  3. Signing: no active verification session?
36 Posts 3 Posters 6.6k Views 2 Watching
  • T
    tomkxy
    So, I repeated the test again, if GW and node are on soft sign it works. If I put either GW or node on soft sign, while the other is using ATSHA204, signing fails
    To verify my setup I switched to development branch. There I could run the node on soft signing while the GW is using ATSHA204.
    AnticimexA 1 Reply Last reply
    • T tomkxy
      AnticimexA
      AnticimexA
      Anticimex
      @tomkxy Hm, ok, so with the updates from PR, soft and atsha signing are not compatible? I need to check into that.
      Out of curiosity, when you checked from development branch, was the ATSHA node using the code from the PR or was it also from development branch? Just so I know if the issue is in the soft signing implementation or both backends.
      T 1 Reply Last reply
      • AnticimexA Anticimex
        tomkxy
        I ran the test with node and gateway on PR code:
        One test both on soft signing -> ok
        One test node on soft signing, GW on ATSH204 -> failed
        Then I repeated with both node and GW on development branch:
        • node soft sign, GW on ATSHA204 -> OK
        • T tomkxy
          AnticimexA
          AnticimexA
          Anticimex
          @tomkxy I think I found the problem. Mistake by me.
          Try to change the following two lines (106 & 107) in MySigningAtsha204Soft.cpp:
          memset(_signing_current_inbound_nonce, 0x00, NONCE_NUMIN_SIZE_PASSTHROUGH);
          memset(_signing_current_outbound_nonce, 0x00, NONCE_NUMIN_SIZE_PASSTHROUGH);
          to
          memset(_signing_current_inbound_nonce, 0xAA, 32);
          memset(_signing_current_outbound_nonce, 0xAA, 32);
            to
            tomkxy
            to
            I made the changes. Still not working.
            • T tomkxy
              to
              AnticimexA
              AnticimexA
              Anticimex
              @tomkxy Hm. I have rewritten the code to be easier to read. Could you please clean out the changes from my PR (restore to "pristine" development) and then reapply the PR from github?
              If possible, also include the verbose logs from both ends so that we can confirm that they agree upon which nonce to use for a message.
              • T
                tomkxy
                I cannot promise that I am able to do that today.
                • T tomkxy
                  AnticimexA
                  AnticimexA
                  Anticimex
                  #28
                  @tomkxy That's ok, No big rush on this. I suspect it is just a matter of the soft and atsha backends are not in agreement on the nonce data. I have not changed the algorithms so I would not expect them to be incompatible.
                    tomkxy
                    Can I use the same pull request? I just fetched this one (https://github.com/mysensors/Arduino/pull/454)
                    OK?
                    • T tomkxy
                      OK?
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @tomkxy yes, just make sure it applies cleanly. I forced pushed some updates.
                        tomkxy
                        I sent you a chat message
                        • T tomkxy
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @tomkxy So I noticed. Let's iron out the details in the chat, and report here when we sort it for documentation purposes.
                          • T
                            tomkxy
                            Here are the log files. They are not in sync from the beginning. Further there re message from a node 27 which can be ignored. Best is probably to work from the end.
                            Node log
                            Starting sensor (RNNNAS, 2.0.0-beta)
                            Radio init successful.
                            Signing required
                            Skipping security for command 3 type 15
                            send: 32-32-0-0 s=255,c=3,t=15,pt=0,l=2,sg=0,st=ok:
                            Waiting for GW to send signing preferences...
                            read: 0-0-32 s=255,c=3,t=15,pt=0,l=2,sg=0:
                            Mark node 0 as one that require signed messages
                            Mark node 0 as one that do not require whitelisting
                            Skipping security for command 3 type 16
                            send: 32-32-0-0 s=255,c=3,t=16,pt=0,l=0,sg=0,st=ok:
                            Nonce requested from 0. Waiting...
                            Skipping security for command 3 type 17
                            read: 0-0-32 s=255,c=3,t=17,pt=6,l=25,sg=0:F0E3953E5E27A57274D53B6F0B2C4098EBD0F6A84345DE7135
                            Nonce received from 0. Proceeding with signing...
                            Signing backend: ATSHA204Soft
                            Message to process: 2000560011FF322E302E302D62657461
                            Current nonce: F0E3953E5E27A57274D53B6F0B2C4098EBD0F6A84345DE7135AAAAAAAAAAAAAA
                            HMAC: DC73D1128E9B00E6E0FFA12AE46CBBD6BE0F3103FDFDE2D718A52AC530A852F9
                            Signature in message: 0173D1128E9B00E6E0FFA12AE46CBB
                            Message signed
                            Message to send has been signed
                            send: 32-32-0-0 s=255,c=0,t=17,pt=0,l=10,sg=1,st=ok:2.0.0-beta
                            read: 0-0-32 s=255,c=3,t=17,pt=6,l=25,sg=0:E574F30C89052CFEA25ACB6D9B3B4E8CA0D462DF4770ECF72F
                            Message to process: 20000E2306FF00
                            Current nonce: E574F30C89052CFEA25ACB6D9B3B4E8CA0D462DF4770ECF72FAAAAAAAAAAAAAA
                            HMAC: 556E870FC4662534A18B29FB7A48440B7C745E15FF82EA34E806F9C372B6FDA9
                            Signature in message: 016E870FC4662534A18B29FB7A48440B7C745E15FF82EA34
                            Message signed
                            send: 32-32-0-0 s=255,c=3,t=6,pt=1,l=1,sg=1,st=ok:0
                            read: 0-0-32 s=255,c=3,t=17,pt=6,l=25,sg=0:10C33355BD231F7BB5E53E7E39372DE1C3053161AE04D74494
                            Message to process: 20008E030BFF53656E736562656E646572204D6963726F
                            Current nonce: 10C33355BD231F7BB5E53E7E39372DE1C3053161AE04D74494AAAAAAAAAAAAAA
                            HMAC: F272ECC9E1B27FF3C089905712EDF1793D146865CE2AF9252D27FAFF953BA64F
                            Signature in message: 0172ECC9E1B27FF3
                            Message signed
                            send: 32-32-0-0 s=255,c=3,t=11,pt=0,l=17,sg=1,st=ok:Sensebender Micro
                            read: 0-0-32 s=255,c=3,t=17,pt=6,l=25,sg=0:3B91B8117E813E6F0E12221791A78309559E5052097A420E8A
                            Message to process: 20001E030CFF312E35
                            Current nonce: 3B91B8117E813E6F0E12221791A78309559E5052097A420E8AAAAAAAAAAAAAAA
                            HMAC: 23E348148A34E8BE86788E5AA5F45F8F675089068DA52BC6C4C27D0B8DCA70C3
                            Signature in message: 01E348148A34E8BE86788E5AA5F45F8F675089068DA5
                            Message signed
                            send: 32-32-0-0 s=255,c=3,t=12,pt=0,l=3,sg=1,st=ok:1.5
                            send: 32-32-0-0 s=0,c=3,t=16,pt=0,l=0,sg=0,st=ok:
                            read: 0-0-32 s=255,c=3,t=17,pt=6,l=25,sg=0:694B1F7903CB8A6854DAF8509AA451207AD040D71966A3453D
                            Message to process: 200006001F00
                            Current nonce: 694B1F7903CB8A6854DAF8509AA451207AD040D71966A3453DAAAAAAAAAAAAAA
                            HMAC: 6013C5AA4FDD7E2F61EAA2C3F2716BCEEFB56292BA66BC98A43517E458EF235B
                            Signature in message: 0113C5AA4FDD7E2F61EAA2C3F2716BCEEFB56292BA66BC98A4
                            Message signed
                            send: 32-32-0-0 s=0,c=0,t=31,pt=0,l=0,sg=1,st=ok:
                            Init complete, id=32, parent=0, distance=1
                            ------------- Start request time ------------
                            read: 0-0-32 s=255,c=3,t=17,pt=6,l=25,sg=0:13F0B25E5D9A117DA1146AFA7494C90FA33FA03B128B0CE3E1
                            Message to process: 2000060301FF
                            Current nonce: 13F0B25E5D9A117DA1146AFA7494C90FA33FA03B128B0CE3E1AAAAAAAAAAAAAA
                            HMAC: 5F71BF42F9C80CC00B5319226D836566CD4F95123E96258FF8E2E3400863547E
                            Signature in message: 0171BF42F9C80CC00B5319226D836566CD4F95123E96258FF8
                            Message signed
                            send: 32-32-0-0 s=255,c=3,t=1,pt=0,l=0,sg=1,st=ok:
                            ------------- End request time ------------
                            read: 0-0-32 s=255,c=3,t=17,pt=6,l=25,sg=0:8FBD6C07C7957826D2BAF13CDD7A82D8082180FD4F0796F6B4
                            Current nonce: 8FBD6C07C7957826D2BAF13CDD7A82D8082180FD4F0796F6B4AAAAAAAAAAAAAA
                            HMAC: 6FAC958E93696F29B508B534322FC0237EB1740405F2A7AA2A518FBF4883896D
                            Signature in message: 01AC958E93696F29B508B534322FC0237EB1740405F2A7AA2A
                            Message signed
                            read: 0-0-32 s=255,c=3,t=17,pt=6,l=25,sg=0:6BB69A71C65A24D7077B9B2A2E65D51B3861A56CF777BBD6B6
                            Current nonce: 6BB69A71C65A24D7077B9B2A2E65D51B3861A56CF777BBD6B6AAAAAAAAAAAAAA
                            HMAC: 3E2DE76DD7349510C9CAE6F072875D7D7C380BBDD00C65339BF25898F44A180B
                            Signature in message: 012DE76DD7349510C9CAE6F072875D7D7C380BBDD00C65339B
                            Message signed
                            read: 0-0-32 s=255,c=3,t=17,pt=6,l=25,sg=0:B7CD5773148E8916C98B5BB16265F17811F8091A560A3535EB
                            Current nonce: B7CD5773148E8916C98B5BB16265F17811F8091A560A3535EBAAAAAAAAAAAAAA
                            HMAC: 46959641C93642F85E13499948DC33F1CE3B1B0DE5D8DEC8F5D04ECBA2A28552
                            Signature in message: 01959641C93642F85E13499948DC33F1CE3B1B0DE5D8DEC8F5
                            Message signed
                            read: 0-0-32 s=255,c=3,t=17,pt=6,l=25,sg=0:43AADEA58D5CC9AF0A58FE4A763CEE560CB751BCF31BAD7F4C
                            Current nonce: 43AADEA58D5CC9AF0A58FE4A763CEE560CB751BCF31BAD7F4CAAAAAAAAAAAAAA
                            HMAC: 1217705F14F7482ACEEC510ADD5EB2CBB329B3FA475486182644D5EC98DDB619
                            Signature in message: 0117705F14F7482ACEEC510ADD5EB2CBB329B3FA4754861826
                            Message signed
                            read: 0-0-32 s=255,c=3,t=17,pt=6,l=25,sg=0:90E1C960135A6C130C95D8DCDA63C583905F58BC0C0AC6734C
                            Current nonce: 90E1C960135A6C130C95D8DCDA63C583905F58BC0C0AC6734CAAAAAAAAAAAAAA
                            HMAC: 5DE257A17035F53D20CE18F57BF0E0E60142F56690BB8BB9F4184632241E2015
                            Signature in message: 01E257A17035F53D20CE18F57BF0E0E60142F56690BB8BB9F4
                            Message signed
                            read: 0-0-32 s=255,c=3,t=17,pt=6,l=25,sg=0:5FB2B52B80BA2BD2B7F657B3754594C84B14811B6067EEB626
                            Current nonce: 5FB2B52B80BA2BD2B7F657B3754594C84B14811B6067EEB626AAAAAAAAAAAAAA
                            HMAC: 00AE0409E50F471F7B4154A4492D72FA382EEA40257DD408D2EB9E1B012A35EF
                            Signature in message: 01AE0409E50F471F7B4154A4492D72FA382EEA40257DD408D2
                            Message signed
                            Log file from gateway:
                            0;255;3;0;9;Starting gateway (RNNGAA, 2.0.0-beta)
                            0;255;3;0;9;Radio init successful.
                            0;255;3;0;9;Init complete, id=0, parent=0, distance=0
                            0;255;3;0;9;MQTT connected
                            0;255;3;0;9;Skipping security for command 3 type 16
                            0;255;3;0;9;read: 32-32-0 s=255,c=3,t=16,pt=0,l=0,sg=0:
                            0;255;3;0;9;Signing backend: ATSHA204
                            0;255;3;0;9;SHA256: B44451C64C562F11BDCF41F7F3EEF39816265188B34FD45E96216B85148A12AA
                            0;255;3;0;9;Transmittng nonce
                            0;255;3;0;9;Skipping security for command 3 type 17
                            0;255;3;0;9;send: 0-0-32-32 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:B44451C64C562F11BDCF41F7F3EEF39816265188B34FD45E96
                            0;255;3;0;9;Signature in message: 0191F99D82163BDAF73FFD91B6984D59A5F564BF45ECBBABCE
                            0;255;3;0;9;Message to process: 2000060301FF
                            0;255;3;0;9;Current nonce: B44451C64C562F11BDCF41F7F3EEF39816265188B34FD45E96AAAAAAAAAAAAAA
                            0;255;3;0;9;HMAC: EB8162E2FCAD9359B19B383A711A5E64A964A25F965162BF74BBFB4EB59836E2
                            0;255;3;0;9;Signature bad: 018162E2FCAD9359B19B383A711A5E64A964A25F965162BF74
                            0;255;3;0;9;Signature verification failed!
                            0;255;3;0;9;verify fail
                            0;255;3;0;9;read: 27-27-0 s=2,c=1,t=1,pt=7,l=5,sg=0:62.49
                            0;255;3;0;9;Sending message on topic: GW1_out/27/2/1/0/1
                            0;255;3;0;9;read: 27-27-0 s=1,c=1,t=0,pt=7,l=5,sg=0:34.11
                            0;255;3;0;9;Sending message on topic: GW1_out/27/1/1/0/0
                            0;255;3;0;9;read: 27-27-0 s=0,c=1,t=4,pt=7,l=5,sg=0:1020.15
                            0;255;3;0;9;Sending message on topic: GW1_out/27/0/1/0/4
                            0;255;3;0;9;read: 27-27-0 s=0,c=1,t=5,pt=0,l=6,sg=0:stable
                            0;255;3;0;9;Sending message on topic: GW1_out/27/0/1/0/5
                            0;255;3;0;9;read: 27-27-0 s=10,c=1,t=38,pt=7,l=5,sg=0:4.123
                            0;255;3;0;9;Sending message on topic: GW1_out/27/10/1/0/38
                            0;255;3;0;9;read: 27-27-0 s=10,c=1,t=39,pt=7,l=5,sg=0:0.000000
                            0;255;3;0;9;Sending message on topic: GW1_out/27/10/1/0/39
                            0;255;3;0;9;read: 27-27-0 s=11,c=1,t=38,pt=7,l=5,sg=0:9.978
                            0;255;3;0;9;Sending message on topic: GW1_out/27/11/1/0/38
                            0;255;3;0;9;read: 27-27-0 s=255,c=3,t=0,pt=1,l=1,sg=0:88
                            0;255;3;0;9;Sending message on topic: GW1_out/27/255/3/0/0
                            0;255;3;0;9;read: 27-27-0 s=13,c=1,t=8,pt=7,l=5,sg=0:0.40
                            0;255;3;0;9;Sending message on topic: GW1_out/27/13/1/0/8
                            0;255;3;0;9;read: 27-27-0 s=13,c=1,t=9,pt=7,l=5,sg=0:0.60
                            0;255;3;0;9;Sending message on topic: GW1_out/27/13/1/0/9
                            0;255;3;0;9;read: 27-27-0 s=12,c=1,t=10,pt=7,l=5,sg=0:328.68
                            0;255;3;0;9;Sending message on topic: GW1_out/27/12/1/0/10
                            0;255;3;0;9;read: 27-27-0 s=12,c=1,t=24,pt=7,l=5,sg=0:36.80
                            0;255;3;0;9;Sending message on topic: GW1_out/27/12/1/0/24
                            0;255;3;0;9;read: 27-27-0 s=14,c=1,t=6,pt=7,l=5,sg=0:0.00
                            0;255;3;0;9;Sending message on topic: GW1_out/27/14/1/0/6
                            0;255;3;0;9;SHA256: 9BEBE9A04F339CE85808EBF1B5E8BC7BD611CC3B5C0A638DF2A548B398BF059E
                            0;255;3;0;9;send: 0-0-32-32 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:9BEBE9A04F339CE85808EBF1B5E8BC7BD611CC3B5C0A638DF2
                            0;255;3;0;9;Signature in message: 012C3605DF4F03AD69833FCC101EA1BF0E5750483F4E2107F6
                            0;255;3;0;9;Current nonce: 9BEBE9A04F339CE85808EBF1B5E8BC7BD611CC3B5C0A638DF2AAAAAAAAAAAAAA
                            0;255;3;0;9;HMAC: 681C6D87947BC2574D48FFCAC370BECD30789EAEB7C2BFBAD562B2ED7DCAE10F
                            0;255;3;0;9;Signature bad: 011C6D87947BC2574D48FFCAC370BECD30789EAEB7C2BFBAD5
                            0;255;3;0;9;Skipping security for command 3 type 15
                            0;255;3;0;9;read: 32-32-0 s=255,c=3,t=15,pt=0,l=2,sg=0:
                            0;255;3;0;9;Mark node 32 as one that require signed messages
                            0;255;3;0;9;Mark node 32 as one that do not require whitelisting
                            0;255;3;0;9;Informing node 32 that we require signatures
                            0;255;3;0;9;Informing node 32 that we do not require whitelisting
                            0;255;3;0;9;send: 0-0-32-32 s=255,c=3,t=15,pt=0,l=2,sg=0,st=ok:
                            0;255;3;0;9;SHA256: F0E3953E5E27A57274D53B6F0B2C4098EBD0F6A84345DE7135D3A4AEC3E13960
                            0;255;3;0;9;send: 0-0-32-32 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:F0E3953E5E27A57274D53B6F0B2C4098EBD0F6A84345DE7135
                            0;255;3;0;9;Signature in message: 0173D1128E9B00E6E0FFA12AE46CBB
                            0;255;3;0;9;Message to process: 2000560011FF322E302E302D62657461
                            0;255;3;0;9;Current nonce: F0E3953E5E27A57274D53B6F0B2C4098EBD0F6A84345DE7135AAAAAAAAAAAAAA
                            0;255;3;0;9;HMAC: CBC7FC088614695AD92A5A4A32CA832C6D00041CF63D1AF78F353FD6E0D9D949
                            0;255;3;0;9;Signature bad: 01C7FC088614695AD92A5A4A32CA83
                            0;255;3;0;9;SHA256: E574F30C89052CFEA25ACB6D9B3B4E8CA0D462DF4770ECF72FB75DED8D5F68BC
                            0;255;3;0;9;send: 0-0-32-32 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:E574F30C89052CFEA25ACB6D9B3B4E8CA0D462DF4770ECF72F
                            0;255;3;0;9;Signature in message: 016E870FC4662534A18B29FB7A48440B7C745E15FF82EA34
                            0;255;3;0;9;Message to process: 20000E2306FF00
                            0;255;3;0;9;Current nonce: E574F30C89052CFEA25ACB6D9B3B4E8CA0D462DF4770ECF72FAAAAAAAAAAAAAA
                            0;255;3;0;9;HMAC: 5E2D30821345709074EB96B09CC0C7408E1291AC5C921432DD83A29919734767
                            0;255;3;0;9;Signature bad: 012D30821345709074EB96B09CC0C7408E1291AC5C921432
                            0;255;3;0;9;SHA256: 10C33355BD231F7BB5E53E7E39372DE1C3053161AE04D744948C093BFA5776C8
                            0;255;3;0;9;send: 0-0-32-32 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:10C33355BD231F7BB5E53E7E39372DE1C3053161AE04D74494
                            0;255;3;0;9;Signature in message: 0172ECC9E1B27FF3
                            0;255;3;0;9;Message to process: 20008E030BFF53656E736562656E646572204D6963726F
                            0;255;3;0;9;Current nonce: 10C33355BD231F7BB5E53E7E39372DE1C3053161AE04D74494AAAAAAAAAAAAAA
                            0;255;3;0;9;HMAC: 82CCF6912389FCE5896B4867B82879414D80FE3FBAC1C6365E0B6303F7DADB56
                            0;255;3;0;9;Signature bad: 01CCF6912389FCE5
                            0;255;3;0;9;SHA256: 3B91B8117E813E6F0E12221791A78309559E5052097A420E8A3AB9EDED6F5D56
                            0;255;3;0;9;send: 0-0-32-32 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:3B91B8117E813E6F0E12221791A78309559E5052097A420E8A
                            0;255;3;0;9;Signature in message: 01E348148A34E8BE86788E5AA5F45F8F675089068DA5
                            0;255;3;0;9;Message to process: 20001E030CFF312E35
                            0;255;3;0;9;Current nonce: 3B91B8117E813E6F0E12221791A78309559E5052097A420E8AAAAAAAAAAAAAAA
                            0;255;3;0;9;HMAC: ACFBD53ADA240C2FF69FF474887A750BEC719180D3A30B132AF241E94D8CF15B
                            0;255;3;0;9;Signature bad: 01FBD53ADA240C2FF69FF474887A750BEC719180D3A3
                            0;255;3;0;9;read: 32-32-0 s=0,c=3,t=16,pt=0,l=0,sg=0:
                            0;255;3;0;9;SHA256: 694B1F7903CB8A6854DAF8509AA451207AD040D71966A3453D7D5772649E35E9
                            0;255;3;0;9;send: 0-0-32-32 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:694B1F7903CB8A6854DAF8509AA451207AD040D71966A3453D
                            0;255;3;0;9;Signature in message: 0113C5AA4FDD7E2F61EAA2C3F2716BCEEFB56292BA66BC98A4
                            0;255;3;0;9;Message to process: 200006001F00
                            0;255;3;0;9;Current nonce: 694B1F7903CB8A6854DAF8509AA451207AD040D71966A3453DAAAAAAAAAAAAAA
                            0;255;3;0;9;HMAC: 786E3B4757AA9BA51BB69546A59AC2E07B4FD696E79A72BF4DBD14530CBDFB21
                            0;255;3;0;9;Signature bad: 016E3B4757AA9BA51BB69546A59AC2E07B4FD696E79A72BF4D
                            0;255;3;0;9;SHA256: 13F0B25E5D9A117DA1146AFA7494C90FA33FA03B128B0CE3E1ED939BDD46DD66
                            0;255;3;0;9;send: 0-0-32-32 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:13F0B25E5D9A117DA1146AFA7494C90FA33FA03B128B0CE3E1
                            0;255;3;0;9;Signature in message: 0171BF42F9C80CC00B5319226D836566CD4F95123E96258FF8
                            0;255;3;0;9;Current nonce: 13F0B25E5D9A117DA1146AFA7494C90FA33FA03B128B0CE3E1AAAAAAAAAAAAAA
                            0;255;3;0;9;HMAC: 7C9BD8227613765CC0A7D20E5C76396F6B380BB4D6A4199CDAB76C4D5CFF5C43
                            0;255;3;0;9;Signature bad: 019BD8227613765CC0A7D20E5C76396F6B380BB4D6A4199CDA
                            0;255;3;0;9;read: 27-27-0 s=13,c=1,t=8,pt=7,l=5,sg=0:0.13
                            0;255;3;0;9;read: 27-27-0 s=13,c=1,t=9,pt=7,l=5,sg=0:0.40
                            0;255;3;0;9;read: 27-27-0 s=12,c=1,t=10,pt=7,l=5,sg=0:225.00
                            0;255;3;0;9;read: 27-27-0 s=12,c=1,t=24,pt=7,l=5,sg=0:0.02
                            0;255;3;0;9;SHA256: 8FBD6C07C7957826D2BAF13CDD7A82D8082180FD4F0796F6B4E49547312D56B7
                            0;255;3;0;9;send: 0-0-32-32 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:8FBD6C07C7957826D2BAF13CDD7A82D8082180FD4F0796F6B4
                            0;255;3;0;9;Signature in message: 01AC958E93696F29B508B534322FC0237EB1740405F2A7AA2A
                            0;255;3;0;9;Current nonce: 8FBD6C07C7957826D2BAF13CDD7A82D8082180FD4F0796F6B4AAAAAAAAAAAAAA
                            0;255;3;0;9;HMAC: 2C52B5D52BDA0030F2BC63D2CE6EB6CF7ED83AB9F35DCEA61147FB3429B03170
                            0;255;3;0;9;Signature bad: 0152B5D52BDA0030F2BC63D2CE6EB6CF7ED83AB9F35DCEA611
                            0;255;3;0;9;read: 26-26-0 s=1,c=3,t=16,pt=0,l=0,sg=0:
                            0;255;3;0;9;SHA256: 53FB5496D3358338CE2D5082FAC5D043DE6D4E0D607275D2F3908F0F1AF8CB73
                            0;255;3;0;9;send: 0-0-26-26 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:53FB5496D3358338CE2D5082FAC5D043DE6D4E0D607275D2F3
                            0;255;3;0;9;Signature in message: 012C20F0DC9CF89B84455FA90271B4823E60DF9D
                            0;255;3;0;9;Message to process: 1A002EE100014879D04101
                            0;255;3;0;9;Current nonce: 53FB5496D3358338CE2D5082FAC5D043DE6D4E0D607275D2F3AAAAAAAAAAAAAA
                            0;255;3;0;9;HMAC: 1D593C273D7167F9756DCA5CE4AF8005D7E5B8D6B95CF2C3B0C10A839E057FC3
                            0;255;3;0;9;Signature bad: 01593C273D7167F9756DCA5CE4AF8005D7E5B8D6
                            0;255;3;0;9;read: 26-26-0 s=2,c=3,t=16,pt=0,l=0,sg=0:
                            0;255;3;0;9;SHA256: 3081C0AF2996E0041CC85171727DB5F96A8201CF0BCC0D92FE3CC33C2A7B9705
                            0;255;3;0;9;send: 0-0-26-26 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:3081C0AF2996E0041CC85171727DB5F96A8201CF0BCC0D92FE
                            0;255;3;0;9;Signature in message: 01395A6873A0741CFD612BEC59D9E865888C6C29
                            0;255;3;0;9;Message to process: 1A002EE10102905B3A4201
                            0;255;3;0;9;Current nonce: 3081C0AF2996E0041CC85171727DB5F96A8201CF0BCC0D92FEAAAAAAAAAAAAAA
                            0;255;3;0;9;HMAC: 137DD0BB67606DDBF1F16854BFE720BB29C6ED1BFDD421430688DFC08F0813AF
                            0;255;3;0;9;Signature bad: 017DD0BB67606DDBF1F16854BFE720BB29C6ED1B
                            0;255;3;0;9;SHA256: 6BB69A71C65A24D7077B9B2A2E65D51B3861A56CF777BBD6B6B626B2A3942FAF
                            0;255;3;0;9;send: 0-0-32-32 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:6BB69A71C65A24D7077B9B2A2E65D51B3861A56CF777BBD6B6
                            0;255;3;0;9;Signature in message: 012DE76DD7349510C9CAE6F072875D7D7C380BBDD00C65339B
                            0;255;3;0;9;Current nonce: 6BB69A71C65A24D7077B9B2A2E65D51B3861A56CF777BBD6B6AAAAAAAAAAAAAA
                            0;255;3;0;9;HMAC: A7FC0A4823BBE2F65EFC0F872743D808BB3DE432CCDEED33353C46B6D50736DD
                            0;255;3;0;9;Signature bad: 01FC0A4823BBE2F65EFC0F872743D808BB3DE432CCDEED3335
                            0;255;3;0;9;read: 22-22-0 s=3,c=1,t=0,pt=7,l=5,sg=0:31.0
                            0;255;3;0;9;Sending message on topic: GW1_out/22/3/1/0/0
                            0;255;3;0;9;SHA256: B7CD5773148E8916C98B5BB16265F17811F8091A560A3535EB6113A76207EE59
                            0;255;3;0;9;send: 0-0-32-32 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:B7CD5773148E8916C98B5BB16265F17811F8091A560A3535EB
                            0;255;3;0;9;Signature in message: 01959641C93642F85E13499948DC33F1CE3B1B0DE5D8DEC8F5
                            0;255;3;0;9;Current nonce: B7CD5773148E8916C98B5BB16265F17811F8091A560A3535EBAAAAAAAAAAAAAA
                            0;255;3;0;9;HMAC: 218006AFDB5D1A909B39808D0F79E620974D2B7A291A929FD4524C0D3E5BEF9E
                            0;255;3;0;9;Signature bad: 018006AFDB5D1A909B39808D0F79E620974D2B7A291A929FD4
                            0;255;3;0;9;SHA256: 43AADEA58D5CC9AF0A58FE4A763CEE560CB751BCF31BAD7F4CCAEEC0925C60AA
                            0;255;3;0;9;send: 0-0-32-32 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:43AADEA58D5CC9AF0A58FE4A763CEE560CB751BCF31BAD7F4C
                            0;255;3;0;9;Signature in message: 0117705F14F7482ACEEC510ADD5EB2CBB329B3FA4754861826
                            0;255;3;0;9;Current nonce: 43AADEA58D5CC9AF0A58FE4A763CEE560CB751BCF31BAD7F4CAAAAAAAAAAAAAA
                            0;255;3;0;9;HMAC: DD7AADA9C207653FF0E5184E006CCB4707837275511EC2136773AEFE80C89AB9
                            0;255;3;0;9;Signature bad: 017AADA9C207653FF0E5184E006CCB4707837275511EC21367
                            • AnticimexA
                              AnticimexA
                              Anticimex
                              I believe we sorted this through chat/github. Thanks for finding the issue and helping out with testing!
                              • T
                                tomkxy
                                @anticimex Thanks to your excellent working, it is working now.
                                • AnticimexA
                                  AnticimexA
                                  Anticimex
                                  #36
                                  :+1:
