  3. arduino promini 3.3V , out put digital.
7 Posts 5 Posters 4.4k Views 3 Watching
  • R
    R
    Reza
    hi
    if i want use a arduino promini 3.3V for relay , so there is a question!
    the digital output of arduino for relay input (5V relay) is 3.3V !?!?! can this voltag trigger my relay input ?
    • sundberg84S
      @Reza with a 5v relay and without any step-up to 5v - most likley no.
      TheoLT 1 Reply Last reply
      • sundberg84S sundberg84
        TheoLT
        TheoLT
        TheoL
        @sundberg84 Would a logical level converter help? I want to do the same in the near future.
        m26872M 1 Reply Last reply
        • TheoLT TheoL
          m26872M
          m26872M
          m26872
          @TheoL A transistor would do just as good as a level converter since it's only one direction, but nevertheless depend on that you'll have 5V available from somewhere.
          • R
            R
            Reza
            @m26872 , @sundberg84 , @TheoL :
            thank you my friends , so i need increase voltage for digital output <3
            • Mike MusskopfM
              Mike MusskopfM
              Mike Musskopf
              Hi @Reza , there's no need to increase the digital output voltage . You just need to have a 5V source somewhere and you can use a N-MOSFET to drive the relay.
              It would look like that:
              Relay Drive Mosfet
              Just ignore the "INPUT" it should be an OUTPUT on the diagram above. Also the MOSFET needs to have a lower VGs and support the current required by your Relay. Something like that should do the trick: http://au.element14.com/on-semiconductor/ntr4501nt1g/n-channel-mosfet-20v-3-2a-sot/dp/1431305.
              Just avoid the common mosfets like BS170 and BS250 as they need some high voltage on the Gate to actually let the current flow. The datasheet will always have a few charts showing how much current the mosfet let flow for different VGSs.
              Cheers,
              Mike M.
              http://talk2.wisen.com.au
              R 1 Reply Last reply
              • Mike MusskopfM Mike Musskopf
                Relay Drive Mosfet
                Cheers,
                Mike M.
                R
                R
                Reza
                Relay Drive Mosfet
                Cheers,
                Mike M.
                hi
                thank you <3
