  3. rfm69 and atc
rfm69 and atc
49 Posts 13 Posters 21.0k Views 12 Watching
  • FleischtorteF Fleischtorte
    @frencho @BenCranston
    This is my implementation of PR440
    first download new RFM69 driver from LowPowerLab https://github.com/LowPowerLab/RFM69/archive/master.zip
    Replace the files from libraries\MySensors\drivers\RFM69 (copy all and replace)
    Change in file RFM69.cpp line 31-32
    #include <RFM69.h>
    #include <RFM69registers.h>
    to
    #include "RFM69.h"
    #include "RFM69registers.h"
    in RFM69_ATC.cpp line 32-34
    #include <RFM69_ATC.h>
    #include <RFM69.h>   // include the RFM69 library files as well
    to
    #include "RFM69_ATC.h"
    #include "RFM69.h"   // include the RFM69 library files as well
    i think this was the driver..
    next was mysensors
    in file libraries/MySensors/MySensor.h line 268
    #include "drivers/RFM69/RFM69_ATC.cpp"
    in file libraries/MySensors/core/MyTransportRFM69.cpp
    first in line 24
    #include "drivers/RFM69/RFM69_ATC.h"
    line 25-26
    RFM69 _radio(MY_RF69_SPI_CS, MY_RF69_IRQ_PIN, MY_RFM69HW, MY_RF69_IRQ_NUM);
    uint8_t _address;
    to
    #ifdef MY_RFM69_Enable_ATC
       RFM69_ATC 	_radio(MY_RF69_SPI_CS, MY_RF69_IRQ_PIN, MY_RFM69HW, MY_RF69_IRQ_NUM);
    #else
    uint8_t _address;
    and line 53 idk if this is necessary
    return _radio.sendWithRetry(to,data,len);
    to
    	return _radio.sendWithRetry(to,data,len,5);
    btw i use not the dev version
    https://github.com/mysensors/MySensors/pull/440 see comment from trlafleur
    there is my testing node (molgan PIR )
     * Version 1.0 - Henrik Ekblad
     * Motion Sensor example using HC-SR501
     * http://www.mysensors.org/build/motion
    // Enable debug prints
    #define MY_NODE_ID 4
    #define MY_RADIO_RFM69
    #define MY_RFM69_FREQUENCY RF69_868MHZ
    #define MY_RFM69_NETWORKID 121
    #define MY_RFM69_ENABLE_ENCRYPTION
    #define MY_RFM69_Enable_ATC
    #define CHILD_ID_RSSI 7 // Id for RSSI Value
    // Initialize motion message
    // Initialize RSSI message
    MyMessage rssiMsg(CHILD_ID_RSSI,V_TEXT);
        _radio.enableAutoPower(-70);
        Serial.println("ATC Aktiviert");
    void presentation()  {
      sendSketchInfo("Molgan-PIR", "1.0");
      present(CHILD_ID, S_DOOR);
      present(CHILD_ID_RSSI, S_INFO);
      // Read digital motion value
      Serial.println(tripped);
      send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
      int var1 = _radio.RSSI;
      send(rssiMsg.set(var1));  // Send RSSI value to gw
      sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
    i hope this helps :) im just learing mysensors & co :expressionless:
    david
    B
    B
    BenCranston
    @Fleischtorte Sweet!! This I can do. I'll make the changes and start testing tonight. thanks for the explicit help.
    -Ben
    frenchoF 1 Reply Last reply
      #include <RFM69.h>
      to
      #include "RFM69.h"
      to
      next was mysensors
      first in line 24
      line 25-26
      uint8_t _address;
      to
      #else
      uint8_t _address;
      to
      david
      frenchoF
      frenchoF
      frencho
      @Fleischtorte
      thanks for the details, I'll look into it, as soon as I have my RFM69 GW talking to my RFM69 node
      Your second life begins when you understand you only have one !
        #include <RFM69.h>
        to
        #include "RFM69.h"
        to
        next was mysensors
        first in line 24
        line 25-26
        uint8_t _address;
        to
        #else
        uint8_t _address;
        to
        david
        frenchoF
        frenchoF
        frencho
        @Fleischtorte is your code example working ? I mean do you see the RSSI going down to -70 ?
        Cause on this page https://lowpowerlab.com/2015/11/11/rfm69_atc-automatic-transmission-control/ Felix says we must use a radio.sendwithretry ?!
        I'm a little confused it not working so I'm digging
        • B BenCranston
          -Ben
          frenchoF
          frenchoF
          frencho
          @BenCranston did you get it to work ?
          • FleischtorteF
            FleischtorteF
            Fleischtorte
            wrote on last edited by Fleischtorte
            #45
            @Frencho radio.sendwithretry is used (see line 53 in libraries/MySensors/core/MyTransportRFM69.cpp) and ATC must be enabled on GW/Node (use _radio.enableAutoPower(-70); only on the node side).
            It seems you need continous traffic to see the effect of ATC (i use a simple relay sketch which reports the rssi with every switch command).
            • nagelcN
              nagelcN
              nagelc
              How is the ATC working out? I think it is a neat feature, but am reluctant to mess with the core MySensors libraries.
              • FleischtorteF
                FleischtorteF
                Fleischtorte
                hi ,
                it works but not very stable... after a while the sensors become offline so i revert to the stable version of MySensors.
                • C
                  C
                  cablesky
                  how is the status now?? Works the ATC now?
                  • scalzS
                    scalzS
                    @cablesky
                    it is not included in Mysensors yet as it breaks compatibility with current packet protocol.
                    It's planned in an upcoming release, and working well ;)
