  3. Reducing number of cpu cycles while sending lots of data
6 Posts 2 Posters 1.7k Views 2 Watching
  • OitzuO
    OitzuO
    Oitzu
    In my nesting-box project i have the case that i need to send a lot of data over the nrf24-link.
    The normal mysensors way of sending the data would be to define a message object outside the sending loop and then set the payload in the loop followed by a send.
    The actual "problem" with this is, that a call to send will each time set the last, sender, destination, version, command and requestack.
    To speed up i declared to methods "prepareSend" which sets all the stuff to the message object and a "send" method that just takes the message object and straight call radio.send.
    Pro: Properties of Message can be set one time -> faster loop
    Contra: Routing changes etc. will have no affect in the loop.
    What do other developers think of this, and is it maybe worthy to also implement it for real?
      I guess it depends... How much difference does this make in real throughput?
      Doesn't the OTA stuff use som sort of stream concept? Maybe that is a good solution for your data as well?
      • OitzuO
        OitzuO
        Oitzu
        My memory says: 5kb/s without modification and arround 20kb/s with modification.
        • OitzuO Oitzu
          Nice. Not fantastic, but a pretty ok speedup.
          OitzuO 1 Reply Last reply
            OitzuO
            OitzuO
            Oitzu
            I don't know about the MYSBootloader 1.3 but the old one was more like a request <-> answer thing of blocks, this is fine but not very fast and not very "streamy" ^^
            Well it was enough to have a reasonable transfer time. There are still more things someone could do to speed things up.
            By example: Disable the auto-ack and send more then 24bytes at a time. (Keeping radio on and send multiple packets)
            But thats all a little bit more complicated with the mysensors lib.
            • OitzuO
              OitzuO
              Oitzu
              Also contra: no signing
