  3. Local heating override.
1 Posts 1 Posters 2.7k Views 1 Watching
  • H
    H
    Hausner
    wrote on last edited by Hausner
    I need some help.
    I have a Node controlling my floorheating, but now I want to make a "local" override button, incl diode indicating lights.
    My idea is to build it all in a clear plastic housing (so I can see the relay lights). I then thounght about using a tactile button as "override" and some 3mm leds as indicators. Green = Auto, Red = "Manuel" and Blue = Overridden.
    This Is my working scetch on a Nano.
     * Version 1.0 - Henrik Ekblad
    #include <MySigningNone.h>
    #include <MyTransportNRF24.h>
    #include <MyTransportRFM69.h>
    #include <MyHwATMega328.h>
    //MyTransportRFM69 radio;
    //MySigningNone signer;
    MyHwATMega328 hw;
    #define NUMBER_OF_RELAYS 8
    const int RELAY[] = {A0, A1, A2, A3, A4, 6, 7, 8};
    MySensor gw(radio, hw);
      gw.begin(incomingMessage, 12, true, 0);
      gw.sendSketchInfo("Relay", "1.0");
      // Fetch relay status
      for (int sensor=1, pin=0; sensor<=NUMBER_OF_RELAYS;sensor++, pin++) {
        gw.present(sensor, S_LIGHT);
        pinMode(RELAY[pin], OUTPUT);
        digitalWrite(RELAY[pin], gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
      gw.process();
      if (message.type==V_LIGHT) {
         // Change relay state
         digitalWrite(RELAY[message.sensor-1], message.getBool()?RELAY_ON:RELAY_OFF);
         // Store state in eeprom
         // Write some debug info
         Serial.print(message.sensor);
    I need to put in 3 LEDS and a button somewhere. Any help would be appriciated.
