  3. RFID v2
RFID v2
12 Posts 4 Posters 5.2k Views 4 Watching
  • D
    D
    davedeluxe
    Has anybody updated the RFID-Sketch to MySensors v2 ?
    It´s not in the examples-list :(
    Thanks, Dave
      @davedeluxe the RFID example depends on an external library. To avoid conflicts, examples depending on external libraries are in a separate git repository (since v2.0). You'll find it at https://github.com/mysensors/MySensorsArduinoExamples/tree/master/examples/RFIDLockSensor
      • D
        D
        davedeluxe
        THANK YOU!!
          A Former User
          Has anyone got this working.
          I have connected as instructed, in the sketch and upload the sketch from the link. But my sensor I just trying to connect.
          TSM:INIT
          TSM:RADIO:OK
          TSP:ASSIGNID:OK (ID=1)
          TSM:FPAR
          TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR
          !TSM:FPAR:FAIL
          !TSM:FAILURE
          TSM:PDT
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR
          !TSM:FPAR:FAIL
          !TSM:FAILURE
          TSM:PDT
          can anyone help here?
          • ? A Former User
            TSM:INIT
            TSM:RADIO:OK
            TSM:FPAR
            TSM:INIT
            TSM:RADIO:OK
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            !TSM:FPAR:FAIL
            !TSM:FAILURE
            TSM:PDT
            TSM:INIT
            TSM:RADIO:OK
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            !TSM:FPAR:FAIL
            !TSM:FAILURE
            TSM:PDT
            @fleshfear what do the logs from your gateway say?
            The node is onable to get a response from the gateway. See https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help for information on how to read the debug log.
              A Former User
              im not getting anything from the logs on the gateway, so I seems that the node is not getting connected to the gateway.
              but if I swap the RFID with a pir instead same wiring and all, only added the wire to the pir and swapped the power wires to the pir. Then it works perfectly.
              The setup is:
              Arduino Pro Mini 328 3.3v
              NRF24L01+
              PN532 NFC RFID Reader/Writer Module V3
              1Pc DC-DC Boost Converter Step Up Module 1-5V to 5V 500mA
              and this is the sketch, where you can see the RFID should connect to A4, A5, which i have solder on to the pro mini.
               * Version 1.0 - Henrik Ekblad
               * RFID Lock sensor/actuator
               * Use RFID tag to lock/unlock a door or trigger a scene on your controller.
               * This example sketch allows you to add an optional relay or solenoid
               * which can be activated/opened by RFID or controller.
               * Use the I2C wiring option for your RFID module and connect to the following Arduino pins.
               * RFID       Arduino
               * GND   ->   GND
               * VCC   ->   +5V
               * SCL   ->   A5
               * SDA   ->   A4
               * Use normal wiring for NRF24L01 radio
               * Attach a optional relay or solonoid lock to pin 4
               * http://www.mysensors.org/build/rfid
              #include <Wire.h>
              #include <PN532_I2C.h>
              #include <PN532.h>
              // Add your valid rfid keys here. To find you your key just run sketch; hold your new RFID tag in fron ot the reader;
              // and copy the key from serial output of this sketch.
              const uint8_t maxKeyLength = 7;
              uint8_t validKeys[][maxKeyLength] = {
                                  { 0xB3, 0xC6, 0xD9, 0x80, 0x00, 0x00, 0x00 },
                                  { 0, 0, 0, 0, 0, 0, 0 },    // ADD YOUR KEYS HERE!
                                  { 0, 0, 0, 0, 0, 0, 0 }};
              int keyCount = sizeof validKeys / maxKeyLength;
              #define CHILD_ID 10   // Id of the sensor child
              // Pin definition
              const int lockPin = 4;         // (Digital 4) The pin that activates the relay/solenoid lock.
              bool lockStatus;
              MyMessage lockMsg(CHILD_ID, V_LOCK_STATUS);
              PN532_I2C pn532i2c(Wire);
              PN532 nfc(pn532i2c);
                pinMode(lockPin, OUTPUT);
                nfc.begin();
                uint32_t versiondata = nfc.getFirmwareVersion();
                if (! versiondata) {
                  Serial.print("Couldn't find PN53x board");
                  while (1); // halt
                Serial.print("Found NFC chip PN5"); Serial.println((versiondata>>24) & 0xFF, HEX);
                Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);
                Serial.print('.'); Serial.println((versiondata>>8) & 0xFF, DEC);
                // Set the max number of retry attempts to read from a card
                // This prevents us from waiting forever for a card, which is
                // the default behaviour of the PN532.
                nfc.setPassiveActivationRetries(0x3);
                // configure board to read RFID tags
                nfc.SAMConfig();
                lockStatus = loadState(0);    // Read last lock status from eeprom
                setLockState(lockStatus, true); // Now set the last known state and send it to controller
              void presentation()  {
                sendSketchInfo("RFID Lock", "1.0");
                present(CHILD_ID, S_LOCK);
                bool success;
                uint8_t key[] = { 0, 0, 0, 0, 0, 0, 0 };  // Buffer to store the returned UID
                uint8_t currentKeyLength;                        // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
                // Wait for an ISO14443A type cards (Mifare, etc.).  When one is found
                // 'uid' will be populated with the UID, and uidLength will indicate
                // if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)
                success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, &key[0], &currentKeyLength);
                if (success) {
                  Serial.print("Found tag id: ");
                  for (uint8_t i=0; i < currentKeyLength; i++)
                    if (i>0) Serial.print(",");
                    Serial.print("0x");Serial.print(key[i], HEX);
                  for (uint8_t i=currentKeyLength; i < maxKeyLength; i++)
                    Serial.print(",0x00");
                  Serial.println("");
                  bool valid = false;
                  // Compare this key to the valid once registered here in sketch
                  for (int i=0;i<keyCount && !valid;i++) {
                    for (int j=0;j<currentKeyLength && !valid;j++) {
                      if (key[j] != validKeys[i][j]) {
                        break;
                      if (j==currentKeyLength-1) {
                        valid = true;
                  if (valid) {
                    // Switch lock status
                    setLockState(!lockStatus, true);
                  // Wait for card/tag to leave reader
                  while(nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, &key[0], &currentKeyLength));
              // Unlocks the door.
              void setLockState(bool state, bool doSend){
                if (state)
                   Serial.println("open lock");
                else
                   Serial.println("close lock");
                if (doSend)
                  send(lockMsg.set(state));
                digitalWrite(lockPin, state);
                saveState(0,state);
                lockStatus = state;
                if (message.type==V_LOCK_STATUS) {
                   // Change relay state
                   setLockState(message.getBool(), false);
                   // Write some debug info
                   Serial.print("Incoming lock status:");
                A Former User
                wrote on last edited by [[global:former-user]]
                This post is deleted!
                J 1 Reply Last reply
                • ? A Former User
                  [[topic:post-is-deleted]]
                  J
                  J
                  jeti
                  @fleshfear sorry that i can not help, but i just ran into the very same issue... any solutions yet or at least reasons for the
                  ? 1 Reply Last reply
                  • J jeti
                    A Former User
                    @jeti the first thing was not enough power to the radio, and i think the next thing is the I2C mode. But it seems that i have set that one up correctly also so im not sure now.
                    Im download a raw PN532 Libary with exemples to see if it the board, or maybe something with mysensors.
                      A Former User
                      i got it working.
                      i sat the board in I2C Mode, channel1 = on and channel2 = off.
                      Then i powered the PN532 board on a external power source.
                      Before i did a step up to 5V, that was wrong it should only get 3.3V.
                      And the arduino GND should be connected to the external power sources GND as well, to make a common ground.
                      Hope it helps.
                      J 2 Replies Last reply
                      • ? A Former User
                        i got it working.
                        Hope it helps.
                        J
                        J
                        jeti
                        @fleshfear great! I will try it as soon as i can!
                        • ? A Former User
                          i got it working.
                          Hope it helps.
                          J
                          J
                          jeti
                          @fleshfear: ok got it also working. Thanks. mine works with 3.3V and 5V
