  3. Vera
  4. VeraPlus - sensors not showing data on dashboard
3 Posts 1 Posters 1.8k Views 2 Watching
  • smintS
    smintS
    smint
    Hello all,
    So I got my ethernet GW going , as well as my first testing sensor and I run on VeraPlus gateway.
    The sensor is working and the gateway is ethernet GW is recieving data:
    0_1465632197216_upload-f217000c-62a6-46e8-9aa7-c923f22788ec
    It is a bit unstable - sometimes I get: "Failed reading humidity from DHT" but most of the time it works ok. I do not have a resistor on the PCB for the DHT though.
    On vera the recognition of the sensor went fine, I got a node and 2 readings - temp and humidity. My problem really is that although I can see the values being recieved by the GW via serial monitor - Vera does not show it - it's just blank:
    0_1465632360848_upload-94d95dce-5b78-42c1-b771-5f538d5a9cbb
    Any ideas?
    • smintS
      smintS
      smint
      Also - I tried to reboot Vera and now I got "MySensors plugin : Cannot send command - communications error" ....
      • smintS
        smintS
        smint
        It might be with the sensor itself? My readins are very unrealiable:
        0_1465635302009_upload-227f8122-d5e0-4b5e-8fbf-fe298fea3109
        Its a DHT11
