  3. Wifi gateway don't forward messages
2 Posts 2 Posters 829 Views 1 Watching
  • obel38O
    obel38O
    obel38
    Hi guys,
    i am working with domoticz, Raspberry Pi
    And a wifi ESP8266 Gateway,
    Sensors send datas to wifi gateway but gateway do not send datas to Domoticz,
    i checked with putty, i can connect and read sensors stream in gateway
    Gateway is connected in domoticz (log file)
    Domoticz is working well, before working with wifi gateway, i was working with serial gateway, and everything was working well !
    it seems that domoticz ignore messages freom gateway
    I could not underrstand ...
    do you have any ideas, how to fix it ?
    • sundberg84S
      Hi!
      Im not familiar with the Wifi so might be a stupid question - but is Wifi gateway supported by Domoticz? (Does it work the same way as Ethernet gw?)... Adding a serial gateway and ethernet gateway to hardware you have to change the settings in your hardware menu.
