  3. Looking to switch automation controller software
27 Posts 10 Posters 11.9k Views 8 Watching
  • F
    F
    Fabien
    node-red-ui is currently switching to node-red-dashboard and maintained by the core team.
    • DidiD
      DidiD
      Didi
      I don´t have noticed that.
      Here is the github link
      if (knowledge == 0) { use BRAIN; use GOOGLE;use SEARCH; } else {make POST;}
      • dbemowskD
        dbemowskD
        So in the interest of keeping my current HA setup running while I get this set up and tested, I figured that this might be a place to use a new controller I got a while back. The controller is an Orange Pi. When a guy from work said he could get me one for $18 US, I couldn't say no. I have had it sitting around for a couple months now waiting to find a use for it. I think I found my use.
        The unit that I have is an Orange Pi PC which has a 1.6GHz quad coreprocessor with 1GB ram. A lot of choices for OS. Need to find me an 8GB class 10 MicroSD card (Might have one laying around). Then I want to find an automation software that is easy to install and use with this computer. Has anyone in here used an Orange Pi, and if so, what automation software have you used with it?
        • tbowmoT
          tbowmoT
          tbowmo
          @dbemowsk
          As some of the other posts in this thread indicate, you can use node-red as a middleware, between domoticz (or any other controller frontends you like) and sensors.
          I'm using it here, between my mysensors GW and domoticz. I have one arduino on my utility meter, that isn't wireless, and doesn't use mysensors protocol. I have used node-red to change it's protocol into mysensors format, and are injecting that into the mysensors datastream into domoticz.
          At the same time, I have influxdb / grafana installed, and node-red publishes all sensor data into influxdb, so I can use that package as graphing solution.
          I have been running two controllers at the same time at one point in time, where node-red was feeding the two controllers the same mysensors datastream, and both controllers could send data to mysensors nodes.
          The possibilities are endless with node-red :)
          D 1 Reply Last reply
          • tbowmoT tbowmo
            @dbemowsk
            D
            D
            drock1985
            @tbowmo
            Oh wow, going to have to look into this now. Any links to get a person started? Only ever heard of Node-Red so far.
            My Projects
            2 Door Chime Sensor
            Washing Machine Monitor
            • tbowmoT
              tbowmoT
              tbowmo
              @drock1985
              Search the forum, as there are some threads with setup hints etc.
              For installation of nodered, you should follow the guides at nodereds website.
              • DidiD
                DidiD
                Didi
                Here is a package you can start without installing anything ;-)
