  3. FTDI Header (on Pro Mini) and removable pins
8 Posts 4 Posters 3.2k Views 1 Watching
  • marceltrapmanM
    marceltrapmanM
    marceltrapman
    While working on my 'minimize what can be minimized' I am now thinking how I can change/remove the header for the FTDI programmer on the Pro Mini.
    Straight or 90degrees they always take more 'air' than necessary so I would like to use a header or plugs that can be removed.
    Does anyone have a suggestion for what I can use?
    Fulltime Servoy Developer
    • korttomaK
      korttomaK
      korttoma
      I usually don't solder any header to the FTDI programmer pins on the Pro Minis. I just shove the pins on the FTDI USB interface through the holes on the Pro Mini where the header should be during programming and it works fine.
      If I have a different source of power to the pro mini I just bend the VCC pin from the FTDI USB interface so it does not connect (note: bend it to many times it will brake).
      • Tomas
      • YveauxY
        YveauxY
        When you're designing your own PCB you can consider a PCB connector like the one used for isa cards or the c64 cartridge connector. Just reserve a few tracks on the edge of your PCB and slide over the connector when you need it connected.
        Too big, but just for the idea:https://lh5.googleusercontent.com/proxy/7LrkILFdxzV5bCUh5JJcfEBU_01hU5D6D2QUGCHPQlEZaQ2YpIJK-6YZorrXemi-G3kJ965mpbWekRh8MPeSb1beI8bxhCYj7oIkZ4iUCXpKoVFA66bpSWz67smwJCWBDbvgbECxHD_0WJb6KPiAaT0Rr3Vb1daqh4sdDG_ZXQP2XOrOGxjyaAMyhPjMRgs=w418-h235-nc
        • Z
          Z
          Zeph
          Cool new tech - you can have a few strips near the edge of a PCB which then fit in a socket :-) :-)
          YveauxY 1 Reply Last reply
          • Z Zeph
            YveauxY
            YveauxY
            @Zeph It's ultra low-tech, but it just works. What's wrong with that ? ;-)
            Takes up little board space and doesn't add any costs to the board, only to the programmer (cable).
            Only problem is I couldn't find any suitable, low pin count connector for it at the regular suppliers... Possibly because I don't know the actual name of such connector.
            marceltrapmanM Z 2 Replies Last reply
            • YveauxY Yveaux
              marceltrapmanM
              marceltrapmanM
              marceltrapman
              Thank you guys, I soldered a board yesterday without connector. While I am still trying out things it was a bit of a pain to keep it in my hands (will use a piece of tape next time I think) but it works.
              @Yveaux Next thing was ask you for the name of the connector :) I removed a board from a scanner a few weeks ago and found a couple of these connectors and they actually look nice.
              • YveauxY Yveaux
                Z
                Z
                Zeph
                @Yveaux I have nothing against low tech that works!
                I was just amused, since PCB edge connectors were ubiquitous decades ago. And it's still a good option.
                Or are you looking for something fancier than "card edge connector"?
                • Z Zeph
                  YveauxY
                  YveauxY
                  @Zeph said:
                  card edge connector
                  Now we know the 'official' name!
                  Thanks dude :+1:
                  I think this one should suffice for a ISP connector: http://www.digikey.com/product-detail/en/7-5530843-7/A101966-ND/2310829
