  3. EasyIoT server - Mysensors Raspberry Pi controller
automationraspberrycontroller
32 Posts 13 Posters 32.6k Views 7 Watching
  • EasyIoTE
    EasyIoTE
    EasyIoT
    New version of EasyIoT server is released. Supported MySensor data types are:
    S_DOOR, V_TRIPPED,
    S_HUM, V_HUM,
    S_TEMP,V_TEMP,
    S_LIGHT and V_LIGHT,
    S_MOTION and V_TRIPPED.
    I_TIME
    S_DIMMER, V_DIMMER, V_LIGHT
    S_LIGHT_LEVEL, V_LIGHT_LEVEL
    S_BARO, V_PRESSURE, V_FORECAST
    We also added automation functions and SMS gateway (control and monitor your network with SMS).
    EasyIoT server download link
    EasyIoT framework http://iot-playground.com
    EasyIoTE 1 Reply Last reply
    • EasyIoTE EasyIoT
      S_DOOR, V_TRIPPED,
      S_HUM, V_HUM,
      S_TEMP,V_TEMP,
      I_TIME
      EasyIoTE
      EasyIoTE
      EasyIoT
      New beta 0_7b1 is out for testing. New MySensor supported data types are:
      S_DISTANCE, V_DISTANCE
      S_DUST, V_DUST_LEVEL
      S_POWER, V_WATT, V_KWH
      S_WATER, V_FLOW, V_VOLUME
      S_UV, V_UV
      S_MOTION, V_TRIPPED - > also supports motion detector
      • A
        A
        aur
        @EasyIoT Does anybody know if there are any basic instructions available on how to installing/using EasyIoT ? I haven't used a Raspberry Pi before.
        The instructions given on MySensors for the Vera controller are really good. Is anything similar available for EasyIoT?
        • A aur
          EasyIoTE
          EasyIoTE
          EasyIoT
          @aur did you check EasyIoT server installation. Just connect NRF24L01 directly to RPI and then download RPI image and put it to SD card. In latest beta you have also support for RPI2.
          • EasyIoTE
            EasyIoTE
            EasyIoT
            wrote on last edited by EasyIoT
            #25
            New version of EasyIoT server V0.7 released. Supported MySesnors data types are:
            S_DOOR, V_TRIPPED Low power door/window sensor,
            S_HUM, V_HUM,
            S_TEMP,V_TEMP,
            I_TIME
            S_UV, V_UV
            You can download latest release at EasyIoT server download
            • H
              H
              hawk_2050
              just been trying out version 0.7 of EasyIoT. I've got my battery powered nodes reporting correctly the temperature sensor value in EasyIoT. They do however also transmit the current battery voltage of the node but so far I haven't seen a way to have EasyIoT report that 'sensor' value. Have I missed something or is this not yet supported?
              Many thanks for your work.
              Cheers
              Richard
              • H hawk_2050
                Cheers
                Richard
                EasyIoTE
                EasyIoTE
                EasyIoT
                @hawk_2050 Battery status is supported. You do not need to configure anything. Just send battery status and it will show in user interface.
                • EasyIoTE EasyIoT
                  EasyIoTE
                  EasyIoTE
                  EasyIoT
                  Just released EasyIoT server beta v0_8b1 with support for MySensors:S_COVER, V_UP, V_STOP, V_DOWN, V_DIMMER.
                  • V
                    V
                    virgus1970
                    Why IOT-server does not supported now by MySensor.org?
                    It was deleted from the list of controllers.
                    • K
                      K
                      kapperi
                      @EasyIoT I was wondering the same thing as @virgus1970
                      I liked EasyIoT because it´s so light and fast to install. But is it really necessary to restrain node discovery to be automatic only, there could be some kind of manual discovery too. I mean that debug shows messages from nodes and there you could get the node id, child_id and message type, as far as I understand thats all that controller needs?
                      One best thing is that radio works directly from rpi and I don´t have to hussle with gateways separately...
                      Unfortunately EasyIoT have a lot of developement to do to be the best controller, there´s a good start to achieve that goal... Domoticz is pretty good too, but it´s way too heavy and slow for me.
                      • H
                        H
                        hyla
                        No luck here ...
                        I've installed EasyIoT V0.8 via SDcard image.
                        The wiring is done as on this page:
                        http://www.instructables.com/id/Low-power-doorwindow-sensor/step2/EasyIoT-server/
                        Now, I can open the EasyIoT webpage, so that part seems to be working. But I can't seem to
                        enable the MySensors Driver. Unlike with other drivers, clicking the "Disable" button will not show
                        additional menue items (like "add nodes"). And clicking the button "won't stick", it's always back to
                        "disable". [B.t.w.: the labelling of the button seems counter intuitive in a way... clicking a "disable" button
                        to enable something doesn't really make sense ;) ]
                        All I did on the Raspi was a sudo apt-get update/upgrade.
                        And in the "MysensorsConfig.xml" I tried to change the channel from 90 to 76, because all my mysensor-
                        sensors are using that (It won't stick either, though. After rebooting the number is back to 90).
                        Apart from that EasyIoT is exactly as it comes on the image.
                        Help, anyone? How can I proceed?
                        B.t.w.: how do You run EasyIoT in the command line manually? I can't start it there, obviously because
                        it's already running ...
                        Thanks,
                        Christoph
                        • msamy.earthM
                          msamy.earthM
                          msamy.earth
                          wrote on last edited by msamy.earth
                          #32
                          @EasyIoT Can you share your implementation for MySensorsDriver?
