Sleep walk?
I use example BinarySwitchSleepSensor.ino with change
- 105, 113 "if (true) {"
Why "sleep(5);" normal? I look at sleep code on github and time smaller than 15 not sleep? I try "sleep(1000);" but it not work too?
If the sleep you mention, is the one to let your buttons settle as the code in this example, line100. then it's "just" to let your buttons settle, to handle the contact/switch bounce
sleep(5);
