  3. Scene Controller
Scene Controller
52 Posts 20 Posters 35.2k Views 6 Watching
  • T tbully
    Thanks @awi. I meant to come back and correct my post. I did see that after going back and looking at the old 1.4 API (you are correct). It has been many months since I've looked at this sketch. However, I'm not using the default PINs here so I guess I have to change MyConfig for this sketch?
    *  NRF24L01 Driver Defaults
    #define RF24_CE_PIN		   9
    #define RF24_CS_PIN		   10
    AWIA
    AWIA
    AWI
    @tbully The new API uses a separate radio class initiator Something like (from one of my own 'learnings' , Ceech board in this case)
    MyTransportNRF24 transport(7, 8); // Sensoduino (8,7) Ceech board, 3.3v (7,8)  (pin default 9,10)
    MySensor gw(transport);
    • T
      tbully
      @awi , not surprisingly, this worked as expected.
      I changed the following in Hek's script and it worked fine:
      MyTransportNRF24 transport(17, 18);
      • alexsh1A
        alexsh1A
        alexsh1
        #43
        Bringing back this old thread as I am building the scene controller now.
        I am having a problem with a lot of garbage like this:
        send: 7-7-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
        send: 7-7-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.2
        send: 7-7-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
        read and drop: 7-7-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
        read and drop: 0-224-0 s=0,c=0,t=0,pt=0,l=0,sg=0:
        ver mismatch
        ver mismatch
        goes on and on
        I do not have different MySensors GW/nodes. All of my GW/Nodes have MYS 1.5.2 Where does ver mismatch come from? Also time is not getting pulled into the scene controller from the controller (Domoticz).
        Cannot get time from the controller either...
        alexsh1A 1 Reply Last reply
        • alexsh1A alexsh1
          ver mismatch
          ver mismatch
          goes on and on
          alexsh1A
          alexsh1A
          alexsh1
          #44
          OK, just to revive this project, I decided to modify it as follows:
          This would make the transmitter fit between the screen and the adapter
          The problem is that this sandwich is super thick. So I got a new screen from itead studio, which can be used without the adapter. In this photo I desoldered D14-D21 pins as they are not used in order to hook up nrf24l01+:
          • alexsh1A alexsh1
            alexsh1A
            alexsh1A
            alexsh1
            #45
            This is a semi finished project. The power is fed via ICSP through 662k (under the red tape):
            Now I need to isolate everything:
            This is how Mega + the screen looks:
            Now I need to figure out how to stick the battery between the screen and Mega :)
            Any suggestions welcome!
            • alexsh1A alexsh1
              alexsh1A
              alexsh1A
              alexsh1
              #46
              Additionally, I have recently received a new Enhanced Nextion screen (again from Itead Studio) and a new ESP8266 PCB:
              Much thinner :-) so watch this space....
              • scalzS
                scalzS
                wrote on last edited by scalz
                #47
                @alexsh1
                cool ;) I made one like this some time ago https://forum.mysensors.org/topic/2766/an-esp8266-nextion-scene-controller/5
                but it's not with the new nextion rev. i like these hmi screens, easy to use.
                • scalzS scalz
                  @alexsh1
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @scalz Yeah, I saw your post a few months ago and it made me think seriously about getting my hands dirty with ESP8266. I have just started so do not expect to come up with anything fully working tomorrow as there are many peculiarities concerning ESP8266 from firmware to programming.
                  You have fully finished integration of your thermostat/scene controller with the controller?
                  Are you using Domoticz?
                  • scalzS
                    scalzS
                    #49
                    @alexsh1 i'm using mqtt and jeedom for this (jeedom has plugin for thermostat etc..) and i have another board which does energy monitoring+heater management. just for curiosity, i have enough pcb lol, but where did you buy your pcb for nextion? or maybe you did it?
                    • scalzS scalz
                      alexsh1A
                      alexsh1A
                      alexsh1
                      #50
                      @scalz I am not that smart yet to design my own boards. Having said that I have made a good progress on C++ and MySensors over a year. So designing my own PCB is a next logical step.
                      The problem is that my home has been fully automated. I have to challenge myself with a more difficult projects or move on to automate my neighbours house lol :-)
                      The most difficult part though is finding the right case. Printing on 3D printer is not cheap as I do not have one and finding something of the shelf is literally impossible.
                      Talking about the PCB, I took the one design by
                      Peter and Aidan:
                      http://tech.scargill.net/new-pcb/
                      However, I'm redesigning the software part to make it a multi functioning scene controller for Domoticz.
                      • alexsh1A
                        alexsh1A
                        alexsh1
                        #51
                        A small teaser - quick menu. One has to be a graphic designer to get the menu nailed.
                        • alexsh1A
                          alexsh1A
                          alexsh1
                          #52
                          This is still in an alpha state and ESP8266 development may take some time.
                          This is a TFT screen with the daughter board:
