  3. Send directly and to gateway
1 Posts 1 Posters 735 Views 1 Watching
  • D
    D
    dzairo
    Hi.
    I make project to control Relay Node with switch node directly and not used gateway.
    I use this code
      MyMessage response (message.getByte(),V_LIGHT) ;
      response.setDestination(1); //
      gw.send(response);
    in this I set then switch node send data directly to relay node with ID 1
    but if want send battery level or temperature to gateway, not to relay, then just set destination to 0 or need something else ?? other setting or code ..
    and question for route .. if send data from node to node and distance is too long and I use repeater then also working or not ??
    I thing so not ..
    regards.
