  3. to debug or not to debug
4 Posts 3 Posters 1.9k Views 2 Watching
  • B
    B
    boozz
    Hi All,
    Just as question: Does it have a lot of influence if I leave the debug option "on" when I install a (new) node?
    I used to do so (I always leave debug on) but I can imagine it has effect on performance. Or is this irrelevant:flushed:
    BR,
    Boozz
    m26872M 1 Reply Last reply
    • B boozz
      Hi All,
      BR,
      Boozz
      m26872M
      m26872M
      m26872
      @boozz A quick research told me - yes, it could have a lot of influence. Especially when using low buad rate and sending a lot of characters over serial line. Of course there are other ways to debug.
        If you do a lot of screen drawing, play sound or anything that requires precise timing, running with debug might have an effect. But if it did, you would have noticed it when you tested the node. So performance-wise you can probably leave it on.
        However, if your node is battery-powered, having the serial chip active might hurt battery life. Therefore I disable debug before deploying nodes.
        If you add your own debug statements in your sketch, this makes it easy to turn them off (I got the idea from here):
        #ifdef DEBUG
          #define debuglogln(args...) Serial.println(args)
        #else
        #ifdef DEBUG
          Serial.begin(BAUD_RATE);
        debuglogln("hello");
        If you turn DEBUG off, debuglogln will do nothing. If DEBUG is on, all debuglogln statements will work as Serial.println. You can do the same for Serial.print (without ln) if you use that.
        • B
          B
          boozz
          Thank you both for the contributions.
          @mfalkvidd: Thanks a lot for pointing me towards the technique to turn it on /off. This will become very handy in the future for sure.
          BR,
          Boozz
