  3. Vera
  4. Problems with installing the plugin
3 Posts 2 Posters 1.5k Views 1 Watching
  • G
    G
    Gralq
    Hi!
    I've just started building the gateway and first sensors and been messing around a bit with the Vera Lite.
    But now when I'm trying to install the plugin the device shows up as empty and I can't configure serial port since the MySensors device isn't visable.
    I'm following the guide on http://www.mysensors.org/build/vera and I think that I haven't missed something. I'm c/p the contents of the files to notepad and substituting .txt with the correct extensions before uploading them to the Vera.
    Does anyone have a guess about what I've done wrong?
    • R
      R
      rafael.brasilia
      If you go to Github and download the zip with all the files, you dont need to copy and paste the code and save with the correct extension.
      you can use this link to download the zip:
      https://github.com/mysensors/Arduino
      Have you looked in the debugger to see if your Gateway initialization is successful? I also had problems getting my Vera to recognize my Gateway, and that was because the Arduino I was using was one of those clones from china. When I bought a Genuine Gravitech Nano, it worked right away.
      • G
        G
        Gralq
        Yay, it's working!
        Thanks for the info about the zip file!
        I'm using a china clone as gateway but it seems to be working. I'm getting info from my mini pro with an attached dth22 at least. =)
