  3. My other PIR multisensor, on coin cell
43 Posts 9 Posters 17.2k Views 16 Watching
  • NeverDieN NeverDie
    @scalz said:
    si2323ds
    SI1869DH is also worth a look as a very nice, general purpose load switch (low volts all the way up to 20v).
    Samuel235
    #21
    @NeverDie said:
    @scalz said:
    si2323ds
    Not sure why my find function never picked this up to be honest. Thank you for point it out to me, much appreciated :)
    Would still like to know if Scalz has this board in working order with the schematic shown.
    MySensors 2.1.1
    • NeverDieN
      NeverDieN
      @scalz
      You may want to take a look at the EX-35R. Its current draw at 3v is just 3.5uA.
      • scalzS
        scalzS
        wrote on last edited by scalz
        #23
        @NeverDie thx. I know this sensor. a bit thick. And I had others goals! thin and compact overall with custom box, I like custom box, you can think your assembly, and it's durable source (stl),
        for sharing some parts, and fun a to z training/challenge :)
        @Samuel235 not yet. I have received pcb some days ago. but I'm missing few values to assemble pir. I delayed a bit my order because I have other board/bom, and try to have free shipping each time ;)
        but I already use p mosfet on other sensors boards and that works nice...
        true, I could have shown you what looks my pcb..so it's white because box will be white and with transparency, I don't want to see the board. But I noticed that each time silkscreen never looks good on white...few ugly things but that will be tiny and thin I think ! I can't wait to assemble it and debug it :)
        • scalzS scalz
          NeverDieN
          NeverDieN
          @scalz
          Is the NodeMCU in the photo just for scale, or does it somehow play a role as well?
          • scalzS
            scalzS
            @NeverDie for scale. and its role is it's bigger than arduio mini, so I cheat :laughing: it's still tiny :)
            • S
              Samuel235
              I love!
              I was reading the other day about using White silkscreen layer on top, and then the names and values where on the top copper layer (being very careful), it gave the effect of pure white and gold plated. It looked beautiful!
              MySensors 2.1.1
              • S
                Samuel235
                @scalz - Could you take 2 minutes to check this MOSFET for me please, do you think this would work in our application? Once i get the board made i will be using the exact one you have, but i need to breadboard all of this together to learn.
                MySensors 2.1.1
                • scalzS
                  scalzS
                  #28
                  @samuel235 I think you don't need a 17amp mosfet.. for breadboarding, you could use the common TO92 BS250 instead. just a thought :)
                  S 1 Reply Last reply
                  • scalzS scalz
                    Samuel235
                    @scalz, i never chose that MOSFET due to its specs, its just the first i came across at the cheapest price available to me. However, i have found this one now and will only have to pay a small shipping fee. http://www.bitsbox.co.uk/index.php?main_page=product_info&products_id=1018
                    MySensors 2.1.1
                    • scalzS scalz
                      NeverDieN
                      NeverDieN
                      #30
                      You're doing a great job, but in my case, I'm currently motivated to move quickly and simply "get it done" and move on. Of course, if your project were already finished, I'd be very much interested in it for possible deployment. However, because it's not finished, I think I'd like to mysensor-enable an existing unit, especially if it works well, has long battery life, and is fairly inexpensive. Also, because motion detectors tend to be visible, having attractive industrial design on the enclosure is not unimportant, and that's hard to accomplish on a DIY basis without turning it into a "project."
                      So, in the meantime, have you run across any other off-the-shelf motion sensors with good battery life? Or, if not, have you found any with good enclosures? If worse came to worst, I could possibly just make use of a COTS enclosure after upgrading the electronics. For instance, I do have an outdoor Optex motion detector with low(ish) energy requirements and which can run on battery and which, by design, leaves space for inserting my own wireless transceiver.
                      • scalzS
                        scalzS
                        #31
                        @Neverdie
                        Thx. yep I understand. Each one his way, no way really better I think, your is nice too ;)
                        And like I said, I am much more interested in complete design. If I would like something complete, I would buy a commercial products for this kind of application or use the ikea molgan for ceiling. And you're right that PIR tends to be visible, but should not be too much visible too..that's why I prefer smaller/thinner box.
                        I'm now working on things which are more expensive to buy..because you can't save big money on this kind of device...
                        That said I have no problem to design my custom box ;) The 3d box for this one is already designed, simple, for a compact 6m lense.
                        I enjoy to use Solidworks to design my custom 3d box (for me it's as addicitive as Eagle). I own a 3d printer and filament is cheap! And I would say I'm luckily well equipped to make all sort of diy :) An electronic lab with a reflow oven and nice tools! And a mecha part, with mini lathe, drill press, tig... and more!
                        So you see not a problem on my side, just the time, but I have to relativise, my iot thing is not so hurry compared to my daily job. I should assemble one very soon now, things are coming. And this design is well know from TI, I have just adapted it a bit, just another alternative ;)
                        NeverDieN 1 Reply Last reply
                        • scalzS scalz
                          @Neverdie
                          NeverDieN
                          NeverDieN
                          #32
                          @scalz
                          I see that Olimex has a version of TI's reference design. Currently $16 on Amazon, with Prme delivery. Coincell powered, small, but no enclosure.
                          TerrenceT 1 Reply Last reply
                          • S
                            Samuel235
                            What board house did you use for this PCB @scalz?
                            MySensors 2.1.1
                            • scalzS
                              scalzS
                              @Samuel235 elecrow.
                              • scalzS scalz
                                @Samuel235 elecrow.
                                Samuel235
                                @scalz Thanks dude!
                                MySensors 2.1.1
                                  @scalz
                                  TerrenceT
                                  TerrenceT
                                  Terrence
                                  wrote on last edited by Terrence
                                  #36
                                  @NeverDie I see that Olimex has a version of TI's reference design. Currently $16 on Amazon, with Prme delivery. Coincell powered, small, but no enclosure.
                                  I have looked on AZ, but can't find this version of TI's ref design. Can you provide a link?
                                  • TerrenceT Terrence
                                    NeverDieN
                                    NeverDieN
                                    @Terrence said in My other PIR multisensor, on coin cell:
                                    That's funny. I thought I had posted the link. Might it have been auto-deleted from my post if it's no longer carried on Amazon?
                                    Anyhow, at present I'm pursuing the AM612 instead.
                                      TerrenceT
                                      TerrenceT
                                      Terrence
                                      #38
                                      @NeverDie I have seen reference to the Olimex version of the TI ref design in the past on other forums, but I have never seen a link to it. I have scoured the web for something that will point me to it. Can you point me in the right direction? Thanks.
                                        NeverDieN
                                        NeverDieN
                                        Here you go: https://www.olimex.com/Products/MSP430/Starter/MSP430-PIR/
                                          TerrenceT
                                          TerrenceT
                                          Terrence
                                          @NeverDie Shows you how good my search was. I think I looked at that, but didn't snap that it had the coin cell on it.
                                          Thanks.
