  3. [Solved] GatewayESP8266MQTTClient from development tree does nothing
2 Posts 1 Posters 1.2k Views 2 Watching
  • Harry van der WolfH
    Harry van der WolfH
    Harry van der Wolf
    wrote on last edited by Harry van der Wolf
    I'm using the Arduino 1.6.5 ide on 64bit Linux using/trying the esp8266 2.2.0, 2.1.0 and 2.0.0 board mananger versions.
    I used the mysensors DEV git branch of May 14th and compiled and flashed the GatewayESP8266MQTTClient.ino.
    The only adaptions I made were the network settings for static IP and the broker address.
    Compiling works fine and flashing to my Nodemcu 1.0 Devboard as well.
    But absolutely nothing happens: I don't see anything on my serial monitor (I tried several baud rates). I can't ping it (static address 192.168.144.245). It doesn't connect to my mosquitto broker. Absolutely nothing.
    So I took an identical Nodemcu and set it up: Again absolutely nothing.
    The first nodemcu worked fine with the 1.5 branch Esp8266Gateway.ino. So I flashed the second nodemcu as well with this ino to rule out hardware issues: Both work fine.
    I finally do a "sudo arp-scan --localnet" to check for the mac addresses on my network and now it turns out that it didn't get a static ip-adress, but a dhcp address being 192.168.144.13
    However: still nothing on the serial monitor or at the mosquitto broker (and the broker functions fine. I tested that)
    So I assume there is something wrong with the static ip settings in the DEV branch, but for the time being I can live with that.
    For the record, these are my IP settings:
    #define MY_IP_ADDRESS 192, 168, 144, 245
    #define MY_IP_GATEWAY_ADDRESS 192, 168, 144, 1
    #define MY_IP_SUBNET_ADDRESS 255, 255, 255, 0
    // MQTT broker ip address.
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 144, 128
    My issues are the complete abundance of serial output and the not connecting to my broker.
    Can anyone please explain if I do something wrong? Or is this a straight bug in the DEV repository? (And I'm not talking about the static ip settings)
      Harry van der WolfH
      Harry van der Wolf
      I saw a commit to the DEV repo so I did a git pull this morning, started arduino and recompiled and flashed.
      It's working. Immediately!
      The fixed ip-adress was there and the the serial monitor displayed nicely the debug and node messages.
      The mosquitto broker receives the info which I can see using the mosquitto_sub command.
      It beats me, as I can't imagine the yesterday evening commit fixed it, but I'm glad it works.
      For reference: This morning I used the 2.2.0 esp8266 board managers version.
