  3. My New IrrigationController
23 Posts 6 Posters 12.6k Views 10 Watching
  • marekdM
    marekdM
    marekd
    Last summer during vacation, was quite hot at my place. My green grass in the garden became ... brown and yellow - there was nobody to irrigate and was no rain, of course!
    So I made a decision to buy irrigation controller and all that stuff. I wanted to have 7-8 zones, BT or wireless control, temperature and rain based control, RTC, Keypad, etc. The problem was that nobody had it or was to expencive.
    So long story short I came up with idea to build one with all those features i need. Without having experience with uC I start to learn (google and youtube) a bit and build some "prototypes". Than IrrigatonController ver 1.0 was ready (December 2015):0_1462825721811_1.jpg
    Than I found @petewill IrrigationControler at youtube - but it was to hard for me from software (all this MySensors) and hardware side - I thought!
    So I built new one - well it is almost done.
    It is tested and working, few things are still missing like running without HA controller and rain sensor. Anyway I post some pictures and script what I've done. At my place it is working under Domoticz and manual (keypad). Tomorrow final wiring!
    0_1462826941290_IMG_20160509_203348.jpg .
    Any comments are more than welcome, know that script need some more work - but it is just a beginning.
     * based on Version 1.0 - Henrik Ekblad
     * Version 2.0 - Marek Dajnowicz
    #define MY_RF24_CE_PIN A8 // żółty 51
    #define MY_RF24_CS_PIN A9 // pomarańczowy 53
    #define MY_NODE_ID 66
    #define MY_REPEATER_FEATURE
    #include <Wire.h>
    #include <Time.h>
    #include <LiquidCrystal.h>
    #include <OneWire.h>
    #include <DS3232RTC.h>  // A  DS3231/DS3232 library
    #include <Keypad_I2C.h> // Klawiatura na I2c
    #include <Keypad.h> // klawiatura
    #define RELAY_1  2  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define NUMBER_OF_RELAYS 8 // Total number of attached relays
    #define ONE_WIRE_BUS 22 // Pin where dallase sensor is connected MEGA256
    #define TEMPERATURE_PRECISION 12
    #define CHILD_ID_SPRINKLER1 1
    #define CHILD_ID_SPRINKLER2 2
    #define CHILD_ID_SPRINKLER3 3
    #define CHILD_ID_SPRINKLER4 4
    #define CHILD_ID_SPRINKLER5 5
    #define CHILD_ID_SPRINKLER6 6
    #define CHILD_ID_SPRINKLER7 7
    #define CHILD_ID_PUMP 10
    #define CHILD_ID_TEMP 11
    #define CHILD_ID_TEMP2 12
    boolean timeReceived = false;
    byte clock[8] = {0x0, 0xe, 0x15, 0x17, 0x11, 0xe, 0x0}; // fetching time indicator
    byte raindrop[8] = {0x4, 0x4, 0xA, 0xA, 0x11, 0xE, 0x0,}; // fetching Valve Data indicator
    LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
    DeviceAddress addrT1 = { 0x28, 0xFF, 0x9F, 0x80, 0x93, 0x15, 0x04, 0xF7 }; //DS18 Dallas temp.
    float T1;
    int numSensors = 0;
    MyMessage msgValve1(CHILD_ID_SPRINKLER1, V_LIGHT);
    MyMessage msgValve2(CHILD_ID_SPRINKLER2, V_LIGHT);
    MyMessage msgValve3(CHILD_ID_SPRINKLER3, V_LIGHT);
    MyMessage msgValve4(CHILD_ID_SPRINKLER4, V_LIGHT);
    MyMessage msgValve5(CHILD_ID_SPRINKLER5, V_LIGHT);
    MyMessage msgValve6(CHILD_ID_SPRINKLER6, V_LIGHT);
    MyMessage msgValve7(CHILD_ID_SPRINKLER7, V_LIGHT);
    MyMessage msgPump(CHILD_ID_PUMP, V_LIGHT);
    MyMessage msgT1(CHILD_ID_TEMP, V_TEMP);
    MyMessage msgT2(CHILD_ID_TEMP2, V_TEMP);
    /**** Kepad settings */
    const byte ROWS = 4;
    const byte COLS = 4;
    char keys[ROWS][COLS] = {
      {'1', '2', '3', 'A'},
      {'4', '5', '6', 'B'},
      {'7', '8', '9', 'C'},
      {'*', '0', '#', 'D'}
    byte rowPins[ROWS] = {47, 45, 43, 41};
    byte colPins[COLS] = {39, 37, 35, 33};
    int i2caddress = 0x20;
    Keypad_I2C kpd = Keypad_I2C( makeKeymap(keys), rowPins, colPins, ROWS, COLS, i2caddress );
    bool state;
    // system messages
    const char *string_table[] =
      "     WELCOME! =)", 			// 0
      "DOMOTICZ TIME", 				// 1
      "WATERING",  					// 2
      "    SYSTEM CHECK  ",			// 3
      "  STARTING UP THE",			// 4
      "  WATERING SYSTEM", 			// 5
      "    Popmp is ON ", 		    // 6
      "      MySensors",		   	// 7
      "   Watering System",	      	// 8
      "   Please wait !!"	        // 9
    const char *string_table2[] = {
      "Strefa 1", "Strefa 2", "Strefa 3", "Strefa 4", "Strefa 5", "Strefa 6", "Strefa 7", "Pompa zasilająca" // ZONE 1...2...
    const unsigned long tUpdate = 60000; // update interval for temp sensors
    unsigned long t0;
      for (int sensor = 1, pin = RELAY_1; sensor <= NUMBER_OF_RELAYS; sensor++, pin++)
        pinMode(pin, OUTPUT); // Then set relay pins in output mode
        digitalWrite(pin, RELAY_OFF); // set all relays OFF
        saveState(sensor, state); // save data at startup.
      requestTime();
      kpd.begin();  //keypad
      sensors.begin(); //dallas temp
      sensors.setResolution(addrT1, TEMPERATURE_PRECISION);
      lcd.begin(20, 4); //(20 characters and 4 line display)
      lcd.clear();
      lcd.backlight();
      lcd.createChar(0, clock);
      lcd.createChar(1, raindrop);
      lcd.home();
      lcd.print(string_table[4]);
      lcd.setCursor(0, 1);
      lcd.print(string_table[5]);
      lcd.setCursor(0, 3);
      lcd.print(string_table[7]);
      delay(3000);
      for (int i = 0; i < 20; i++) {
        delay(100);
        lcd.scrollDisplayLeft();
      lcd.clear();
      lcd.home();
      lcd.print(string_table[0]);
      lcd.print(string_table[3]);
      (lcd.setCursor(0, 3));
      for (int M = 1; M >= 0; M--) // countdown
        lcd.setCursor(10, 3);
        lcd.print(M);
        delay(1000);
      lcd.clear();
      lcd.home ();
      requestTime();
      ServerUpdate();
      sendSketchInfo("Watering", "2.0");
      for (int sensor = 1, pin = RELAY_1; sensor <= NUMBER_OF_RELAYS; sensor++, pin++) {
        present(sensor, S_LIGHT, string_table2[sensor - 1]); // use CHILD ID names from table
      present(CHILD_ID_TEMP, S_TEMP,"Dallas");
      present(CHILD_ID_TEMP2, S_TEMP,"RTC Temp");
      domoticztime(); // to PRINT the time from conroller
      keypad(); // READING KEYPAD
      if ((millis() - t0) > tUpdate) ServerUpdate();
    void ServerUpdate()
      T1 = sensors.getTempC(addrT1);
      send(msgT1.set(T1 , 1));
      int t= RTC.temperature()/4;
      send(msgT2.set(t,2));
      lcd.setCursor(11, 2);
      lcd.print("T:");
      lcd.print(T1);
      lcd.print(char(223));
      lcd.print("C");
      lcd.setCursor(11, 3);
      lcd.print("T:");
      lcd.print(t);
      lcd.print("C");
      t0 = millis();
    void domoticztime()
      lcd.home();
      lcd.setCursor(0, 2);
     // lcd.print(string_table[1]);
      //lcd.setCursor(2, 2);
      lcd.write(byte(0));
      lcd.setCursor(1, 2);
      lcd.print(hour());
      lcd.print(":");
      int min = minute();
      if (min < 10) lcd.print("0");
      lcd.print(minute());
      lcd.print(":");
      lcd.print(second());
      lcd.print(day());
      lcd.print("/");
      lcd.print(month());
      lcd.print("/");
      lcd.print(year());
    void keypad()
      char key = kpd.getKey(); delay(50);
      if (key == '*') ALL_OFF();
      if (key == '#') WRONG();
      if (key == '1') ZONE_1();
      if (key == '2') ZONE_2();
      if (key == '3') ZONE_3();
      if (key == '4') ZONE_4();
      if (key == '5') ZONE_5();
      if (key == '6') ZONE_6();
      if (key == '7') ZONE_7();
      if (key == '8') WRONG();
      if (key == '9') WRONG();
      if (key == '0') WRONG();
      if (key == 'D') DEBUG();
    void DEBUG()
    {for (int sensor = 1, pin = RELAY_1; sensor <= NUMBER_OF_RELAYS; sensor++, pin++)
        state = loadState(sensor);
        Serial.print("sensor: ");
        Serial.print(sensor);
        Serial.print("  /  stan:  ");
        Serial.println(state);
    void ALL_OFF()// TURNING ALL ZONES OFF @ ONE KEY PRESSED
      lcd.clear();
      lcd.print(" TURN ALL ZONES OFF");
      Serial.println(" turn ALL OFF");
      send(msgValve1.set(0) );delay(100);
      send(msgValve2.set(0) );delay(100);
      send(msgValve3.set(0) );delay(100);
      send(msgValve4.set(0) );delay(100);
      send(msgValve5.set(0) );delay(100);
      send(msgValve6.set(0) );delay(100);
      send(msgValve7.set(0) );
      send(msgValve1.set(0), true); delay(100);
      send(msgValve2.set(0), true);delay(100);
      send(msgValve3.set(0), true);delay(100);
      send(msgValve4.set(0), true);delay(100);
      send(msgValve5.set(0), true);delay(100);
      send(msgValve6.set(0), true);delay(100);
      send(msgValve7.set(0), true);
      DEBUG();
      delay(1500);
      lcd.clear();
    void ZONE_1()
    { // zone 1, pin 2
      byte pin=RELAY_1;
      state = loadState(CHILD_ID_SPRINKLER1);
      digitalWrite(pin, state ? RELAY_ON : RELAY_OFF);
      saveState(CHILD_ID_SPRINKLER1, state);
      if (state == 1)
        lcd.print(" ");
      send(msgValve1.set(state ? false : true), true);
    void ZONE_2()
      byte pin=RELAY_1+1;
      state = loadState(CHILD_ID_SPRINKLER2);
      saveState(CHILD_ID_SPRINKLER2, state);
     if (state == 1)
        lcd.setCursor(1, 1);
        lcd.print(" ");
      send(msgValve2.set(state ? false : true), true);
    void ZONE_3()
    byte pin=RELAY_1+2;
      state = loadState(CHILD_ID_SPRINKLER3);
      saveState(CHILD_ID_SPRINKLER3, state);
      if (state == 1)
        lcd.setCursor(2, 1);
        lcd.print(" ");
      send(msgValve3.set(state ? false : true), true);
    void ZONE_4()
    byte pin=RELAY_1+3;
      state = loadState(CHILD_ID_SPRINKLER4);
      saveState(CHILD_ID_SPRINKLER4, state);
      if (state == 1)
        lcd.setCursor(3, 1);
        lcd.print(" ");
      send(msgValve4.set(state ? false : true), true);
    void ZONE_5()
    byte pin=RELAY_1+4;
      state = loadState(CHILD_ID_SPRINKLER5);
      saveState(CHILD_ID_SPRINKLER5, state);
      if (state == 1)
        lcd.setCursor(4, 1);
        lcd.print(" ");
      send(msgValve5.set(state ? false : true), true);
    void ZONE_6()
    byte pin=RELAY_1+5;
      state = loadState(CHILD_ID_SPRINKLER6);
      saveState(CHILD_ID_SPRINKLER6, state);
      if (state == 1)
        lcd.setCursor(5, 1);
        lcd.print(" ");
      send(msgValve6.set(state ? false : true), true);
    void ZONE_7()
    byte pin=RELAY_1+6;
      state = loadState(CHILD_ID_SPRINKLER7);
      saveState(CHILD_ID_SPRINKLER7, state);
      if (state == 1)
        lcd.setCursor(6, 1);
        lcd.print(" ");
      send(msgValve7.set(state ? false : true), true);
    void WRONG() {}
      byte zone;
      if (message.isAck()) {
        // Change relay state
        digitalWrite(message.sensor - 1 + RELAY_1, message.getBool() ? RELAY_ON : RELAY_OFF);
        zone = message.sensor; // less typing :)
        // Store state in eeprom
        // representing active zones at LCD
        if (message.getBool() == RELAY_ON) // checking new state of relay
          Serial.print("Watering ZONE: "); Serial.println(zone);
          lcd.setCursor(0, 0);
          lcd.print("Watering ZONE: ");
          lcd.setCursor(zone - 1, 1);
          lcd.print(zone);
        if (message.getBool() == RELAY_OFF) // checking new state of relay
          lcd.print(" ");
           // Write some debug info
        Serial.print("Incoming change for ZONE:");
        Serial.print(message.sensor);
    Regards
    karl261K 1 Reply Last reply
    • epierreE
      epierreE
      epierre
      wrote on last edited by epierre
      What have you used on the hardware side ?
      The OpenSprinkler project is interresting as it is designed to run on arduino with some interresting logic such as EvapoTranspiration or the "Mr Zimmermann" method.
      https://github.com/rayshobby/opensprinkler
      It would be interresting to have it running on your domotiz platform and connect the remotes valves through mysensors ;-)
      //and maintaining grass is more a problem than a solution, too many time and water wasted on it... (not talking of polluants...)
      z-wave - Vera -> Domoticz
      marekdM 1 Reply Last reply
      • epierreE epierre
        marekdM
        marekdM
        marekd
        @epierre
        Hi there!
        Hardware (main):
        Adruino MEGA256 - Nano and ProMini was to small with memory.
        DS3231 - for RTC and temperature inside the box
        LCD 4x20 I2C
        Power supply 12V & 5V 2A each - part is from my "old" external HDD
        NRF24L01+PA+LNA + Socket Adapter plate Board f 8Pin NRF24L01+
        http://www.ebay.com/itm/311574056137?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
        Keypad 4x4
        DS18 for temp - had DHT11 but mixed + & - and got burned down ;)
        5V 8-Channel Relay Module With Optocoupler Low Level Triger
        24V Transformer with DIN mounting
        The most expensive single part was the BOX :)
        I've visited before OpenSprinkler and this is a pretty nice project!
        m26872M 1 Reply Last reply
        • marekdM marekd
          @epierre
          Hi there!
          Hardware (main):
          LCD 4x20 I2C
          Keypad 4x4
          m26872M
          m26872M
          m26872
          @marekd Great project and thx for the share! Are you sure you can't squeeze the sketch into a Nano or ProMini by using PROGMEM and F-macro? I did it like that in this example.
          • m26872M m26872
            marekdM
            marekdM
            marekd
            @m26872
            Thanks!
            You can squeeze, but I wanted to have more options and not to be limited by memory - anyway at this stage of developing. Because normally you have only one sprinkler controller you can use better uC - I did this way. Playing with more advance programming for memory optimization - is not for me (at this stage of my knowledge) - but thanks for this hint , I might use it in future.
            I was reading your post about 2AA battery node... this is my let's say next step to make.
            epierreE 1 Reply Last reply
            • marekdM marekd
              @m26872
              Thanks!
              epierreE
              epierreE
              epierre
              @marekd said:
              @m26872
              Thanks!
              on the OsPi hardware, both Arduino/PI (depending on installation) are powered from 24V AC for the sprinkler valves
              • epierreE epierre
                @marekd said:
                @m26872
                Thanks!
                marekdM
                marekdM
                marekd
                @epierre
                could you explain? I did't understand our thoughts.
                • epierreE
                  epierreE
                  epierre
                  @mareked you could power everything only from the 24V AC as they do !
                  marekdM 2 Replies Last reply
                  • epierreE epierre
                    marekdM
                    marekdM
                    marekd
                    @epierre I never thought about it - but you are right! Got some LM7805 and Graetz bride (or 1N4004's)... must think about. I could save some space and additional power supply.
                    Thank YOU!
                    • epierreE epierre
                      marekdM
                      marekdM
                      marekd
                      but going form ~22V DC to 5V makes a lot lot lot of heat! any idea how to avoid this issue?
                      • epierreE
                        epierreE
                        epierre
                        check ospi they have published their BOM
                        • epierreE epierre
                          marekdM
                          marekdM
                          marekd
                          @epierre
                          power supply unit with LM2596 is rather complicated to build and needs parts which I don't have. I could, of course, buy step down module for around 1-2$. Maybe I'll come back to this solution after this watering season - now is is to late for this. Thanks anyway!
                          • marekdM
                            marekdM
                            marekd
                            Finally I launched my Irrigation System, there are some small bugs in the code, but can live with it - for now. Have plans how to rebuild this in winter time to be more robust and to look better.
                            Runs under Domoticz and manually with keypad.
                            For now it looks like this:
                            • epierreE epierre
                              marekdM
                              marekdM
                              marekd
                              @epierre
                              Started to play with LM2596, I've got sth. like this:
                              http://www.ebay.com/itm/1pcs-1-23V-30V-DC-DC-Buck-Converter-Step-Down-Module-LM2596-Power-Supply-Output-/400985220074?hash=item5d5c94e3ea:g:o10AAOxy0x1TVSpD
                              Added diode bridge between transformer and this converter. But my concern is that I've some big voltage peaks the the output of it. It happens when I'm opening/closing valves (AC solenoids) connected to this transformer.
                              Set this converter to 12V DC but my readings are sometimes around 20V DC and I am affraid that I could destroy by Arduino.
                              Do you (anyone) have any suggestion ?
                              • gbgent_ncG
                                gbgent_ncG
                                gbgent_nc
                                @marekd
                                Just wondering, could you not set your zones up as an array. This would reduce the size a little and should also free up memory for variables.
                                • gbgent_ncG gbgent_nc
                                  @marekd
                                  marekdM
                                  marekdM
                                  marekd
                                  @gbgent_nc
                                  Yes I could and did already because have to use ProMini [my MEGA2560 was killed ;) ].
                                  Anyway plan is now to use 2xProMini., one for LCD, Keyboard, relays and second for temperature x2, water meter, rain sensor and relay for pump.
                                  • fetsF
                                    fetsF
                                    fets
                                    @marekd could you give us a link to your walves.
                                    • fetsF fets
                                      marekdM
                                      marekdM
                                      marekd
                                      @fets
                                      Manufacturer is RAIN S.p.a Italy, www.rain.it.
                                      Model I use is RN150.
                                      Got them from Leroy Merlin, price was around 11 EUR.
                                      fetsF 1 Reply Last reply
                                      • marekdM marekd
                                        @fets
                                        fetsF
                                        fetsF
                                        fets
                                        @marekd thanks
                                        • marekdM marekd
                                          #include <Wire.h>
                                          #include <Time.h>
                                          float T1;
                                          int numSensors = 0;
                                          bool state;
                                          // system messages
                                            "WATERING",  					// 2
                                            "      MySensors",		   	// 7
                                          unsigned long t0;
                                            requestTime();
                                            lcd.clear();
                                            lcd.backlight();
                                            lcd.home();
                                            delay(3000);
                                              delay(100);
                                            lcd.clear();
                                            lcd.home();
                                              lcd.print(M);
                                              delay(1000);
                                            lcd.clear();
                                            lcd.home ();
                                            requestTime();
                                            ServerUpdate();
                                          void ServerUpdate()
                                            lcd.print("T:");
                                            lcd.print(T1);
                                            lcd.print("C");
                                            lcd.print("T:");
                                            lcd.print(t);
                                            lcd.print("C");
                                            t0 = millis();
                                          void domoticztime()
                                            lcd.home();
                                            lcd.write(byte(0));
                                            lcd.print(hour());
                                            lcd.print(":");
                                            int min = minute();
                                            lcd.print(":");
                                            lcd.print(day());
                                            lcd.print("/");
                                            lcd.print(month());
                                            lcd.print("/");
                                            lcd.print(year());
                                          void keypad()
                                          void DEBUG()
                                            lcd.clear();
                                            DEBUG();
                                            delay(1500);
                                            lcd.clear();
                                          void ZONE_1()
                                          { // zone 1, pin 2
                                            byte pin=RELAY_1;
                                            if (state == 1)
                                              lcd.print(" ");
                                          void ZONE_2()
                                            byte pin=RELAY_1+1;
                                           if (state == 1)
                                              lcd.print(" ");
                                          void ZONE_3()
                                          byte pin=RELAY_1+2;
                                            if (state == 1)
                                              lcd.print(" ");
                                          void ZONE_4()
                                          byte pin=RELAY_1+3;
                                            if (state == 1)
                                              lcd.print(" ");
                                          void ZONE_5()
                                          byte pin=RELAY_1+4;
                                            if (state == 1)
                                              lcd.print(" ");
                                          void ZONE_6()
                                          byte pin=RELAY_1+5;
                                            if (state == 1)
                                              lcd.print(" ");
                                          void ZONE_7()
                                          byte pin=RELAY_1+6;
                                            if (state == 1)
                                              lcd.print(" ");
                                          void WRONG() {}
                                            byte zone;
                                                lcd.print(zone);
                                                lcd.print(" ");
                                          Regards
                                          karl261K
                                          karl261K
                                          karl261
                                          @marekd Great controller! For the keypad: I see from the code that you use the I2C code. How did you connect your keypad? Did you use a I2C extension chip? And, which keypad_i2c library do you use? I found multiple on the net.
                                          Thanks!
