  3. Vera
  4. Migrate from Serial Gateway to Ethernet Gateway
3 Posts 2 Posters 1.8k Views 1 Watching
  • J Offline
    J Offline
    jocke4u
    I have ordered some new hardware to start using Ethernet Gateway instead of Serial Gateway.
    So will base the Ethernet GW on Arduino Uno instead of current Nano
    Therefore I wonder if any special actions are needed e.g. if the GW stores any values in EEPROM etc
    1. Assembly the hardware
    2. Load software
    3. Connect to LAN and boot it up
    4. Disconnect Serial GW
    5. Configure Vera3 plugin to use Ethernet GW's IP/Port
    6. Sensors will find the new GW, or??
    • greglG Offline
      greglG Offline
      gregl
      IIRC, thats pretty much what i did... sensors automagically used new ethernet g/w and away it went.
      If anything , reboot Vera to reinit the mysensors plugin. ( i did under 1.3 )
      • J Offline
        J Offline
        jocke4u
        Great, thanks for info :)
        12.1k
