Device_Variable::m_szValue_set device: 31 service: urn:upnp-arduino-cc:serviceId:arduino1 variable: InclusionMode was: 0 now: 1 #hooks: 0 upnp: 0 skip: 0 v:0xa18a00/NONE duplicate:0 <0x75133520>
    50 03/04/16 10:38:17.751 luup_log:31: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,InclusionFoundCountHR, 0 devices found, 31 <0x75133520>
    06 03/04/16 10:38:17.752 Device_Variable::m_szValue_set device: 31 service: urn:upnp-arduino-cc:serviceId:arduino1 variable: InclusionFoundCountHR was: now: 0 devices found #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x75133520>
    50 03/04/16 10:39:17.749 luup_log:31: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,InclusionMode, 0, 31 <0x75133520>
    06 03/04/16 10:39:17.750 Device_Variable::m_szValue_set device: 31 service: urn:upnp-arduino-cc:serviceId:arduino1 variable: InclusionMode was: 1 now: 0 #hooks: 0 upnp: 0 skip: 0 v:0xa18a00/NONE duplicate:0 <0x75133520>
    50 03/04/16 10:39:17.754 luup_log:31: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,InclusionFoundCountHR, , 31 <0x75133520>
    06 03/04/16 10:39:17.755 Device_Variable::m_szValue_set device: 31 service: urn:upnp-arduino-cc:serviceId:arduino1 variable: InclusionFoundCountHR was: 0 devices found now: #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x75133520>
    50 03/04/16 10:39:17.756 luup_log:31: Arduino: Inclusion mode ended. <0x75133520>
    //Devices >settings >New Sevice > Restart Engine
    21293 root 1708 S /bin/sh -c ser2net -n -C "3481:raw:0:/dev/ttyUSB0:115200 1STOPBIT NONE"
    21294 root 848 S ser2net -n -C 3481 raw 0 /dev/ttyUSB0 115200 1STOPBIT NONE
    06 03/04/16 10:39:57.975 Device_Variable::m_szValue_set device: 31 service: urn:micasaverde-com:serviceId:HaDevice1 variable: IODeviceXRef was: 37 now: 37 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x77ec4320>
    06 03/04/16 10:39:57.976 Device_Variable::m_szValue_set device: 31 service: urn:micasaverde-com:serviceId:HaDevice1 variable: IOPortPath was: /dev/ttyUSB0 now: /dev/ttyUSB0 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x77ec4320>
    50 03/04/16 10:40:04.201 luup_log:31: Arduino plugin: loading library L_Arduino ... <0x77763520>
    50 03/04/16 10:40:04.226 luup_log:31: Arduino plugin: library L_Arduino loaded <0x77763520>
    50 03/04/16 10:40:04.226 luup_log:31: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,PluginVersion, 1.5, 31 <0x77763520>
    50 03/04/16 10:40:04.227 luup_log:31: Arduino: Trying for a serial connection <0x77763520>
    50 03/04/16 10:40:04.227 luup_log:31: Arduino: Serial port is connected <0x77763520>
    50 03/04/16 10:40:04.228 luup_log:31: Arduino: Baud is 115200 <0x77763520>
    50 03/04/16 10:40:04.229 luup_log:31: Arduino: Sending: 0;0;3;0;2;Get Version <0x77763520>
    02 03/04/16 10:40:04.236 luup_log:31: Arduino: Incoming internal command '0;0;3;0;2;1.5.4' discarded for child: nil <0x75363520>
    root@MiOS_45013463:/tmp/log/cmh# lsusb
    Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    Bus 001 Device 014: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
