  3. My New IrrigationController
23 Posts 6 Posters 12.8k Views 10 Watching
  • karl261K karl261
    @marekd Great controller! For the keypad: I see from the code that you use the I2C code. How did you connect your keypad? Did you use a I2C extension chip? And, which keypad_i2c library do you use? I found multiple on the net.
    Thanks!
    marekdM
    marekdM
    marekd
    @karl261
    Thanks,
    in case I2C yes, and no.
    with 1st generation [with 1 ProMini] I used I2C port expander PCF8574.
    with 2nd generation [with MEGA2560] just pins, 8 pins, declared like this:
    /**** Kepad settings /
    const byte ROWS = 4;
    const byte COLS = 4;
    char keys[ROWS][COLS] = {
    {'1', '2', '3', 'A'},
    {'4', '5', '6', 'B'},
    {'7', '8', '9', 'C'},
    ', '0', '#', 'D'}
    byte rowPins[ROWS] = {47, 45, 43, 41};
    byte colPins[COLS] = {39, 37, 35, 33};
    int i2caddress = 0x20;
    Keypad_I2C kpd = Keypad_I2C( makeKeymap(keys), rowPins, colPins, ROWS, COLS, i2caddress );
    with 3rd generation - plan to have 2nd ProMini with PCF expander.
    attached library I use.
    0_1474294070076_Keypad_I2C.zip
    and some pictures of generation 3, which is under construct :)
    Power supply:
    and control box with 2 ProMinis:
    karl261K 1 Reply Last reply
    • marekdM marekd
      @karl261
      Thanks,
      ', '0', '#', 'D'}
      Power supply:
      karl261K
      karl261K
      karl261
      @marekd Thanks for the detailed reply. What the monster capacitor for in gen 3?
      I plan to build my keypad with one pro mini and the PCF8574. Like your gen 1 & 3. How did / are you planning to wire the PCF8574? It seems rather straight forward according to this:
      https://www.hackster.io/venkatesh_rao/i2c-keypad-73a012
      Is this the wiring you are using? Or is it different?
      Since I am building a battery keypad, I was also planning to use the interrupt line of the PCF8574.
      marekdM 1 Reply Last reply
      • karl261K karl261
        marekdM
        marekdM
        marekd
        @karl261
        Capacitor is not so big ;) generally helps.
        I my wiring there is no pull-up resistors at I2C lines. Rest is the same.
