  3. Newbie needs help
Newbie needs help
7 Posts 4 Posters 2.5k Views 5 Watching
  • masterkenobiM
    masterkenobiM
    masterkenobi
    I just started on mysensors and I have zero knowledge in electronics.
    I want to create some sensor nodes using arduino pro mini.
    However i have few doubts. Hope someone can help a newbie.
    1. I can see only one VCC pin (excluding the one on programming header which i would like keep it for uploading sketches in future). How do I connect my radio and sensor? Shouldn't it be at least 2 VCC pins? Or can I fit in 2 wires into the same VCC pin?
    2. I'm powering the sensor node with 2 AA batteries. The negative terminal goes to ground. What about the positive terminal? Does is goes to RAW?
    I'm sorry for the silly questions.
    • masterkenobiM masterkenobi
      Welcome @masterkenobi !
      1: You can connect as many things as you like to the vcc pin. A breakout board is very handy when prototyping to make it easy to connect many things to the same pin.
      2: it depends. Search for 2xAA in the forum and you'll find lots of discussions. But to get started connect + on the batteries to Vcc.
      masterkenobiM 1 Reply Last reply
        masterkenobiM
        masterkenobiM
        masterkenobi
        @mfalkvidd thanks.
        I manage to build a couple of sensors powered by 2 AA batteries.
        However I'm stuck at monitoring the battery level.
        After I uploaded BatteryPoweredSensor.ino to my board, it overwrote the sensor sketch I uploaded earlier.
        Do I have to merge both sketches into one before upload?
        • Boots33B
          Boots33B
          Boots33
          Yes each time you upload a sketch it replaces the one that is already there.
          • D
            D
            danivalencia
            Here you have a sample of one of my battery nodes. Now I'm using V2.0 of Library, but this used to work before updating
            #include <BH1750.h>
            #define SN "SensorLuz"
            #define SV "1.0"
            unsigned long SLEEP_TIME = 300000; // 5 minutos
            #define CHILD_ID_LIGHT 0
            #define NODE_ID 7
            #define VBAT_PER_BITS 0.003363075
            #define VMIN 1.9                                  //  Vmin (radio Min Volt)=1.9V (564v)
            #define VMAX 3.0                                  //  Vmax = (2xAA bat)=3.0V (892v)
            int batteryPcnt = 0;                              // Calc value for battery %
            int batLoop = 0;                                  // Loop to help calc average
            int BATTERY_SENSE_PIN = A0;
            BH1750 lightSensor;
            uint16_t lastlux;
            MyMessage msgLux(CHILD_ID_LIGHT, V_LEVEL);
            MyMessage msgLuxUnit(CHILD_ID_LIGHT, V_UNIT_PREFIX);
               analogReference(INTERNAL);
              gw.begin(NULL, NODE_ID);
              lightSensor.begin();
              gw.sendSketchInfo(SN, SV);
              gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);
              gw.send(msgLuxUnit.set("lux"));
              uint16_t lux = lightSensor.readLightLevel();
              Serial.print("Lux: ");
              Serial.println(lux);
              if (lux != lastlux) {
                  gw.send(msgLux.set(lux));
                  lastlux = lux;
              batM();
              gw.sleep(SLEEP_TIME);
            void batM() //The battery calculations
               delay(500);
               delay(500);
               float Vbat  = sensorValue * VBAT_PER_BITS;
               int batteryPcnt = static_cast<int>(((Vbat-VMIN)/(VMAX-VMIN))*100.);
               //Serial.print("Battery percent: "); Serial.print(batteryPcnt); Serial.println(" %");
               if (batLoop > 24) {  //24 ciclos de 5 min = 2h.
                 batLoop = 0;
               else
               batLoop++;
            • Boots33B Boots33
              masterkenobiM
              masterkenobiM
              masterkenobi
              Thanks.
              Thanks.
              There is also another thing concern me. What if my neighbor also into Mysensors? Will he be able to view all the data from my sensors? How do I secure the nodes?
              D 1 Reply Last reply
                Thanks.
                Thanks.
                D
                D
                danivalencia
                Take a look at https://forum.mysensors.org/topic/1021/security-introducing-signing-support-to-mysensors
