  3. RFID v2
RFID v2
12 Posts 4 Posters 5.2k Views 4 Watching
  • D
    davedeluxe
    THANK YOU!!
      A Former User
      Has anyone got this working.
      I have connected as instructed, in the sketch and upload the sketch from the link. But my sensor I just trying to connect.
      TSM:INIT
      TSM:RADIO:OK
      TSP:ASSIGNID:OK (ID=1)
      TSM:FPAR
      TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      !TSM:FPAR:FAIL
      !TSM:FAILURE
      TSM:PDT
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      !TSM:FPAR:FAIL
      !TSM:FAILURE
      TSM:PDT
      can anyone help here?
      • ? A Former User
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        !TSM:FPAR:FAIL
        !TSM:FAILURE
        TSM:PDT
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        !TSM:FPAR:FAIL
        !TSM:FAILURE
        TSM:PDT
        @fleshfear what do the logs from your gateway say?
        The node is onable to get a response from the gateway. See https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help for information on how to read the debug log.
          A Former User
          im not getting anything from the logs on the gateway, so I seems that the node is not getting connected to the gateway.
          but if I swap the RFID with a pir instead same wiring and all, only added the wire to the pir and swapped the power wires to the pir. Then it works perfectly.
          The setup is:
          Arduino Pro Mini 328 3.3v
          NRF24L01+
          PN532 NFC RFID Reader/Writer Module V3
          1Pc DC-DC Boost Converter Step Up Module 1-5V to 5V 500mA
          and this is the sketch, where you can see the RFID should connect to A4, A5, which i have solder on to the pro mini.
           * Version 1.0 - Henrik Ekblad
           * RFID Lock sensor/actuator
           * Use RFID tag to lock/unlock a door or trigger a scene on your controller.
           * This example sketch allows you to add an optional relay or solenoid
           * which can be activated/opened by RFID or controller.
           * Use the I2C wiring option for your RFID module and connect to the following Arduino pins.
           * RFID       Arduino
           * GND   ->   GND
           * VCC   ->   +5V
           * SCL   ->   A5
           * SDA   ->   A4
           * Use normal wiring for NRF24L01 radio
           * Attach a optional relay or solonoid lock to pin 4
           * http://www.mysensors.org/build/rfid
          #include <PN532_I2C.h>
          #include <PN532.h>
          // Add your valid rfid keys here. To find you your key just run sketch; hold your new RFID tag in fron ot the reader;
          // and copy the key from serial output of this sketch.
          const uint8_t maxKeyLength = 7;
          uint8_t validKeys[][maxKeyLength] = {
                              { 0xB3, 0xC6, 0xD9, 0x80, 0x00, 0x00, 0x00 },
                              { 0, 0, 0, 0, 0, 0, 0 },    // ADD YOUR KEYS HERE!
                              { 0, 0, 0, 0, 0, 0, 0 }};
          int keyCount = sizeof validKeys / maxKeyLength;
          #define CHILD_ID 10   // Id of the sensor child
          // Pin definition
          const int lockPin = 4;         // (Digital 4) The pin that activates the relay/solenoid lock.
          bool lockStatus;
          MyMessage lockMsg(CHILD_ID, V_LOCK_STATUS);
          PN532_I2C pn532i2c(Wire);
          PN532 nfc(pn532i2c);
            pinMode(lockPin, OUTPUT);
            nfc.begin();
            uint32_t versiondata = nfc.getFirmwareVersion();
            if (! versiondata) {
              Serial.print("Couldn't find PN53x board");
              while (1); // halt
            Serial.print("Found NFC chip PN5"); Serial.println((versiondata>>24) & 0xFF, HEX);
            Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);
            Serial.print('.'); Serial.println((versiondata>>8) & 0xFF, DEC);
            // Set the max number of retry attempts to read from a card
            // This prevents us from waiting forever for a card, which is
            // the default behaviour of the PN532.
            nfc.setPassiveActivationRetries(0x3);
            // configure board to read RFID tags
            nfc.SAMConfig();
            lockStatus = loadState(0);    // Read last lock status from eeprom
            setLockState(lockStatus, true); // Now set the last known state and send it to controller
          void presentation()  {
            sendSketchInfo("RFID Lock", "1.0");
            present(CHILD_ID, S_LOCK);
            bool success;
            uint8_t key[] = { 0, 0, 0, 0, 0, 0, 0 };  // Buffer to store the returned UID
            uint8_t currentKeyLength;                        // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
            // Wait for an ISO14443A type cards (Mifare, etc.).  When one is found
            // 'uid' will be populated with the UID, and uidLength will indicate
            // if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)
            success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, &key[0], &currentKeyLength);
            if (success) {
              Serial.print("Found tag id: ");
              for (uint8_t i=0; i < currentKeyLength; i++)
                if (i>0) Serial.print(",");
                Serial.print("0x");Serial.print(key[i], HEX);
              for (uint8_t i=currentKeyLength; i < maxKeyLength; i++)
                Serial.print(",0x00");
              Serial.println("");
              bool valid = false;
              // Compare this key to the valid once registered here in sketch
              for (int i=0;i<keyCount && !valid;i++) {
                for (int j=0;j<currentKeyLength && !valid;j++) {
                  if (key[j] != validKeys[i][j]) {
                  if (j==currentKeyLength-1) {
                    valid = true;
              if (valid) {
                // Switch lock status
                setLockState(!lockStatus, true);
              // Wait for card/tag to leave reader
              while(nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, &key[0], &currentKeyLength));
          // Unlocks the door.
          void setLockState(bool state, bool doSend){
            if (state)
               Serial.println("open lock");
               Serial.println("close lock");
            if (doSend)
              send(lockMsg.set(state));
            digitalWrite(lockPin, state);
            saveState(0,state);
            lockStatus = state;
            if (message.type==V_LOCK_STATUS) {
               // Change relay state
               setLockState(message.getBool(), false);
               Serial.print("Incoming lock status:");
            A Former User
            wrote on last edited by [[global:former-user]]
            J 1 Reply Last reply
            • ? A Former User
              [[topic:post-is-deleted]]
              J
              J
              jeti
              @fleshfear sorry that i can not help, but i just ran into the very same issue... any solutions yet or at least reasons for the
              ? 1 Reply Last reply
              • J jeti
                A Former User
                @jeti the first thing was not enough power to the radio, and i think the next thing is the I2C mode. But it seems that i have set that one up correctly also so im not sure now.
                Im download a raw PN532 Libary with exemples to see if it the board, or maybe something with mysensors.
                  A Former User
                  i got it working.
                  i sat the board in I2C Mode, channel1 = on and channel2 = off.
                  Then i powered the PN532 board on a external power source.
                  Before i did a step up to 5V, that was wrong it should only get 3.3V.
                  And the arduino GND should be connected to the external power sources GND as well, to make a common ground.
                  Hope it helps.
                  J 2 Replies Last reply
                  • ? A Former User
                    i got it working.
                    Hope it helps.
                    J
                    J
                    jeti
                    @fleshfear great! I will try it as soon as i can!
                    • ? A Former User
                      i got it working.
                      Hope it helps.
                      J
                      J
                      jeti
                      @fleshfear: ok got it also working. Thanks. mine works with 3.3V and 5V
                      12.5k
