  3. rfm69 and atc
rfm69 and atc
49 Posts 13 Posters 21.0k Views 12 Watching
  • L
    L
    lafleur
    I have all this working now and have 7 devices on it to a serial gateway...
    Using new RFM69 driver and RFM69_ATC...
    Its interesting to see the power levels change as packets flow...
    If I can figure out how to do a PULL request, I will make it happen to 2.0b development branch...
    tom
    • scalzS
      scalzS
      :thumbsup:
      sorry for delayed answer, a bit busy, I have actually no time to look at/share my experiments :confused:
      I found this interesting too, seeing powerlevels change. btw I didn't finish the listenmode part, I'm on other things for the moment, so that's great if your are doing the job :)
      thx ;)
      • scalzS
        scalzS
        wrote on last edited by scalz
        #23
        hi guys.
        just a little update to say that I'm back on this :blush:
        it's still a wip so I will share/release a bit later ;)
        I have this working in mysensors dev for the moment.
        • I can get rssi value.
        • atc power mode.
        • listenmode : an mqtt esp8266 GW is peridocially waking up a proto node which is in deepsleep (the node is woken up by INT0 triggered by the radio of course). I will mainly use this for sort of remote watchdog for some of my nodes etc..
        • F
          F
          Fabien
          @scalz, good work ! Nice features.
          • alexsh1A
            alexsh1A
            alexsh1
            @scalz As you noticed I have just started with rfm69 and thanks for your help in the other thread. Really looking forward to your work as ATC is something I am missing in MySensors.
            • scalzS
              scalzS
              @alexsh1 : thx. i know i have not pr this yet..it's still working local but have not done extended tests as I'm busy improving mqtt wifi gw..but i will do my best
              • FleischtorteF
                FleischtorteF
                Fleischtorte
                Hi Scalz,
                any progress here? Cant wait to use ATC and the rssi-value for my nodes :D
                Thanks for your work :thumbsup:
                regards
                david
                carlierdC 1 Reply Last reply
                • FleischtorteF Fleischtorte
                  Hi Scalz,
                  regards
                  david
                  carlierdC
                  carlierdC
                  carlierd
                  @Fleischtorte So I am not the only one David waiting for ATC and RSSI ;)
                  David.
                  • FleischtorteF
                    FleischtorteF
                    Fleischtorte
                    @carlierd Yeah Davids FTW :D
                    • frenchoF
                      frenchoF
                      frencho
                      @lafleur @scalz
                      Hi guys,
                      Have one of you succed with the PR, so we can enjoy at least the ATC feature.
                      This is really the down side with the RFM69HW, power consumption so your work could be really helpfull !
                      Really thank you for that
                      Your second life begins when you understand you only have one !
                      L 1 Reply Last reply
                      • frenchoF frencho
                        @lafleur @scalz
                        Hi guys,
                        L
                        L
                        lafleur
                        wrote on last edited by lafleur
                        #31
                        @frencho
                        I have it all working, but my development environment and Jenkins are not in alignment, so my PR was rejected by the development team. They provide me NO help in resolving the issue... They tend to favor and support only the older NRF24L01 radio and have little interests in the newer, better preforming RFM69 or RFM95 radios. So have a look at my code changes in the close PR. It was not hard to implement. I have move on.....
                        frenchoF 1 Reply Last reply
                          wrote on last edited by hek
                          #32
                          @lafleur
                          I'm sorry if your feelings got hurt. But you simply wouldn't do what the team instructed you in PR #440 to get it merged.
                          https://github.com/mysensors/MySensors/pull/440
                          • L lafleur
                            @frencho
                            frenchoF
                            frenchoF
                            frencho
                            Thanks @lafleur, found your PR, I will try to do my own thing based on your work. Shouldn't be a big deal.
                            • L
                              L
                              lafleur
                              I did exactly what you ask, but it continued to fail in building the examples... In another PR, you pointed out that there were issue in building the examples under IDE 1.6.9.
                              My feeling were not hurt, but I did NOT want to wast anymore time in dealing with Jenkins with out guidance.... Also there is NO guide on what Jenkins expect to see in its development environment. it all trial and error...
                              FYI... I have developed RFM95 and TTN transport layers for my snapshot of your code.
                              • scalzS
                                scalzS
                                @frencho @lafleur
                                sorry for this delay. i'm busy, running..sometimes i refresh myself doing some sw but I admit i spent more time on hw than looking how to cleanly do this PR. ouch :sweat: but for me it has to be hobby even if I'm always rushing myself.
                                you're not true ;) in fact mysensors team is not nrf24 only :)
                                as soon as i can, i will look. it could be a bit time consuming as it would be my first PR, why i always delay..boo lazy i am :blush: The best way I think (as, now, I'm not up to date with dev branch, I will need diffchecking my stuff):
                                • I would start/improve PR437 with minor changes needed. As mysensors drivers compiles ok, i would do in this way than taking lowpowerlab lib first (all warnings enabled of course)
                                • then a separated for ATC + or another one for ListenMode. to have a better history and not breaking anything.
                                so, I would separate the PR. I don't know if you tried like this (if i'm overhead), or what were your PR issue. I will look a bit later for curiosity or in case I would run in similar issue hihi.
                                Cool if you have it working :)
                                • FleischtorteF
                                  FleischtorteF
                                  Fleischtorte
                                  @lafleur thanks for your work! On the weekend i was able to upgrade the driver and enable ATC with RSSI-Report. With the instructions from PR440 it was very easy :thumbsup:
                                  • L
                                    L
                                    lafleur
                                    It's great to see that you got it all working from the PR440. I hope others will find your work useful....
                                    I'm my test,it works very well.....
                                    B 1 Reply Last reply
                                      frenchoF
                                      frenchoF
                                      frencho
                                      @Fleischtorte would you accept to share the work ? I started to play with the RFM69, but didn't get to the ATC part yet. It could save me a couple of hours, and debug ^^
                                      • L lafleur
                                        B
                                        B
                                        BenCranston
                                        @lafleur @Fleischtorte @frencho I think I'm a bit dense today. I don't understand where the code currently sits in terms of something that could be tested. I see that PR440 was closed and referenced to go back to PR437 or open a new PR? I'd love to give ATC code a go on my RFM69HW's. Is it being integrated into the development branch? How would I go about testing at this time? I did a quick look at the codebase in git and there is no mention of ATC in the MySensors dev branch... A quick diff of the RFM69.cpp code from Felix and MySensors shows a few differences, so they are not 100% in sync. Alas, I'm at a loss on how to apply the work already done to test.. I can "git clone" like a banshee, but beyond that I'm lost with Jenkins. Sorry, again, dense today...
                                        Any advice on how I can help is appreciated. I can test pretty easily. All of my nodes are Moteino's with RFM69HW radios.
                                        Thanks again for everyone's efforts and work to make ATC a reality in the MySensors codebase!
                                        • FleischtorteF
                                          FleischtorteF
                                          Fleischtorte
                                          wrote on last edited by Fleischtorte
                                          #40
                                          @frencho @BenCranston
                                          This is my implementation of PR440
                                          first download new RFM69 driver from LowPowerLab https://github.com/LowPowerLab/RFM69/archive/master.zip
                                          Replace the files from libraries\MySensors\drivers\RFM69 (copy all and replace)
                                          Change in file RFM69.cpp line 31-32
                                          #include <RFM69.h>
                                          #include <RFM69registers.h>
                                          to
                                          #include "RFM69.h"
                                          #include "RFM69registers.h"
                                          in RFM69_ATC.cpp line 32-34
                                          #include <RFM69_ATC.h>
                                          #include <RFM69.h>   // include the RFM69 library files as well
                                          to
                                          #include "RFM69_ATC.h"
                                          #include "RFM69.h"   // include the RFM69 library files as well
                                          i think this was the driver..
                                          next was mysensors
                                          in file libraries/MySensors/MySensor.h line 268
                                          #include "drivers/RFM69/RFM69_ATC.cpp"
                                          in file libraries/MySensors/core/MyTransportRFM69.cpp
                                          first in line 24
                                          #include "drivers/RFM69/RFM69_ATC.h"
                                          line 25-26
                                          RFM69 _radio(MY_RF69_SPI_CS, MY_RF69_IRQ_PIN, MY_RFM69HW, MY_RF69_IRQ_NUM);
                                          uint8_t _address;
                                          to
                                          #ifdef MY_RFM69_Enable_ATC
                                             RFM69_ATC 	_radio(MY_RF69_SPI_CS, MY_RF69_IRQ_PIN, MY_RFM69HW, MY_RF69_IRQ_NUM);
                                          #else
                                          uint8_t _address;
                                          and line 53 idk if this is necessary
                                          return _radio.sendWithRetry(to,data,len);
                                          to
                                          	return _radio.sendWithRetry(to,data,len,5);
                                          btw i use not the dev version
                                          https://github.com/mysensors/MySensors/pull/440 see comment from trlafleur
                                          there is my testing node (molgan PIR )
                                           * Version 1.0 - Henrik Ekblad
                                           * Motion Sensor example using HC-SR501
                                           * http://www.mysensors.org/build/motion
                                          // Enable debug prints
                                          #define MY_NODE_ID 4
                                          #define MY_RADIO_RFM69
                                          #define MY_RFM69_FREQUENCY RF69_868MHZ
                                          #define MY_RFM69_NETWORKID 121
                                          #define MY_RFM69_ENABLE_ENCRYPTION
                                          #define MY_RFM69_Enable_ATC
                                          #define CHILD_ID_RSSI 7 // Id for RSSI Value
                                          // Initialize motion message
                                          // Initialize RSSI message
                                          MyMessage rssiMsg(CHILD_ID_RSSI,V_TEXT);
                                              _radio.enableAutoPower(-70);
                                              Serial.println("ATC Aktiviert");
                                          void presentation()  {
                                            sendSketchInfo("Molgan-PIR", "1.0");
                                            present(CHILD_ID, S_DOOR);
                                            present(CHILD_ID_RSSI, S_INFO);
                                            // Read digital motion value
                                            Serial.println(tripped);
                                            send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
                                            int var1 = _radio.RSSI;
                                            send(rssiMsg.set(var1));  // Send RSSI value to gw
                                            sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
                                          i hope this helps :) im just learing mysensors & co :expressionless:
                                          david
                                          B frenchoF 3 Replies Last reply
