  3. Window / motion sensor: noob help on sketc
3 Posts 3 Posters 1.3k Views 2 Watching
  • tenaciousmetalT Offline
    tenaciousmetal
    wrote on last edited by tenaciousmetal
    I've spent many months reading this great forum and i'm ready to build my first project.
    I'm using VeraLite as controller with a serial gateway (USB) and i would like to build a window/motion sensor battery operated (2AA).
    For the sensors I collected all the stuff:
    • list itemArduino Pro mini
    • list item2AA battery holder
    • list itemDC-DC Step up regulator
    • list itemRadio NRF24L01+ (directly linked to the step-up for power)
    • list itemMotion HC SR501 (to PIN2 not used by radio)
    • list itemReed switch
    I hacked the Nano by broking the LED (since i wasn't able to desolder it)
    Now i have some problem with the sketch, since i tried to fuse 2 different sketches (door/window and motion)
    Can someone help me?
    #define SKETCH_NAME "Binary / Motion Sensor"
    #define SKETCH_MAJOR_VER "2"
    #define SKETCH_MINOR_VER "0"
    #define PRIMARY_CHILD_ID 4
    #define PRIMARY_BUTTON_PIN 2   // Arduino Digital I/O pin for button/reed switch
    // initialize motion sensor
    // Initialize motion message
    //initialize window sensor
    MySensor sensor_node;
    MyMessage msg(PRIMARY_CHILD_ID, V_TRIPPED);
      sensor_node.begin();
      // Setup the Window
      pinMode(PRIMARY_BUTTON_PIN, INPUT);
      // Activate internal pull-ups
      digitalWrite(PRIMARY_BUTTON_PIN, HIGH);
      sensor_node.sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VER "." SKETCH_MINOR_VER);
      // Register binary input sensor to sensor_node (they will be created as child devices)
      sensor_node.present(PRIMARY_CHILD_ID, S_DOOR);
      gw.begin();
      gw.present(CHILD_ID, S_MOTION);
      uint8_t value;
      static uint8_t sentValue=2;
      sensor_node.sleep(5);
      value = digitalRead(PRIMARY_BUTTON_PIN);
      if (value != sentValue) {
         // Value has changed from last transmission, send the updated value
         sensor_node.send(msg.set(value==HIGH ? 1 : 0));
         sentValue = value;
    // Read digital motion value
      Serial.println(tripped);
      gw.send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
      // Sleep until something happens with the window sensor
      sensor_node.sleep(PRIMARY_BUTTON_PIN-2, CHANGE, 0);
      // Sleep until motion interrupt comes in on motion sensor. Send update every two minute.
      gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
    A 1 Reply Last reply
    • S Offline
      What is the problem, any error codes or serial output?
      • tenaciousmetalT tenaciousmetal
          // Setup the Window
          gw.begin();
          uint8_t value;
             sentValue = value;
        A Offline
        A Offline
        AWI
        @tenaciousmetal I think something went wrong in combining the two sketches. You are instantiating (defining) two nodes in one sketch. What you should do is have one node, "gw" for example and define two children/sensors. I tried to make some changes in your sketch that should lead you in the right direction. (marked with "AWI", not tested there can be a few syntax errors)
        //initialize window sensor (AWI: don't define the node twice)
        //MySensor sensor_node;
         //sensor_node.begin(); (AWI: define the "gw" node here)
         gw.begin() ;
         // Setup the Window & Activate internal pull-ups
         pinMode(PRIMARY_BUTTON_PIN, INPUT_PULLUP);
         // Activate internal pull-ups (AWI: combined in previous definition)
        // digitalWrite(PRIMARY_BUTTON_PIN, HIGH);
         gw.sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VER "." SKETCH_MINOR_VER);
         gw.present(PRIMARY_CHILD_ID, S_DOOR);
         // gw.begin();  (AWI: no need for another begin)
         uint8_t value;
         gw.sleep(5);
            gw.send(msg.set(value==HIGH ? 1 : 0));
            sentValue = value;
         // Sleep until something happens with the window sensor (AWI: combine with other sleep)
         //sensor_node.sleep(PRIMARY_BUTTON_PIN-2, CHANGE, 0);
         gw.sleep(INTERRUPT, CHANGE, PRIMARY_BUTTON_PIN-2, CHANGE, SLEEP_TIME);
