  3. Humidity example sketch not working
sketchhumiditysrror
5 Posts 2 Posters 3.7k Views 1 Watching
  • A
    A
    ajachierno
    I am getting an error when I try and run the example humidity sketch. Error details below
    HumiditySensor copy copy copy.ino:11:5: error: no matching constructor for initialization of 'DHT'
    DHT dht;
    libraries/DHT/DHT.h:32:3: note: candidate constructor not viable: requires at least 2 arguments, but 0 were provided
    DHT(uint8_t pin, uint8_t type, uint8_t count=6);
    libraries/DHT/DHT.h:23:7: note: candidate constructor (the implicit copy constructor) not viable: requires 1 argument, but 0 were provided
    class DHT {
    1 error generated.
    Any one have any ideas? Pretty new to this.
    • marceltrapmanM
      marceltrapmanM
      marceltrapman
      wrote on last edited by marceltrapman
      Did you download and install all libraries that are available in the MySensors Arduino Master folder (stop running Arduino IDE, copy/paste files in library folder, start Arduino IDE).
      Fulltime Servoy Developer
      • A
        A
        ajachierno
        yes, also I have actually been trying to run it using codebender and didn't work there so then I did try doing it in the native IDE and still not working. My understanding is codebender has all the libraries built in so I am thinking it isn't a library issue, although like I said new at this so may be wrong
        • A ajachierno
          marceltrapmanM
          marceltrapmanM
          marceltrapman
          @ajachierno I am not sure what to say, it runs 'out of the box' here.
          Which version of the sketch are you using?
          this is where it goes wrong I guess:
          requires 1 argument, but 0 were provided class DHT
          • A
            A
            ajachierno
            I am running straight off the webpage. Actually it doesnt apear I can get any of the sketches to run using either the browser plg in or the native IDE.... :/ wishing I hadnt updated since this last set of changes.
