  3. Help with bed occupancy-sketch using preassure sensor
2 Posts 1 Posters 867 Views 1 Watching
  • Cliff KarlssonC
    Cliff KarlssonC
    Cliff Karlsson
    I am going to try to place an fsr-preassure sensor in my bed to check if it can be used as a bed occupancy sensor. But I really suck at coding and just tried to modify an existing sketch into this:
    #include <MyConfig.h>
    #define NODE_ID 1
    #define OPEN 1
    #define CLOSE 0
    MyMessage msg(NODE_ID, V_TRIPPED);
    int FSR_Pin = A0; //analog pin 0
    uint8_t value = OPEN;
      present(NODE_ID, S_DOOR);
     int FSRReading = analogRead(FSR_Pin);
     if(FSRReading > 300)
    value=CLOSE;
    else
    value=OPEN;
    send(msg.set(value));
    sleep(10000);
    I don't really know the what FSR reading I will have to use but I am starting with 800 (value goes from 0- ~1000)
    Will this sketch trigger as soon as the FSR rading is above 800 and stay triggered until reading drops under 800 ?
    • Cliff KarlssonC
      Cliff KarlssonC
      Cliff Karlsson
      This is a regular basic sketch that uses the sensor.
      void setup(){
        Serial.begin(9600);
      void loop(){
        Serial.println(FSRReading);
        delay(250); //just here to slow down the output for easier reading
