  3. Bluetooth Proximity Sensor
bluetoothpresence
33 Posts 9 Posters 36.5k Views 7 Watching
  • K
    K
    Konrad Walsh
    ok.. mine enters AT mode.. and I can get it to send and receive data.. I may as well keep plugging at it so
    • K Konrad Walsh
      I have given up.. I cant get anywhere with this but I think its cause I bought hc-06.. Are you closer?
      P
      P
      PedroC88
      @Konrad-Walsh For what I know, the HC-06 is automatically configured to take in AT commands, so that shouldn't be a problem, although mine (that I got today) seems to be defective as I send it the AT command, but I'm getting no answer.
        I accidentally feed the first module with reversed polarity. It did not like that very much. :(
        The second module arrived this week, but I haven't hooked it up yet. Planned on using software serial and had a test sketch going something like this:
        /* $Id$
        Serial terminal for the HC-05 bluetooth module.
        Sets up BT module and allow user interaction with the device via the Arduino Serial Monitor.
        Wiring of BT HC-05 device to the Arduino
        RX -> 11
        TX -> 10
        KEY -> 9
        #include <SoftwareSerial.h>
        // Bluetooth to Arduino pins.
        #define BTkey 9
        #define BTrxPin 10
        #define BTtxPin 11
        enum { SYNC, ASYNC };
        SoftwareSerial BTSerial(BTrxPin, BTtxPin);
        // Send a command to the bluetooth device.
        // mode ASYNC - don't want for the response
        // mode SYNC - wait for the response
        void sendBluetoothCommand(String cmd, uint8_t mode) {
          Serial.print(mode == SYNC ? "SYNC> " : "ASYNC> ");
          Serial.println(cmd);
          BTSerial.println(cmd);
          if (mode == ASYNC) return;
          char ch = 0;
          while (ch != '\n') {
            if (BTSerial.available()) {
              ch = BTSerial.read();
               Serial.write(ch);
           Serial.begin(57600);
          // SETUP BLUETOOTH
          // define pin modes for tx, rx:
          pinMode(BTrxPin, INPUT);
          pinMode(BTtxPin, OUTPUT);
          // Switch module to AT mode
          pinMode(BTkey, OUTPUT);
          digitalWrite(BTkey, HIGH);
          BTSerial.begin(38400);
          sendBluetoothCommand("AT", SYNC);
          sendBluetoothCommand("AT+NAME=blueNode", SYNC);
          // AT+ROLE=p1
          // p1 - 0 Slave Role, 1 Master Role, 2 Slave-Loop role.
          sendBluetoothCommand("AT+ROLE=1", SYNC);
          // AT+INQM=p1,p2,p3
          // p1 - 0 inquire_mode_standad, 1 inquire_mode_rssi
          // p2 - maximum number of bluetooth devices response
          // p3 - the maximum of limited inquiring time. 1~48 (1.28s ~ 61.44s)
          //      15*1.28 = 19sec
          sendBluetoothCommand("AT+INQM=0,5,15", SYNC);
          // Keep reading from HC-05 and send to Arduino Serial Monitor
            Serial.write(BTSerial.read());
          // Keep reading from Arduino Serial Monitor and send to HC-05
          if (Serial.available())
            BTSerial.write(Serial.read());
        And.. the first module was of the wrong type (I think). Must support master-mode if I understand it correctly. The second one I bought was this type.
        P
        P
        PedroC88
        @hek When you say you inverted the polarity... are you talking about VCC and GRD? or Rx and TX?
        hekH 1 Reply Last reply
        • P PedroC88
          @PedroC88
          vcc/gnd
          • K
            K
            Konrad Walsh
            i am "semi" abandoned it.. I couldn't get it work at all...
            • K
              K
              Konrad Walsh
              i am "semi" abandoned it.. I couldn't get it work at all... but I cant say I fully grasp the syntax yet. Hopefully @HEK gets the notion...
              P 1 Reply Last reply
              • K Konrad Walsh
                P
                P
                PedroC88
                @Konrad-Walsh At the end I got the HC06 to work, I'm finally understanding all of this, if you tell me what you're trying to accomplish and the code u have I might be able to help. Also the module you're using.
                • Ø
                  Ø
                  Øyvind A. Espnes
                  I really like this idea, but for it to be effective we need to measure the decibel level of the connection and not just connected/disconnected state. Is this possible?
                  • Ø Øyvind A. Espnes
                    P
                    P
                    PedroC88
                    @Øyvind-A.-Espnes I haven't tried it, but with the AT+INQM command you can specify wether you want the RSSI of the device when issuing the AT+INQ command. This document can better explain it.
                    After that it should just be a matter of parsing the resulting string and extract the signal strength.
                    • D
                      D
                      Dean
                      I was thinking about going this route, but until last weekend I was using Tasker and having it tell Vera that I am here when my phone connects to my Wifi. I bought a new phone and I can't get it to stay connected when it hasn't been used in a while, so I have to rethink...
                      While a Mysensors option could be good, what I am going to do is use my many Android tablets that I have throughout my home and have them always searching my my mobile. With them all throughout my home, I won't have to worry about bluetooth range.
                      Sorry it isn't a Mysensors option, but I thought I would share what I am going to do :-)
                      • N
                        N
                        Newzwaver
                        Any luck with BT?
                        • riochickenR
                          riochickenR
                          riochicken
                          @hek
                          Did you get anywhere with this? I would like to build a bluetooth sensor myself but since this is an old thread, I am not really sure if the market has been modernized a little with bluetooth devices..
                          Thanks!
                            Sorry, no. Realised modern phones BT goes into sleep mode which means they don't announce themselves for longer periods. Kind of made it meaningless for the application.
