  3. Multiple DHT22 in one sensor for greenhouse (newbee question)
multiple dht22
11 Posts 5 Posters 6.4k Views 4 Watching
  • DickD
    DickD
    Dick
    I try to find out how to create a sensor with 2 DHT22 and, because I am a beginner I do something wrong. Can anybody help me so I can continue with my fisrst MYSENSORS steps.
    Here the script:
    #include <DHT.h>
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_HUM 10
    #define CHILD_ID_TEMP 11
    #define HUMIDITY_SENSOR_DIGITAL_PIN 4
    unsigned long SLEEP_TIME = 3000; // Sleep time between reads (in milliseconds)
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
      gw.begin();
      gw.sendSketchInfo("Humidity", "1.0");
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
        Serial.println(temperature);
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
      gw.sleep(SLEEP_TIME); //sleep a bit
    DickD 1 Reply Last reply
    • DickD Dick
      Here the script:
      #include <DHT.h>
      DHT dht;
      float lastTemp;
      float lastHum;
        gw.begin();
          if (!metric) {
            lastHum = humidity;
      DickD
      DickD
      Dick
      the problem is that I can only see one temp and one humid.
      it is something in the code .
      Here the script:
      #include <DHT.h>
      DHT dht;
      float lastTemp;
      float lastHum;
      gw.begin();
      if (!metric) {
      lastHum = humidity;
      • DickD Dick
        Here the script:
        #include <DHT.h>
        DHT dht;
        float lastTemp;
        float lastHum;
        gw.begin();
        if (!metric) {
        lastHum = humidity;
        BulldogLowellB
        BulldogLowellB
        BulldogLowell
        @Dick
        This (untested) should work to check the temp and humidity:
        #include <DHT.h>
        #define CHILD_ID_HUM1 0
        #define CHILD_ID_HUM2 1
        #define CHILD_ID_TEMP1 3
        #define CHILD_ID_TEMP2 4
        DHT*  dht[2];
        byte sensorPin[2] = {3, 4};
        float lastTemp[2] = {0.0, 0.0};
        float lastHum[2] = {0.0, 0.0};
        //MyMessage msgHum(CHILD_ID_HUM1, V_HUM);
        //MyMessage msgTemp(CHILD_ID_TEMP1, V_TEMP);
          gw.begin();
          for (int i = 0; i < 2; i++)
            dht[i] = new DHT;
            dht[i]->setup(sensorPin[i]);
          gw.present(CHILD_ID_HUM1, S_HUM);
          gw.present(CHILD_ID_HUM2, S_HUM);
          gw.present(CHILD_ID_TEMP1, S_TEMP);
            delay(dht[i]->getMinimumSamplingPeriod());
            float temperature = dht[i]->getTemperature();
              Serial.print(F("Failed reading temperature from DHT"));
              Serial.println(i);
            else if (temperature != lastTemp[i])
              lastTemp[i] = temperature;
              if (!metric)
                temperature = dht[i]->toFahrenheit(temperature);
              //gw.send(msgTemp.set(temperature, i));
              Serial.print(F("T"));
              Serial.print(i);
              Serial.print(F("= "));
            float humidity = dht[i]->getHumidity();
              Serial.print("Failed reading humidity from DHT");
              Serial.println(i);
            else if (humidity != lastHum[i])
              lastHum[i] = humidity;
              //gw.send(msgHum.set(humidity, 1));
              Serial.print(F("H"));
              Serial.print(i);
        if you can test it using the Serial Monitor, we can then get the radio commands working (not complete yet)
          @Dick
          #include <DHT.h>
          DHT*  dht[2];
            gw.begin();
              dht[i] = new DHT;
                Serial.println(i);
                if (!metric)
                Serial.print(i);
                Serial.println(i);
                Serial.print(i);
          DickD
          DickD
          Dick
          @BulldogLowell
          thats fast, I have a lot to learn when I read your code. I tested the code and on the serial it looks fine. As you mentioned already it cannot connect to the gateway. Can you also show me how that goos? I also want to know why you use [i] in your script? can you also advise me where to start to learn the programming language you used? hoop th hear from you soon.languagerhere.
          • DickD Dick
            @BulldogLowell
            BulldogLowellB
            BulldogLowellB
            BulldogLowell
            wrote on last edited by BulldogLowell
            @Dick
            Sorry for the late response...
            I created two instances of the DHT object, using pointers, so that's a little beyond a beginner (but also not hard to do). The [i] is the for-loop index, I put the two sensors into an array to simplify the code (but a little harder for new person to understand).
            My advice is to go through the Arduino learning sections on their websites and search for C++ tutorials on the web, there are many good ones.
            Try this and see if it 1) sets up the two temperature and two humidity devices on your controller and 2) does it transmit the temperatures?
            #include <DHT.h>
            #define NUM_SENSORS 2
            unsigned long SLEEP_TIME = 3000UL; // Sleep time between reads (in milliseconds)
            MyMessage tempMssg(0, V_TEMP);
            MyMessage humMssg(NUM_SENSORS, V_HUM);
            byte tempID[NUM_SENSORS] = {0,1};
            byte humID[NUM_SENSORS] = {2,3};
            DHT* dht[NUM_SENSORS];
            byte sensorPin[NUM_SENSORS] = {3, 4};
            float lastTemp[NUM_SENSORS] = {0.0, 0.0};
            float lastHum[NUM_SENSORS] = {0.0, 0.0};
              Serial.begin(9600);
              gw.begin();
              for (int i = 0; i < NUM_SENSORS; i++)
                dht[i] = new DHT;
                gw.present(tempID[i], S_TEMP);
                gw.present(humID[i], S_HUM);
              Serial.println(F("Setup Complete."));
                  Serial.println(i);
                  if (!metric)
                  gw.send(tempMssg.setSensor(i).set(temperature, false));  // no ack
                  Serial.print(i);
                  Serial.println(i);
                  gw.send(humMssg.setSensor(i).set(humidity, false));  // no ack
                  Serial.print(i);
            I cannot test it but hopefully we can get it working for you.
            DickD turborickT 2 Replies Last reply
              @Dick
              #include <DHT.h>
                Serial.begin(9600);
                gw.begin();
                  dht[i] = new DHT;
                    Serial.println(i);
                    if (!metric)
                    Serial.print(i);
                    Serial.println(i);
                    Serial.print(i);
              DickD
              DickD
              Dick
              @BulldogLowell
              Pls do not sorry for the late response. I found it fast! I am glad that somebody wants to help others. At the moment I am not in the position to test it but believe me Tomorrow evening, after work, it is the first thing I gonna do, ha ha.
              Also thanks for the tips where to start. I have knowlegse of SQL and SQLplus, not of C++ but enough info can be found on the internet. First of all I start with the basics of Arduino. Good begin.
              I let you know about the test results tomorrow.
              Thans again.
              to be continued. Have a nice evening.
              BR.
              Dick
              • DickD
                DickD
                Dick
                At least I was able to test it. The solution worked perfect. Thanks for the support and I continue to finsh my project by implementing it at home. have a nice day. Bests
                Dick
                  @Dick
                  #include <DHT.h>
                    Serial.begin(9600);
                    gw.begin();
                      dht[i] = new DHT;
                        Serial.println(i);
                        if (!metric)
                        Serial.print(i);
                        Serial.println(i);
                        Serial.print(i);
                  turborickT
                  turborickT
                  turborick
                  @BulldogLowell Can this sketch be converted to 2.0.0 ?
                  • turborickT turborick
                    BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    @turborick
                    Sorry, I've yet to upgrade to latest version of MySensors libraries.
                    • R
                      R
                      Rene046
                      This post is deleted!
                      • P
                        P
                        palmerfarmer
                        wrote on last edited by palmerfarmer
                        Is there a way i could display the temp and hum for each sensor on an lcd screen?
                        I know how to do this for data that is not using pointers.
                        below is my sketch that flips between 2 sensors on the LCD
                        /* test modified from a v1 basic mutliple multi dht22 sketch
                            Gives correct temp and humidity readings for each dht22 in domoticz (ie not crossed between 1 and 2)
                            Not displaying properly on the LCD yet
                            Domoticz ver 4.11558 beta
                            Gateway 3.2.1
                            node 3.2.1
                            09/12/2019
                             Arduino Mega
                             1.8 inch TFT LCD Display 128x160 8/16Bit ST7735S
                             x2 DHT22
                             NRF24
                        #define MY_RADIO_NRF24    //Mega Pins 49 CE, 53 CSN/CS, 52 SCK, 51  MOSI, 50  MISO
                        #define MY_RF24_CE_PIN 49
                        #define MY_RF24_CS_PIN 53
                        #define MY_RF24_PA_LEVEL (RF24_PA_MIN)
                        #define MY_NODE_ID 103
                        #include <UTFT.h>          //LCD 1.8
                        #include <DHT.h>
                        #define RELAY1 44
                        #define RELAY2 45
                        //static const uint8_t FORCE_UPDATE_N_READS = 10;
                        extern uint8_t BigFont[];
                        extern uint8_t SmallFont[];
                        unsigned long SLEEP_TIME = 6000; // Sleep time between reads (in milliseconds)
                        //MySensor gw;
                        byte tempID[NUM_SENSORS] = {0, 1};
                        byte humID[NUM_SENSORS] = {2, 3};
                        byte sensorPin[NUM_SENSORS] = {40, 42};
                        //LCD setup
                        UTFT myGLCD(ITDB18SP, 11, 12, 8, 9, 10); // lcd pins 3,2,6,5,4
                          myGLCD.InitLCD(LANDSCAPE);// or PORTRAIT
                          myGLCD.clrScr();
                          myGLCD.setColor(200, 255, 255);
                          myGLCD.setBackColor(0, 0, 0);
                          myGLCD.setFont(SmallFont);
                          myGLCD.print("Version & Sketch", LEFT, 3);
                          myGLCD.print("V.2 TEST5", LEFT, 16);
                          delay(1000);
                          myGLCD.clrScr();
                          myGLCD.setColor(255, 255, 255);
                          myGLCD.print("TH1 OUTSIDE", 2, 2);
                          myGLCD.print("o", 67, 12);
                          myGLCD.print("C", 74, 15);
                          myGLCD.print("%", 150, 15);
                          myGLCD.print("TH2 INSIDE", 2, 36);
                          myGLCD.print("o", 67, 46);
                          myGLCD.print("C", 74, 49);
                          myGLCD.print("%", 150, 49);
                          Serial.begin(9600);
                          // begin();
                            dht[i] = new DHT;
                          sendSketchInfo("DHT22 Humidity test5", "2.0");
                              Serial.println(i);
                              if (!metric)
                              Serial.print(i);
                            myGLCD.setFont(BigFont);
                            myGLCD.setColor(100, 255, 255);
                            myGLCD.printNumF(temperature, 1, 1, 15);  // this where something needs to be changed to get it to display each temp separately
                              Serial.println(i);
                              Serial.print(i);
                              Serial.println(humidity); // this where something needs to be changed to get it to display each hum separately
                              myGLCD.printNumF(humidity, 1, 85, 15);
