  3. MyNodes.NET
  4. Remote Configuration
Scheduled Pinned Locked Moved MyNodes.NET
12 Posts 2 Posters 3.8k Views 3 Watching
  • TakeroT
    TakeroT
    Takero
    Hello There,
    i installed MyNodes on my Raspberry via SSH Shell. It is possible to configure the Software via Network, and not "localhost"?
    Thanks!
    derwishD 1 Reply Last reply
    • TakeroT Takero
      Hello There,
      Thanks!
      derwishD
      derwishD
      derwish
      @Takero Tried this? http://mynodes.net/Software/Configure#localhost
      • TakeroT
        TakeroT
        Takero
        wrote on last edited by Takero
        I found this information in your Link before, but it needs to run it first local too! I want to do it remote from the begining. It is hard to get local Access to my rPi. That's my Problem.
        • TakeroT Takero
          derwishD
          derwishD
          derwish
          wrote on last edited by derwish
          @Takero Then, just edit WebController\project.json:
          "web": "Microsoft.AspNet.Server.Kestrel --server.urls http://localhost:1312"
          replace " http://localhost:1312" to your IP.
          Then start dnx web
          This line:
          https://github.com/derwish-pro/MyNodes.NET/blob/master/WebController/project.json#L31
          • TakeroT
            TakeroT
            Takero
            Thanks a lot! I will try that tomorow.
            • TakeroT
              TakeroT
              Takero
              It works!! Thanks!
              • TakeroT
                TakeroT
                Takero
                Now i have the Problem with the SerialGateway, what you described in your Troubleshoot . . . . I will try the last Beta ob Mono . . .
                I am using a Pi2+
                Edit: It does not work . . .
                GATEWAY: Gateway is not responding.
                • TakeroT Takero
                  I am using a Pi2+
                  derwishD
                  derwishD
                  derwish
                  @Takero Really sad. I contacted Microsoft and they told that the problem must be sought in mono. Need to wait for mono to fix it. At the moment, you can only use Ethernet gateway.
                  • TakeroT
                    TakeroT
                    Takero
                    Yah thats realy sad . . i dont have Ethernet Gateway ;-) I still wait for a fix
                    • TakeroT
                      TakeroT
                      Takero
                      Any news between mono Update?
                      • TakeroT Takero
                        derwishD
                        derwishD
                        derwish
                        @Takero Microsoft has updated the ASP.NET framework. I will soon make a port on it. I hope they fixed this bug.
                        TakeroT 1 Reply Last reply
                        • derwishD derwish
                          TakeroT
                          TakeroT
                          Takero
                          reply
                          Then is soon?
                          Alternativ i will try an other OS for my RPi
