  3. Looking to switch automation controller software
27 Posts 10 Posters 11.9k Views 8 Watching
  • dbemowskD dbemowsk
    @mfalkvidd I can see that being nice for the logic side, but what I was asking about when I mentioned a web interface was some nice easy way of looking up the status of devices from something like a floorplan or list view, and a way to control those devices manually if I see the need.
    drock1985
    @dbemowsk
    Domoticz. Domoticz offers floorplan setup (just upload a .jpg of the plan) and has manual switches you can set up. As well, the automation uses blocky - an easy to use GUI way of automating. Or LUA; if you are feeling brave.
    My Projects
    2 Door Chime Sensor
    Washing Machine Monitor
      K
      K
      kimot
      @dbemowsk I think, that for example Domoticz does not understood your RS485 thermostat. So you can recieve its message by serial node in NODE RED,
      decode message and send it via HTTP to the Domnoticz. Or you are not happy with Domoticz graph style end limitation only 7 days for detail teperature storage. So you can first recieve data from sensor by NODE RED, store them to the file or database and then send them to the Domoticz. I wrote that NODE RED is good for cooperation with other sw controllers, witch do visualisation measured data.
      • dbemowskD
        dbemowskD
        @kimot I see, you are only using NODE RED as a go between for Domoticz, not as the actual controller itself. Like a way to interface hardware that Domoticz doesn't normally recognize.
        • DidiD
          DidiD
          Didi
          Read this for a Nodered userinterface
          http://tech.scargill.net/node-red-ui/
          http://tech.scargill.net/more-node-red-ui/
          • F
            F
            Fabien
            node-red-ui is currently switching to node-red-dashboard and maintained by the core team.
            • DidiD
              DidiD
              Didi
              I don´t have noticed that.
              Here is the github link
              • dbemowskD
                dbemowskD
                So in the interest of keeping my current HA setup running while I get this set up and tested, I figured that this might be a place to use a new controller I got a while back. The controller is an Orange Pi. When a guy from work said he could get me one for $18 US, I couldn't say no. I have had it sitting around for a couple months now waiting to find a use for it. I think I found my use.
                The unit that I have is an Orange Pi PC which has a 1.6GHz quad coreprocessor with 1GB ram. A lot of choices for OS. Need to find me an 8GB class 10 MicroSD card (Might have one laying around). Then I want to find an automation software that is easy to install and use with this computer. Has anyone in here used an Orange Pi, and if so, what automation software have you used with it?
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @dbemowsk
                  As some of the other posts in this thread indicate, you can use node-red as a middleware, between domoticz (or any other controller frontends you like) and sensors.
                  I'm using it here, between my mysensors GW and domoticz. I have one arduino on my utility meter, that isn't wireless, and doesn't use mysensors protocol. I have used node-red to change it's protocol into mysensors format, and are injecting that into the mysensors datastream into domoticz.
                  At the same time, I have influxdb / grafana installed, and node-red publishes all sensor data into influxdb, so I can use that package as graphing solution.
                  I have been running two controllers at the same time at one point in time, where node-red was feeding the two controllers the same mysensors datastream, and both controllers could send data to mysensors nodes.
                  The possibilities are endless with node-red :)
                  D 1 Reply Last reply
                  • tbowmoT tbowmo
                    @dbemowsk
                    drock1985
                    @tbowmo
                    Oh wow, going to have to look into this now. Any links to get a person started? Only ever heard of Node-Red so far.
                    My Projects
                    2 Door Chime Sensor
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @drock1985
                      Search the forum, as there are some threads with setup hints etc.
                      For installation of nodered, you should follow the guides at nodereds website.
                      • DidiD
                        DidiD
                        Didi
                        Here is a package you can start without installing anything ;-)
